retird
Everything posted by retird
  1. OK now your Profile settings match both in the settings and o Device monitor. Put in a fresh battery now.
  2. Do you see in the General Tab the Settings screen for choice between "DL'"and "MTL" now? Connect device and screen shot DL profiles and then screenshot MTL profiles.
  3. Again what atty and what coil configuration are you using? Have you tried a different atty? Give a screenshot of Atomizer2 profiles. Screenshots are with the device connected to EScribe.
  4. Can you post a screenshot showing Atomizer2 profiles?
  5. If you started a ticket with Evolv they should reply back to you. Your issue may be a mod design issue, a connectivity issue, a bad solder joint, or many other things. Yes I saw the manual and the page in the manual you post. What atty and what coil are you using?
  6. Post a screenshot of your profile 3 settings please and are you in Replay?
  7. Try changing Fading >After Firing to "Activate the Screen". If the screen turns on sometimes it could be that the display ribbon that connects the display to the board is getting pinched by the one of the buttons when pushing them and it is usually the fire button...
  8. Is there a crack in the screen that you can see? The slightest crack will cause the display to go black for ever and ever. Send a ticket to Evolv at this link: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  9. What esoteric coils are we talking about for heating e-liquid?
  10. How did you obtain the 0.37 ohms reading?
  11. Each board and functionality of them is due to the design of the board and firmware/software. Any valid points you might have can always be mentioned to Evolv at https://helpdesk.evolvapor.com/index.php?a=add&category=5
  12. All the components are placed on the board by a pick-and-place machine and are not hand soldered.... as I understand it.... I have, over the past 9 years, noticed that the Evolv folks are pretty straight shooters. 😊
  13. At first glance there are many words in the English version that are not translated to English and some English words are not spelled right... Will look deeper as I have time...
  14. In EScribe Device Monitor, when you connect the device it will update the time/date.... Quickly changing batteries will keep time/date. These are the options other than manually setting after device is without batteries too long...
  15. Make sure you have a good Usb data cable to use... charge only usb cables don't transfer any data....
  16. hum, maybe the fire button is stopped working... try a hard reboot..... start a ticket with Evolv https://helpdesk.evolvapor.com/index.php?a=add&category=1
  17. You can start a ticket with Evolv and see if they want to answer your question.... we do not work for Evolv...... https://helpdesk.evolvapor.com/index.php?a=add&category=1
  18. The DNA technology is designed as a personal vaporizer. TC regulates temperature for the vaporization process of a liquid to a desired temperature. Your intended use is not the intended use of a DNA.
  19. Is it Locked? 5-clicks to unlock.....
  20. This is an Evolv e-cig/e-liquid forum... you might go to an herb forum for help....
  21. What do you mean by dry coil?
  22. Yep, there are many, many themes to choose from....... pitch till ya' win......
  23. What do you you get by doing this? Tools>Apply Service Pack
  24. I would be very leery installing such an old version of EScribe or older firmware updates.... especially on my main computer.... 🤔
  25. hum.... if I recall, Vapor Shark had their DNA 200 boards specifically made for the Shark from Evolv and they used their own charger board.... never bought one just for that reason.... all of the beta versions of the 200 I tested for Evolv (before they released the 200) are still working perfectly to this day..... but at any rate, whether of not the 200 had a 5 watt increment in the past it does not have it now.... as you know Evolv constantly improved the boards and the EScribe software over Evolv's history....
