See also my other Themes:
What's New in Version 32.1 (SILVER) See changelog
- Darstellungsfehler "New-Atomizer"-Screen im neuen SILVER-Theme behoben (nur deutsche Oberfläche)
- Display error "New Atomizer" screen fixed in the new SILVER theme (German surface only)
BITTE BEACHTEN - REPLAY IST FÜR COIL-MATERIAL "Watts" VORGESEHEN, NICHT FÜR SPEZIFISCHE DRÄHTE!
With version 32.1 (SILVER):- Download
