  1. Well, ya got 2 choices. Escribe - Tools - USB Recovery charge (but you'd have to do this numerous times, and look if the cells will come up in V) or an external charger. However, depending on how long they've been that low (1 and 2), there could be bad internal battery damage. Just replace with another battery. Any idea why this happened (shelved and unused for a while)? Edit - Added this -> If it were mine, I'd just replace the battery
  2. Is that a Lipo? If so, the cells are highly imbalanced.
  3. Many squonking/BF 510's have an adjustable 510 pin to ensure a solid connection.
  4. The 75's never had the same battery smarts as the other boards like the 200 series.
  5. In escribe do this Options -> User Interface -> Advanced so the 'Mod tab' shows for Atomizer Analyzer and battery changes Change # of cells from 3 to 2. Your mod should now work. You've lost any logos, setting setup, and any values that might have been setup by them.
  6. I've seen some of his where they were named like soft, medium, hard, no preheat, etc. If you liked/used those (which are still perfectly fine), then with your red text, you end up choosing the type of profile and change material only. OR You set up specific profiles based on material/wire, and use that for a complete setup. Personally, I use a combination of each on a mod where it's painful to get escribe access.
  7. Rasta, there are 2 different ways. Your RED text above allows you to change materials 'on the fly' and follow the preheat, punch, time, watts set for it right now. Used if you want a soft, medium, hard type settings. To change to a new profile completely (like your 316 profile); hold up and down button at the same time till screen displays message quick double click either button (displays current profile name) click either up or down button to change to next complete profile click fire button once you reach the profile you want hold up and down button at the same time till screen displays message If you followed your red text that can happen.
  8. Seeing as how @James gave you a method, here's a touch more detail. Steam-engine, wire wizard. Use material of your choice, click equivalents, put in desired temp of your test. In new material type, use the same wire profile, it will show the resistance required for that temp. If I'm wrong hopefully someone else will chime in.
  9. How did you 'measure' this? Seems pretty high, but each mod can be different. Kanthal should be pretty much rock solid steady. I'd check all the connections are tight.
  10. There you go, right in Post 1.
  11. I haven't needed or seen one. If a search yielded no results you can officially ask here; EVOLV HELP DESK
  12. You oughta open a ticket with Evolv and send 'em a Device Monitor showing that. Anytime I've seen that, it's a blown battery chip on the board.
  13. Round cells or Lipo? What are the individual cell voltages?
  14. Good to hear you found the issue. I merely copy/pasted retird's request. Thanks are always appreciated, warranted or not. Cheers, good luck with your new JST.
  15. Rasta, overall that looks good. Couple comments. The only ways I can see you getting lava is if it's firing 100 watts straight (non TC) OR the wrong wire profile. If you don't plan on using Nickel or Titanium in the near future, go into profiles and change them to SS. Then go to Material tab, right window, select, then remove from mod. Preheat should be greater than the Power number. Yours show both at 100w. 100watts, is clearly too much to maintain the watts required, so you can drop the Power to 50w, leaving preheat at 100 if you wish (if you liked that ramp up) You can tweak any of those 5 values to your desire. Note that even though we said 100w, your temp was ~150c. Always remember to upload settings to Device after you make changes in escribe Under File -> Save As you can save a backup of all your settings.
  16. As far as wire, pretty much your standard TC wires. SS316L, 430, SS Notch coils, Ni200, Ti01. Both spaced and contact. Used to be dual coils, round or claptons. Now only dedicated single coil atty's. My Kayfun 5 has a single 24 or 26/36 clapton requires about 35 watts to maintain temp. Most of the others are 2x28/40 SS fused, trying to hit .25-.45 ohms. Spaced or contact depends on the build deck. Glad to hear it's working for you. If you want a quicker or slower ramp up, watch that red line in Device Monitor. and adjust those preheat, punch, time.
  17. Yo Rasta, I wrote you a book over there.
  18. Quickly read that DW, looks like a solid option. I have stayed at Windows 7 on a VM.
  19. Or ya can send me a printscreen of profile 2, and device monitor when you're all set to fire.
  20. Check your watts material in the right hand window. Make sure 'temperature sensing' is not selected below it, just above the graph. Set a profile, I usually set Profile 1 back to your watts material Go to Profile 2. Put Power at 100 watts, temp of your choice (150C) is fine. Click on temperature dominant. Do not lock resistance. Leave the other defaults for now alone. Near top of screen -> Upload settings to device (always gotta do this) Atty should be at room temperature, wicked and ready to go. Device Monitor. Bottom left side should say Normal or charging. Over to the right it should say Profile. Click on that, change it to Profile 2 Put mod down on table. Device Monitor, far right, see Puffs, click and set to 3 seconds. Your mod will fire, and no lava for you. Post printscreen like the second one you did before.
  21. On your 'material' tab, left side, see the one called 'watts', click to highlight, then that right arrow -> in between the two windows to put it back on your mod. You should still have SS316 in the right window. If not, do the same thing as before for 'watts'
  22. If you don't connect a wire capable of TC, it will fire at the wattage selected. If you do connect a wire capable of TC, it will fire using the material profile selected, in the screenshot 'ni200'. So you're vaping kanthal @ 37.4watts. If you're gonna keep changing things/resetting things I'm not asking you to do, I'll go cut the lawn.
  23. For not understanding, you done great. Can you do a Printscreen of 'Profile 1', please. And tell me what kind of batteries you're using? At a bare minimum, on the 'mod' tab, double the value for Wh's.
  24. Escribe - Material tab. Highlight the wire you chose on the right hand side. Look down at graph/line. Tell me what values do you see at the highest setting? Follow my instructions here and do a Printscreen exactly like he did.
  25. The latest firmware and escribe is found here: Go to the 'material' tab to see what wire types are available, and on your mod. Your RED comment works in newer versions. Latest tells us nothing, but you can see it in the bottom right hand corner of Device Monitor.
