Moving Replay Buttons DNA 75C INT
Wayneo replied to Chef Ginger Pants's topic in Themes and Custom Screens
Secondary click on trackpad. 2 finger tap/click. -
I'm a Mac user and converted it to Windoze for you -
Sure, why not. Select field. Right click field (should show copy control) Go to screen where you want it Right click (should show paste control) It'll show up in the right hand, checkerbox screen, with all prior conditions brought with it -
Escribe Evolv seems dumbed down compared to Arctic Fox, she said
Wayneo replied to Tmease's topic in Modders' Forum
I believe she's mistaken about using (TC and power curves) at the same time with AF ( @joeblowma can you correct or validate me here, please) While we loosely use the term TC, I don't ever remember in any datasheet seeing it. It's actually Temperature Protection, a temp high limit. TP/TC and Replay will always work best with a spaced coil of all the same material. Or the cores at least. it's easier to see/work out hot spots. Different materials heat/cool at different rates. Great suggestion! Esoteric coils (multi metals for 'staged' heating') is a pipe dream for TC, and just best used in Watts, maybe Replay (too many if's to write) BTW she CAN disable punch/preheat immediately after taking a hit WITH 1 PRESS OF AN ICON. I'm a bit surprised comrade @zark didn't mention that. To be fair to her, at one time, I wanted that level of control, or at least being able to set (TC) preheat power as a % of set power, but have come to realize I can easily control enough with the Punch setting. -
@SamIAm Thank you for a solid PSA (Personal Service Announcement). Welcome to the forum, and I hope you're enjoying your mod(s) A quick question, so you now have 3 that work, or you returned the first 2? Quoting Sam "Try that before you return it."
Is this your first DNA Color mod? Can you post a printscreen of 'Atomizer Analyzer' also a printscreen of escribe with the profile you're using. And a third printscreen of 'Device Monitor' while firing, with cold ohms and live ohms checked. Was that a simple single wire? Each/every time you changed the atty, did you measure the Ω before firing the coil?
Are you sure it’s nichrome? Looking at your diagnostics picture I can’t believe I’m seeing any value for temp. Yours shows 232C.
Sounds like you have a bad connection somewhere. If you use atomizer analyzer in escribe it will show that. The ohms should be steady with very little fluctuation. Like maybe 1 or 2 milliohms. Put another atty or coil, ideally simple single coil and see if that’s steady. If it’s not you need to look at your mod build connections (grounding and 510) all 4 of them 👍
What material is that coil? Go to that 'atomizer' screen, measure coil ohms.
Looks great 🤩 and helluva risk you took that worked. Kudos to you. 🙌
The entire premise of this thread is false. ❌ Who on earth ever heard of a "LiPo mech mod" being built with a highly sophisticated, variable wattage, regulator board? 🤔 🤪 She can solder, SHE'S A KEEPER! 🤩 Take her mod, and buy her a new enclosure and board of her choice. 🎉 She can solder, SHE'S A KEEPER! 🤩 Or slap that black and white ArcticFox theme on it and call it a day. 🗑 She can solder, SHE'S A KEEPER! 👍 You can let her know this board can fire the lowest ohm coil she can build. 🧨 -
Therion 166W doesnt work on windows 10 anymore?
Wayneo replied to JohnnyBigodes's topic in DNA 200 and 250
Those are the EXACT same links that are posted for the 250C board! Glad that you got your mod sorted out. -
If that were me, I'd reach out to VA and ask them directly. They do claim 'Hand-polished finish' OR because it's not DNA specific, look for a forum/group with more active modders
Huh? Can you provide a link for that, please. -
Open a ticket with the 'Help Desk', give them the details. Link in my sig.
Did you actually check that the ribbon cable is pushed into the connector straight and far enough? Did you hear that definite click when you closed the connector?
new to dna mod , couple of questions please
Wayneo replied to leea12345's topic in DNA 75 Color and 100 Color
Preheat applies extra power until the heating coil is up to operating temperature to shorten the delay between pressing the fire button and generating vapor. Because preheat is temperature based, it will not overheat or burn the vapor. The Preheat settings can be adjusted from the device. That #1 is the Punch setting - Scale 1-11, which is how close to your Set Temp before ending the Preheat settings Yes Similar to Preheat for TC vaping http://www.steam-engine.org/wirewiz# DJLSB Vapes has some good YouTube tutorials on the DNA Color chip. I highly suggest you watch at least one before you start changing things Welcome -
It's good to leave the defaults set by the manufacturer until you understand what/why you're changing them. Those 'Advanced' settings allow you to (tailor/be more specific) the battery specs you actually have, for the mod. And other things. The closer you are to .2, the more watts you can use. Boost will briefly give you more watts than you have set to get the coil heat up quicker. The closer to 11, the more watts will be used. Using 'Device Monitor' you can enable/disable and view how your mod is operating. Battery in your case. DJLSB Vapes has some good YouTube tutorials (I don't regularly keep up with ANY youtuber and definitely not user comments)
Website escribe download software not working
Wayneo replied to EDMKEV's topic in EScribe, Software and Firmware
We've seen where on a Windows machine, you might need to try a different USB2 port and plugged directly into the PC. -
What are the individual cell voltages? And the USB voltage when looked at in Device Monitor? -
You're only get 2A charging while using an external block and a high quality cable. The closer the battery is to full, the charge rate will go lower. -
Sure, it should install. I do believe that has worked for me in the past. What are you trying to update, the firmware on your mod or escribe itself on your PC? -
Just tested for SP19 and NOT working either. I have sent messages to Evolv. -
Welcome @Pino74 The GO chip in your mod offers 'Replay' which has the benefits of TC such as dry hit prevention. You MUST use a TC capable material/wire such as Ni200, Ti01, SSxxx, NiFexx (or others) in order to activate 'Replay'. So yes, your NiFe48 material/wire should work. That GO board works best in the .2-.4Ω range.
Welcome @milly89 Hope you will contribute. This is a DNA focused forum on vaping nicotine with all Evolv products.
