Escribe - Material tab. Highlight the wire you chose on the right hand side. Look down at graph/line. Tell me what values do you see at the highest setting? Follow my instructions here and do a Printscreen exactly like he did.
The latest firmware and escribe is found here: Go to the 'material' tab to see what wire types are available, and on your mod. Your RED comment works in newer versions. Latest tells us nothing, but you can see it in the bottom right hand corner of Device Monitor.
Happy you got it sorted. Now everything connects again?
For 2 battery operation, the last time I checked, the Triade didn't come with a separate battery door. Yes, you can turn the battery icon display off. Theme tab in escribe. For an accurate battery icon you'd need 2 sets of the same battery, and set the battery parameters in the mod tab. I'd suggest you're best option is anything on the Mooch approved list. Solid review by Zophie, and you should follow her advice about djlsb vapes, and watch his escribe videos before configuring.
Now I'll just ramble for a bit. I don't know if you're concerned you're getting close to the 600F mark. IMHO it's just an artificial safety constraint set by Evolv. I mainly vape in the 390-440F range. Just the heat in my lungs. Is that a single 24/36 or more for your 2 coils? I was gonna run your build in steam-engine for an idea of your heat flux. TC is core wire/material dependant only. Not gauge, wraps, or diameter. It's all about the TCR/TFR. Simplest explanation for TC .... You're now vaping at a set resistance.
Yeah, perfect. Notice that green line shows it's about 55 watts to maintain that beautiful solid 500F. That number (55 watts) will change if you do a real not simulated puff. Can you do a real one, this time increase the temp to 550F, upload to mod. Another printscreen, just like this. OR, if you just like that 85 watts but with the benefit of TC (dry hit protection) and really want that 85 watts, there's 1 last/more thing.
Sweet, so now if your're in TC, fire up Device Monitor, and with the following clicked on the left hand side (while firing). You should notice your initial preheat spike, then the wattage required to maintain your 500F. If you post a printscreen of the entire screen while firing, I'll see what it'll take to get your watts up.
There is no "Off" key sequence. Just remove the batteries. I don't have the mod connected to USB while doing this. If you want, you can lock it beforehand (I don't). Perhaps, but I wouldn't even try. Sure, but you'll never have a truly accurate 'battery icon' if you setup your batteries. The mod will work fine with either set, just not the icon.
Looks fine. Whatever floats your boat. You really have to throw it on a mod to see how it really looks. Any non color, escribe capable mod, in any field you can reach easily. The problem with Italics is I'd really need to edit pixels to make sure they're either on/off and add a few here and there to remove jagginess. Out of what I posted, I'm leaning to my very 1st but squaring the edges, and the inner curves, like inside the B, E, and O. For my Secondary screen, it's always just my name in Wingdings font. Buncha cool symbols.
VapeCige Vtbox250 won't charge after battery analyzer
Wayneo replied to Dindonio's topic in Batteries and Charging
What version of escribe are you running? -
You're welcome. Enjoy your mod.
- 4 replies
- 1
- therion
- therion bf
- (and 4 more)
Hmmmm, I don't see the 75C listed under 'New Settings'. You need escribe V2.x. What version are you running?
- 4 replies
- 1
- therion
- therion bf
- (and 4 more)
Absolutely, if your 'mod resistance' has been correctly set.
The correct internal resistance for DNA 75c
Wayneo replied to Smokin Dave's topic in DNA 75 Color and 100 Color
Hey Dave, I guess you validated that number yourself for your mods to publish those values? I believe large manufacturer's take a sample size and program that value for all their mods, at best. Out of ALL my DNA's with a non zero populated, they've ALL been changed after running Case Analyzer myself. 5 minutes to do it from start to finish.- 1 reply
- 1
I cannot confirm or deny, but I'd take the RDA off, clean out the 510 area including the threading of the mod with IPO, threading on the RDA, tighten all 'build' screws as well as the + pin of the RDA. I highly doubt this is battery related.
It's right there in the signature line in the post above yours. I'd suggest 1.2 SP3, if you must. If you're gonna do this, beforehand I'd remove all USB drivers, identified as 'Dimension Engineering'
Reading ohms too high therion bf 75c dna
Wayneo replied to Scott111's topic in DNA 75 Color and 100 Color
And what's the coil wire type? -
dna 250 My first DNA mod, looking for simple mod and related advice.
Wayneo replied to µDavid's topic in DNA 200 and 250
I have 2 leather mods. A lost vape efusion duo, and a Triade. Every couple months, I'll use some waterproof boot/shoe protector on them. They're now both a year old, and have aged like a well worn leather jacket. They have a warmth in my hand or when resting against my leg. Still very happy with both. I'm a round button kinda guy, but the Evolv reference are square so I don't have one. -
What makes you think this? Don't know if I'd even suggest you check your build, cuz steam-engine closely agrees with your mod also
