- silver and  black versions are also available!
The following logo combinations are available:
BLACK: Evolv_or_SQ_switchable
SILVER: Evolv or (Salix (profile1) + SQ (profile234) + Evolv (profile5678)) _ switchable
SILVER: Evolv or (SQ (profile1234) + LVE (profile5678)) _ switchable
SILVER: Evolv or LVE_switchable
SILVER: Evolv or SQ_switchable
SILVER: LVE or SQ_switchable
- SCARLET PASSION: Evolv_or_LVE_switchable
Thanks to Tortuga for the fantastic background graphics!
The "K.I.S.S.-Mode ON" mode addresses inexperienced users and is very simple,
the "K.I.S.S.-Mode OFF" mode is aimed at experienced users who want full control over their mod ...
SILVER_Theme_Evolv_DNA_75C_250C.png BLACK_StattQualm_Theme_Evolv_DNA_75C_250C.png
(some screens may have changed)
wolke-101 hat hier einen sehr anschaulichen Beitrag zu den Unzulänglichkeiten des TC-Modus geschrieben - spannend.
PLEASE NOTE - REPLAY IS FOR COIL MATERIAL "Watts" PROVIDED, NOT FOR SPECIFIC WIRES!
What's New in Version 32.2 (SILVER)   See changelog
- "last-puff-power" wird (wieder) im Replay-Mode auf dem Mainscreen angezeigt
- kleine grafische Überarbeitungen
- "last-puff-power" is (again) displayed in replay mode on the main screen
- small graphic revisions
- Darstellungsfehler "New-Atomizer"-Screen im neuen SILVER-Theme behoben (nur deutsche Oberfläche)
- Display error "New Atomizer" screen fixed in the new SILVER theme (German surface only)
emir71
Report ·
Hallo erste mal,
Probier bitte nie neue Version aus - lohnt sich und scheint stabil
Share this review
