You need to use the 'Theme Designer', find the screen where it is, then the field you want to remove. Delete the 'field', save and upload to your mod.
Hey, I NEVER said this, but I do agree with it. And I NEVER said this That photo of Stainless Steel is not a simple single wire, and it will require more watts than one strand of 26 gauge Stainless. Straight watts. Single coil. 24 or 26 awg wire (material). ⬆ DO NOT DO THIS! ⬆ Straight watts. Single coil. 24 or 26 awg wire (material).
Canada, so plain generic English. Straight watts. Single coil. 24 or 26 awg wire (material).
You have made MANY WRONG assumptions and choices. Titanium resistance DOES AND SHOULD increase when power is applied. 28 watts for those high mass SS claptons were a poor choice in your very first post You still need a basic understanding of what you are doing. Temperature control is an advanced topic and you should learn to vape in straight watts with a simple single wire first. Kanthal or Nichrome or Stainless steel. Then move on to Replay with your Stainless steel. Straight watts - Use your single coil atomiser. just increase or decrease watts until you get a good flavorful vape. One of your profiles should be called watts or kanthal or power. If you look at that profile in escribe the material should not say stainless steel or Titanium anywhere. No replay. Nothing. The basic concepts how these mods work have never changed. You might find an old Russian video. Good luck.
Is that your only mod? STOP pressing that button constantly. You only need to check the resistance of your build once, with your mod and atomizer both at ambient (room) temperature. That big red X picture shows you issued a reboot command that worked. Look at the top line, it shows rebooted.WHY did you do that?
Your video did not work. So I do not know anything new. If you are only clicking the center 'select' button to re-measure the ohms I do not think it is normal because that is done at very low watts. If you are using the 'fire' button, it could be normal. WHY ARE YOU CONTINUALLY CHECKING THE RESISTANCE? English is my only language. 🙂 English : I have a question why I can't reload the mod partially or completely through the program? It gives an error that it is impossible to type errors What are you trying to reload, and why? And what error?
Shouldn't matter with N80, but I'd do it before. Let us know if the ohms fluctuates, and how much. Did this always happen, since new?
I do not understand the bolded text, but it is normal for Titanium 1 to increase the resistance more than that while in use. That coil only raised in temperature to ~90°C which is still below the boiling point of water. And yes, it should decrease. There should already be a profile for Titanium 1 on your mod. You can use that. I do not understand this at all. It might be easier if you write in Russian, and I will use a translator.
I am only reading the answer to the question I asked. I knew your answer before you replied. Your answer was this. My very first comment to you from back in August is still valid "That's a lot of mass you're trying to heat at only 31 watts" And why anyone would fuse 2 already fused claptons of dissimilar metals is beyond me. Your coil, I believe has hotspots in one of those 2 fused claptons which were probably not dry burned beforehand. Your 2nd puff, the res increased to .144, and your 3rd puff to only .122. See the flat red line on all 3 puffs, yeah, wasting time trying to heat the coil. But finally the temp rises to ~118°C on both your puffs. That's 244°F, and barely above the boiling point of water. Yes Replay and TC will work with mixed metals. I just use all SS as the core wire, with a nichrome 40g wrap.
As far as the screen being flipped/upside down, hopefully you've both verified that's not been set on the mod. Escribe -> Mod -> Mechanical. Last option 'screen is flipped'. No idea about the lines. Replacement Screens are ~$12 and available all over the world.
Under the Help menu item, the bottom option is backups. You can restore to a time before you made the change. Then you should go under File and save the entire configuration as your default, that you can always use to restore.
Good to hear!
under the Help menu item, the bottom option is backups. You can restore to a time before this was happening.
I have NEVER seen that from just applying a theme. (.ecigtheme) file extension You could be fine with a 'disconnect', then a 'connect and download settings', then apply the theme
Did you personally ever see that logo on your mod? Yes, it's normal. That factory reset (you mean restore defaults?) could have wiped it out
With yesterdays forum update, if you go to Recently used devices, there's now a toggle to keep you logged in. I'm going on more than 12 hours, no logout. Using Chrome browser btw. Tab open while using other tabs, closing tab and coming back later, still not logged out. A happy day is here. Oh yeah, better desktop emoji's to match the mobile. 🙂
You should only need the Mac version of escribe to install the theme, but nothing extra to download any file, from anywhere. Can you post a screenshot of that error. (Command+shift+4) all at the same time, then use the crosshairs to highlight the error. P.S. I actually have the latest Air.
200 or 250 NOT COLOR, yes 3S and they both have balance charging. There are also the datasheets for both of those.
A 4S Lipo battery will work with the 250C Yes, you can charge internally as the board supports balanced charging Here's the link for the datasheet. https://downloads.evolvapor.com/dna250color.pdf
That depends on the theme that is on your mod, so that's 'Theme' -> 'Theme Designer' -> 'Indicator Light'
Using escribe on your PC, For the MOD tab to appear - Options (menu bar) -> User Interface -> Manufacturer Then choose 'Battery' Save your battery file from your mod to your computer. Lower the 100% value to 4.18, then 'upload settings to mod'. OR, you can edit that 100% right there, then 'upload settings to mod'
Complete Noob. No new User Guide? Questions Inside.
Wayneo replied to GloriousBeardGuy's topic in DNA 250 Color
You are correct. There is no new user guide but one suggestion is to go watch a couple youtube videos on the DNA board/mod. DJLSSBvapes has quite a few, or a technical reviewer. You will get a better basic understanding. Questions #1 and #3 are both theme specific, you need to read the 'about this file' section for that file, and IIRC he used the trem 'throttling' instead of the official 'temp protect'. OR, you could just comment in that theme and get a direct reply from the author. Back to question #1. Yes, one could/would be the preheat watts. Question #3, check all your connections are solid, and the stability of your build using 'Atomizer Analyzer' for that coil, in escribe.
