retird
Everything posted by retird
  1. I wasn't aware that the Paranormal ships with an OTG cable. I thought it just shipped with a USB charging/data cable.
  2. A quick "search" for this csv returns this....the "search box" is your friend.... https://forum.evolvapor.com/applications/core/interface/file/attachment.php?id=233534
  3. I use a 510 to 510 adapter and just fill the female end with solder.... Link to cheap adapter... https://www.fasttech.com/product/1563302-510-to-510-adapter-for-e-cigarette
  4. The SS316 CSV should work fine.... I have used Notch Coils for years now and without issue on my 250C. Here is the CSV for SS316L that I have used for years. You can try it but I suspect a connectivity issue in your atty, hot spot, dirty 510 connection, poor ground, or etc. SS 316L.csv
  5. In Theme Designer under the Light Indicator tab are the settings the same for both devices?
  6. Does it do the same thing in TC mode? May be a connectivity issue with the coil, atty, or etc. Are you using spaced coils? In Device Monitor what coil resistance variation (Cold ohms to Live ohms) do you get while vaping ?
  7. Just solder the center pin to the main body creating a dead short. That does the same thing as the tool you speak of.
  8. One way is to go into EScribe with your device connected and select the profile you are using and click Temperature OFF. Upload to your device. Another way is to change the profile you are using to a different profile that is not in TC mode. OR Datasheet has lots of info: https://downloads.evolvapor.com/dna250.pdf Old DNA200 datasheet attached also.... below DNA 200 data sheet.pdf
  9. You might try going to EScribe Display tab and see if the Power Bank setting is set to Auto or Manual (in theme). What do you get when you set it to Auto? My understanding is the DNA 250C supports USB On-The-Go. An OTG adapter may be plugged into the Micro USB port on the device to charge any other device capable of charging via USB.
  10. What auxilliary power supply are you using, voltage, amperage, and etc. ?
  11. IT's OK.... my 250C board in a different device does the same.....
  12. Thank you @mactavish for the history lesson.... I've been using Evolv stuff since the Darwin days, alpha or beta tested every one except for one over the years, and I could write a book about what could possibly delay a release of a board/software/firmware/update and etc. As you know when they plan on a release, being their best estimate, they are also working on several new things also that may materialize in the future. Knowing Evolv and the folks there I am not hesitant to say that they have not held back, as far as I know, on a release just to increase sales on something else. Heck you can still buy DNA20, 40, 25, 60, and etc. boards. When the update that gives Replay to the 75C is ready to be released it will be put out.
  13. Not knowing the full description of the purpose of PK "Allow on unlikely coils" it may just be a hidden tool that can be used to see if one can vape what seems to be an "unlikely coil". At this point I see no real value to use it on a regular basis as Replay works nicely.... or maybe it's use can be used for something coming in the future that we know not what it is yet...???? For years now we have seen the DNA technology continually go to the next level and I have wondered for years also if Evolv will ever design what is the weak link (in my opinion) of vaping. That being the atomizer with its legacy connection issues. How great it would be to have a new atomizer technology with something different than the "the old technology in the room" .... that being the 510 connector. Noted that Evolv's 510 connector is the best one I've ever used.....
  14. 0.004 is standard as Nick posted.......
  15. Are you running the latest approved version of EScribe? You might try installing the INT version from this link https://www.evolvapor.com/products/dna250color Scroll down to EScribe Suite..... Select INT version
  16. In EScribe select Help/Backups....... ecig files Always good to save ecig file and ecigtheme files to your computer for future needs.....
  17. https://www.evolvapor.com/products/dna250color Scroll down to EScribe Suite..... Select version you want....
  18. AMD..... loaded the Boxer *,ecig file and Replay didn't work on my 250C....... Try this Test Theme and see if it does anything..... it is just the Default Evolv theme with a Toggle to turn on and off Replay on the main screen... NEXT DAY EDIT: Will Load Boxer Default and see if it seems to work? Test 250C Theme.ecigtheme
  19. Probably not the issue but could you post up the *.ecig file and I'll spin it on my 250C with SS....
  20. An *.ecigprofile file is different than a *.cvs file..... What is the name of the file you downloaded?
  21. Look under Language in Theme Designer.....
  22. You could use the 3 mounting screws that hold the board in the enclosure as they are ground. Make sure that your 510 is tightly screwed into the enclosure as that will be the ground for the 510. OR you can run a ground wire from the power out ground solder pad to the shell (silver part) of the 510. Here is a data sheet that also has a wiring schematic and picture... https://downloads.evolvapor.com/dna250.pdf
  23. You might review the board dimensions, button placement and mounting screw holes, and etc.... Info contained in these 2 datasheets with pictures... https://downloads.evolvapor.com/dna250color.pdf https://downloads.evolvapor.com/dna75color.pdf
  24. Here is but one way to access Replay. Theme designs can be used to access Replay feature also
  25. DNA250 Color Data Sheet..... https://downloads.evolvapor.com/dna250color.pdf
