  1. Sorry man, not an Evolv board in there. You should seek advice elsewhere. Don't they have a product forum?
  2. Yes. Enjoy your mod.
  3. NiFexx has been used for vaping for many years. I use it occasionally, but I'm not going to say what's safe for anyone other than me. The GO board will allow Replay with pretty much any TC capable material/wire. Or it'll work like any other mod in straight watts.
  4. You can open an official Help Desk ticket here and they will guide you: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  5. By now you'll see It's nothing more than a slightly and hastily warmed over copy of the djlsb theme with Replay (IF the djlsb version didn't have Replay) Start escribe. File -> Open that .ecig file Theme tab -> open/change/look at/save theme (after deleting 1 wallpaper) You'll see nothing but theme
  6. Loaded easily on my 75C. That is clearly a V1 theme in the .ecig file. But if you like it .............. whatever. Just go delete wallpaper #3 which is not even used and it will load, or any one of the wallpaper screens. At least it's not hideous
  7. In the ecigstats app check that the 'link to account' and 'options' are setup properly. Plug into the machine that has the ecigstats app more often (its icon should appear) Download your data from the ecigstats web page
  8. Escribe 'Help' -> 'Backups' and choose one from before hitting that Default option
  9. Great to hear.
  10. Buying from a reputable supplier for those batteries is best. Here's a Mooch link for batteries and suppliers. https://bit.ly/3busyvf Had it been sitting for a while, or did something happen just prior to it just no longer working? Welcome
  11. Is that mod actually a regular black and white screen with 3 batteries, or an internal Lipo battery? You posted in the 'color' section, but I can move it if necessary. For starters the cells look low, too low to work, but when you plugged in the cable, did the screen light up? If you look at the very bottom line where it says Mode: Normal, over to the right it will show/detect button presses. Over and on the left it shows the watts set at at 80.30, so if you press the up/down button, that value should increment/decrement
  12. @pleasedeleteme We are not Evolv employees. Direct your request to the link posted below. https://helpdesk.evolvapor.com/?a=add
  13. @pleasedeleteme It took more time for you change your username, upload a new picture, quote me and then write that request than it would to unfollow the thread and sign on at your leisure. Just don't sign on any longer if you wish. * We're all under much stress during this pandemic and if people can at least talk/help someone about a somewhat relevant topic instead of staring at the walls, it's a good thing
  14. @craw We moderators see ALL postings. We're just chilled If it's bothering you, you can just unfollow this thread. Then you won't get any more email updates.
  15. DJLSB vapes has put out some good videos on Reply, TC, escribe, etc. for mods with these boards. From back in 2017 I said "... I'll usually vape a new juice in Wattage mode before moving to TC. I have a minty watermelon juice that in TC I totally lose the mint at 420F. And a peanut butter vape, where at certain temps the peanuts will taste burnt, not the whole juice, just the peanuts. But overall, TC will give you a consistent experience and no dry hits." In other words, a linear/singular taste. Now (or during the birth of Replay), the brain trust at Evolv said this "As for flavor, different flavor molecules boil and are primarily tasted at different temperatures. .... Temperature control, by contrast, tends to taste 'muted', because the vast majority of the puff is at a fixed, instead of changing, temperature" pretty much validating my experiences. Enjoy your mod
  16. That's all correct. Replay gives you the 'dry hit' protection of TC, without the TC. Notice I never once mentioned a temp. But 'yes' you can also enable that in the SS profile, BUT WHY?
  17. You don't need to plug it in. Just go to that Replay profile. Ideally the material type says something like watt or kanthal. Don't change it. Adjust your watts to what you like,take a few puffs, 'select' the Replay option when you like the puff. Ideally it'll say something like enabled or playing. There should be a cancel or stop option somewhere. Unfortunately themes are like the Wild West and designers can make them however they please.
  18. Minimum Replay requirements DNA75C, 250C, or GO International software installed Theme that supports Replay Success best practices Ni200, Ti, SSxxx, NiFe or any TC capable material (wire) as your core wire There are 8 profile slots on every mod. 1 might be called Replay (if you're lucky). Start vaping in a profile that supports Replay. No material file required for straight Replay (as conceived by Evolv). If you don't understand something written, let us know.
  19. Here's a video showing how you can run and create your own. https://youtu.be/pNsAHmZ-E0o?t=0 All you need is an RDA , a couple loops of wire, a fan, and an hour of your time. There's no longer a Watt hour setting on color boards.
  20. I wouldn't say so. Those numbers are well within the mod limits. The numbers depend on many things including air-flow. IRL I have vaped an air Crown 3 at 125 watts and it wasn't hot at all. It's just what you prefer for that setup.
  21. That's really a personal preference thing. I'd say many are in the 380-480°F range. Welcome
  22. Minimum Replay requirements DNA75C, 250C, or GO International software installed Theme that supports Replay Success best practices Ni200, Ti, SSxxx, NiFe or any TC capable material (wire) as your core wire Start vaping in a profile that supports Replay.
  23. Sorry about that. I missed the 'and you said it wasn't you' part. Almost had madness and mayhem running rampant here I checked over there, April 13, 2016 (Sounds like a Friday). Moderator Edit: Juicy bits removed due to Rules 10 and 12 I'd put my hand up for abusive and aggressive (if they were children), but not the other two. OOPS, I think there's a rule about not quoting or posting PM's, and no bad mouthing moderators over there. If so, this message will self destruct.
  24. Who knew there was a 'Retired' and a 'retird' moderator over there. Man, years ago I got sent my first and only ever warning and my post removed by 'retired'. I even asked you once @retird if that was you. Moderator Edit: Juicy bits removed due to Rules 10 and 12 I still have that tank, pristine in its shrink-wrap if anyone wants a pic. (I was rebuilding those tiny Aspire BVC coils with SS) and didn't want to do other factory coils.
  25. If you start escribe without selecting a mod, you can choose to create a new one. The default theme there is the current default for each board type. I know there have been changes to the default over time. Some like the watt increment value has been mentioned in the release notes without fanfare. SP 15.1 was either from .1 to .5 or what you noticed IIRC
