Everything posted by retird
multiple ui Gauges - Major update 2.0.0
retird commented on SirTimmyTimbit's file in DNA 75 Color, 100 Color, 250 Color
Pardon me Sir Timmy..... I just hit fire button without vaping so I could view the screen and the power does work real time then goes immediately back to 22 watts when releasing the fire button (can't see my screen while vaping).... sorry for the Senior Moment on my part..... a similar function on a different theme keeps the last live reading on the Main Screen instead of going back to the set wattage in Replay. See if I can find that theme.... My Color Theme - 0.ecigtheme- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
Sir Timmy, thanks for the reply...... I'm using 1.6.0, and maybe it was updated since I downloaded it. When I vape in Replay the Main Screen shows 22 watts under the left (red) guage. It never changes from 22 watts. The guage setting is Power. The center guage setting is Blue and set to Voltage and constantly reads 0.78. The right most guage is orange and reads battery level. Really a moot point now since you now have 1.6.1...... Here is the theme file I'm using on the 75C. I'm gonna download your latest right now.... Thanks Gauges-1.6.0.ecigtheme- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
You can submit a suggestion here.... https://helpdesk.evolvapor.com/index.php?a=add&category=5
Nice Theme........ only wish that it would show real time wattage used when in Replay instead of just the set wattage.... on the main screen..... and on the lock screen it could show, when a usb is connected, it would show not only charging but also usb data cable is being used..... in other words a charging symbol and a usb data symbol when a data cable is being used.... Many times I have seen folks saying their device won't connect to EScribe only to find out they are only using a charge only usb cable... Attached shows my attempt to show the lock screen modified.... pictures for USB and Data are not really good enough for your excellent theme but you get the idea... THX for the nice theme.... Gauges-1.6.0 TEST.ecigtheme- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
retird replied to David Campbell's topic in EScribe, Software and Firmware
15.1 -
Is "Reset Statistics" broken for anyone else?
retird replied to niandra3's topic in Themes and Custom Screens
"If I recall when you reset Puffs it resets Puffs "Since Reset" and the "Total" Puffs doesn't ever reset but give a total since vaping started.... In Device Monitor.......... -
Can this work for you?
You might go to Help/ Backups in EScribe and you may be able to get the theme back.... autobackups are made and stored by date so you can select an earlier backup... and upload it to the device...
On the link posted click on "James" or on the "Early Firmware and EScribe, Software and Firmware" line and it will take you there... -
OK. now that you have EScribe can you post here the ecig file.... 1. Connect device to usb... 2. Start Escribe 3. After the automatic downloading of your ecig file you can click on File/ Save As to save the file to the computer. Post the saved file here by choosing "choose file" at the bottom of the post you are typing..
Can you check the Atty Settings for the Replay profile and see if the Replay box is checked? Also, without knowing the theme of the Vapecig I'm kinda shooting in the dark to help you... Maybe someone with that device can chime in and help....
Mod makers can design the Theme differently .... The theme of the Vapecig may be different than the Paranormal..... So what steps do you use to try to get Replay to work on the Vapecig?
Can you post the *.ecig file so we might look at it?
Could be just that the ribbon cable going to the display is getting pinched by the fire button when you push it.... if so just reposition the ribbon...
I always try to read a warranty......... Lifetime Warranty During the first year of ownership, MaxAmps will replace any defective LiPo or LiFe battery at no cost. After one year, any defective MaxAmps LiPo or LiFe battery can be exchanged for just 50% of the new pack's list price. Our lifetime warranty is non-transferrable. You must be the original owner to receive warranty coverage.
From this Manual: 9. CHARGING AND USB ON-THE-GO Internal Charging: The DNA 250C has a built in 2A USB charger. It automatically detects the type of USB power supply it is connected to, so it can be plugged into standard PC USB ports or higher power chargers. The max charge current is based on the cell capacity as programmed in EScribe. External charging (Recommended): Remove batteries from device. Follow charging instructions with using charger. Paranormal-DNA-250C-User-manual-0117.pdf
Lost Vape Triade reads resistance .04 too high
retird replied to george.pirpiris@gmail.com's topic in DNA 200 and 250
hum....... in Escribe the internal resistance setting should be around 0.004 not .04 for most devices.... -
Install this: EARLY SERVICE PACK (all devices) EScribe Suite 2.0 SP15.1 From here:
