3_P_EVOLV_V7-Descrition.png+
See also my other Themes:
What's New in Version 10/31/2021 05:35 PM   See changelog
- all versions: smallest detail corrections and changed 12/24 hour changeover
- "silver" version: corrected background
Veröffentlicht
After the theme has developed and grown for more than 2 years, I have now set it up from scratch with a slightly changed layout.
Some small weaknesses in detail could be remedied in this step.
As long as no problems are reported to me, as long as Evolv does not bring a new chipset with new possibilities (instead of fewer) onto the market, as long as I consider this development to have been successfully completed.
Veröffentlicht 12. Oktober
- Detailed work and bug fix in the temperature warning, this has been repositioned (even if it will hopefully never be seen by anyone)
- New layout of the battery screen, better adaptation to the number of cells used
V7xx2.8: REPLAY control no longer in accent color green, but follows the normal color scheme in the sense of better readability in a bright environment
(the old version 7xx2.7 with accent color remains available in the download area
  • With version 10/31/2021 05:35 PM:
  • Download
  • Like 6
Thank you for this award 😊
  • Like 2
  • Thanks 3
Thunder Dick
emir71
Hallo erste mal,
Khaled Shehab
good job 👍
RogerMechMan
Hi!
Happy vaping!
mykl10
aMir S
Sami_mp
