Sure do, YES! Whenever you wanna drop by my place in Canada I'll be ready.
Completely disable New/old coil message (no tc profile)?
Wayneo replied to Phillis's topic in DNA 75 Color and 100 Color
I could swear I've seen this asked and answered before for the 'C' board, and IIRC it was always theme related. You have a few options .... interrogate the theme yourself, send a message to the theme designer, wait for someone who's more familiar on where to look, or use the search function here. Unfortunately I don't own a 'C' board.- 4 replies
- temp control
- new coil
(and 1 more)
Tagged with:
Your batteries could've run out of juice. Charge 'em up till you get to a PC and look at Device Monitor. You running the 18650's or Lipo?
And you used the thick ground pad right beside your positive from the 510?
RAW ohms live it would range from 0.386 - 0.405. <<-- Yeah, AA will fire 1 watt intermittently, and that's where you might be seeing that jump.
I don't think so. Your second 'firing' in the last printscreen already showed 2.68v with a dip even lower. Usually, or in my case, at that wattage on a single battery DNA75, not color, I've seen around .6-.8 voltage drop, all depending (like retird) said on battery and connections. I don't think the mod is too advanced for you at all. Especially not in wattage mode. By 'advanced' it has actually helped you/us to identify where the problem may lie, instead of just being blind. Please keep us informed with your dealings with them.
How high is it? Have you checked in AA on another DNA mod? or tried a different rda? Check your grounding, and solder joints.
Did you ask Boxer if this was normal for their mods? That Black line shows your battery is sagging from ~3.7v to your 2.5v CSC, and the internal temp has risen 100F. Volts are way better than %'s to diagnose issues.
Putting DNA 250 chip into Hugo Vapor Boxer Mod
Wayneo replied to Toffi69's topic in Installation and Assembly
@Toffi69 I'd download the dna datasheet, and the back pages are the board measurements/details. I'd measure the actuator placements first and screen dimensions to get an idea of what you could be getting into -
Do you already own the Hugo Boxer Mod? -
Not me, my man, but I'll take it for pointing you in the right direction. Go 'like' TheSwain's post so others can see you agree. As far as mod resistance you might wanna search around here. I don't own one, they can all be different, and now that you've removed that loctite .......... well?
2x Samsung Q30 .CSV needed for Therion 75C
Wayneo replied to bubblespot29's topic in Batteries and Charging
@PepeSilvia Easy answer ...... Yes to everything. It's a simple 2 column csv showing Battery Charge %, and the voltage. Only affecting the display gauge. Depending on your vaping characteristics you'll get different usage results in real life. In general, you'll get better results with a serial board- 4 replies
- 1
- therion75c
- .csv
(and 1 more)
Tagged with:
You can use that one- 4 replies
- 1
- therion75c
- .csv
(and 1 more)
Tagged with:
Kanthal is good ole watts usage. So whatever the ratings on the coil. There are also 0.4Ω SS316L (Stainless Steel Coil for Temperature Control) Enjoy your mod
- 1 reply
- lavabox
- new to vaping
(and 1 more)
Tagged with:
Here's a great post written by an Evolv tech
You can create or load your own battery curve which only affects the gauge display in combination with Watt hours input. Cell soft cutoff for message when you're hitting that 'lower' limit. Soft being the keyword which is the big momentary dip when you first hit the fire button.
General/Power: Kanthal power limit <- 'Your' manual limiting of max watts. Preheat power <- TC only Preheat punch <- TC only There are some good youtube escribe tutorials by pbusardo and djlsb vapes.
- 1 reply
- 1
It's not a regular 510 connector like you'd imagine. I have seen conversions done with a FatDaddy :ow profile, which IIRC had an 11mm depth. I saved this post from long ago, as it's the same enclosure. https://www.e-cigarette-forum.com/threads/replacing-the-510-in-an-rx200-fairly-easy-actually.727725/
Request for any 250 file or factory, needed desperatly
Wayneo replied to vern's topic in EScribe, Software and Firmware
Those are all the standard Evolv defaults, and any 3 battery mod will work fine using them straight out of the box. Battery - You can create or load your own battery curve which only affects the gauge display in combination with Watt hours input. Cell soft cutoff for message when you're hitting that 'lower' limit. Case thermals - Mainly for TC usage, but also useful for when your batteries are getting old and heating up. Mod resistance - Mainly for the most accurate coil resistance readings, especially for TC usage. -
DNA75C Paranormal battery cells not shown
Wayneo replied to klein's topic in DNA 75 Color and 100 Color
Unfortunately no, they're parallel. And IIRC in the datasheet advertised as integrated charging, and neither balance or balanced is in the entire document. Welcome -
The 75's batteries are all in a parallel configuration so presented to the board/chip as 1 cell, whether it's one or more cells. -
For a completely clean file, on the front page when you start escribe it's right there as 'Evolv dna 250'. -
Dead paranormal. Thank God I recovered it though.
Wayneo replied to Aalmosawi's topic in EScribe, Software and Firmware
Search works, and there are many sharp experienced users here. IMHO, public is better cuz if any of us are wrong someone will catch it quickly. Welcome
