3_P_EVOLV_V7-Descrition.png+
See also my other Themes:
What's New in Version 19   See changelog
- Version ohne branding hinzugefügt
- various optimizations around the date and battery indication
- rudimentary dialogue on the "New Atomizer" screen in K.I.S.S.-Mode
- Version without branding added
  • Like 6
Thank you for this award 😊
  • Like 2
  • Thanks 3
Thunder Dick
emir71
Hallo erste mal,
Khaled Shehab
good job 👍
RogerMechMan
Hi!
Happy vaping!
mykl10
aMir S
Sami_mp
