Everything posted by retird
I have been deep in Evolv stuff also, since the Darwin days, then the Kick, then the DNA 20D, 30, Kick2, 25, DNA 40 (Temp Control), 1 amp charger board, DNA60, 75, DNA200, and etc, etc, including the latest DNA Go board ..... just ask Brandon.... ha ha..... but you may be right about the 5 watt increments but I'm just not remembering it that way.... ☺️
hum....... been a long time since the DNA200 came out and if memory serves me (at 70 years of age) the 1 5 and 10 settings are for Temperature adjustment (F)..... watts adjustment is .1 .2 .5 and 1.0 if I am remembering correctly.... Other Moderators can correct me if I'm in error....
Screenshot shows in lower left corner that the device is locked.... unlock it and see what goes then......
Try spaced coils as they seem to be the coils of choice for DNA boards......contact coils can be tricky to use........ try this: Build coils, dry burn if you choose. Set the atty aside and let it get completely back to ambient temperature. The device should be at ambient temperature also for best results. Attach atty to the device and vape.
- 3 replies
- dna250c
- paranormal
(and 2 more)
Tagged with:
Do you dry burn your coils and are they contact coils or spaced? What wire are you using?
- 3 replies
- 1
- dna250c
- paranormal
(and 2 more)
Tagged with:
https://downloads.evolvapor.com/dna60.pdf
Lost Vape Drone DNA250C - Squonk hose kinking
retird replied to str8.drippin's topic in DNA 250 Color
If there are any videos I have not seen them... -
Would it help to just take out the hose and reverse it and reinstall? -
Search the forum for VTC6 and find the csv you want to use.... surely there is a csv for single battery....
See page starting with "Installing the screen"..... https://downloads.evolvapor.com/dna250color.pdf It starts out like this: Installing the Screen The TFT screen connects to the DNA 250C using an 8 pin ZIF socket and a flexible cable to allow for design flexibility. The cable can be bent or folded (once) but care should be taken to not apply tension or strain to the area where the cable attaches to the screen itself. Once the screen is mounted the cable should be tucked up under the screen and not out towards the fire button. Positioning the cable near the fire button can allow the mods fire button to contact the cable when pressed which will cause eventual screen failure. Only insert or remove the screen before the board is powered on.
If you don't get it here you might contact VA and ask them for it..... link..... https://viciousantonline.com/contact-us/
Need how-to for screen replacement on drone 250c
retird replied to Bombastinator's topic in DNA 250 Color
OK..... you might google "Lost Vapes Drone 250C disassembly video" I've seen disassembly videos of other drones (maybe one of those could be helpful..... -
I don't think a DNA200 screen will work on the 250C...... here is a link to the 250C replacement screen..... https://www.evolvapor.com/products/dna250color -
Start a ticket with Evolv.... link in my sig line below
Since you just purchased it and had it only a few days you might contact the vendor to see about getting a replacement under their warranty.
What happens when you only plug in the usb cable with no device connected? Is this a Windows computer? Have you tried a different usb cable?
Can you post a picture of the board/wiring? Also have you tried a different atomizer?
The Plus requires SP20
http://learningrc.com/puffed-lipos/
Nothing in your video..... Did you follow the 2s Wiring diagram and bridge properly? Battery set to 2-cell in Escribe? https://downloads.evolvapor.com/dna250color.pdf How about a picture of the wiring on the board and battery holder?
Can you save the .ecig file to your computer and post that file here? Are you using the same Theme on both devices?
No hornets nest here..... the thread was always active but few can participate as they aren't users of Linux.... 😀
If you all still want to communicate with @James about Linux you might try asking by starting a ticket with Evolv Help Desk....there are few, few Linux folks around here.... @James is your go-to guy at Evolv... ask that your ticket comments be given to @James.... https://helpdesk.evolvapor.com/index.php?a=add&category=1
Also..... Too Hot: The DNA 75C has onboard temperature sensing. It will shut down and display this message if the internal board temperature becomes excessive.
