3_P_EVOLV_V7-Descrition.png+
See also my other Themes:
What's New in Version INT_2.0_SP20_BLACK_1   See changelog
INT_2.0_SP20 _BLACK_1:
- new Performance Screen (only K.I.S.S.-Mode OFF)
- new coil setup screen
V45: Final Version with Escribe INT 2.0 SP19
- changed, clean arrangement of the coil setup screen
- K.I.S.S.-OFF-Mode: New Atomizer Screen links to the coil setup screen instead of just confirming a new coil
V44:
- Adjustments to the date and time display
- subtle changes in the layout
- THERE ARE ONLY TWO THEMES NOW;
CALLED "SILVER" AND "BLACK"
- in both the logo can be changed on the lockscreen,
the basic setting is the Evolv logo
- alternatively the SQUAPE or StattQualm logo is displayed, but only in profiles 1 to 4 (in profiles 5 to 8 the Evolv logo is always displayed)
- THE "STATTQUALM" THEME IS UPDATED ONLY ON EXPRESS REQUEST (FEEDBACK)!
V41:
- BUGFIX IN THE CONFIGURATION OF LOCKSCREEN AND MAINSCREEN
- BUGFIX BATTERY WARNING LESS THAN 10%
(in this context, I would like to remind you how important feedback is ...)
- small menu and screen adjustments
  • With version INT_2.0_SP20_BLACK_1:
  • Download
  • Like 6
Thank you for this award 😊
  • Like 2
  • Thanks 3
Thunder Dick
emir71
Hallo erste mal,
Khaled Shehab
good job 👍
RogerMechMan
Hi!
Happy vaping!
mykl10
aMir S
Sami_mp
