3_P_EVOLV_V7-Descrition.png+
See also my other Themes:
What's New in Version 09/29/2021 08:58 PM   See changelog
FUNCTIONAL CHANGES | FUNCTION EXTENSIONS
- basic mode: The functionality of the basic mode is strongly based on the stick theme; Material change, Ohmlock and the like are not available
- enhanced mode: full control over the mod, taking into account the specifications, REPLAY only with material selection "Watt" and, conversely, TC not with material "Watt".
In enhanced mode I decided to allow a subsequent correction of the output power in REPLAY mode - comparable to TC mode. I think this is more controllable than the "Warmth" function, for which I lack any documentation about the EXACT increase in output power.
In REPLAY mode, the power used is always displayed and can be influenced directly.
(IMPORTANT UPDATE: the actual innovation locked the mod in the previously published version due to an copy error on my part.)
In TC mode, instead of the temperature, I also show the power used on the first main screen, as I consider this to be more informative than a calculated temperature.
DESIGN CHANGES
Some errors within the color schemes have been fixed, the coloring of the highlighted toggles are now also adapted to the color schemes.
  • With version 09/29/2021 08:58 PM:
  • Download
  • Like 6
Thank you for this award 😊
  • Like 2
  • Thanks 3
Thunder Dick
emir71
Hallo erste mal,
Khaled Shehab
good job 👍
RogerMechMan
Hi!
Happy vaping!
mykl10
aMir S
Sami_mp
