3_P_EVOLV_V7-Descrition.png+
See also my other Themes:
What's New in Version INT_2.0_SP20_2-8   See changelog
Scarlet Passion: Bug "Out of space" fixed
INT_2.0_SP20 _2-8:
- Navigation changed; "Round Robin" only on exit down, from main screen exit up to lock the device
- "New Atomizer" screen can be left in K.I.S.S.-OFF mode without any changes
INT_2.0_SP20 _2-7:
- Scaling of the battery indicators changed
INT_2.0_SP20 _2-5:
INT_2.0_SP20 _2-2:
INT_2.0_SP20 _2-1:
BLACK:
BLACK / SILVER:
In the following standard topics, I have added a screen on which these dependencies can be observed well    PreHeat-Boost-Test.ecigtheme
Im folgenden Standardtheme habe ich einen Bildschirm hinzugefügt, auf welchem siche diese Abhängikeiten gut beobachten lassen PreHeat-Boost-Test.ecigtheme
INT_2.0_SP20 _2:
INT_2.0_SP20 _1:
- new coil setup screen
  • With version INT_2.0_SP20_2-8:
  • Download
  • Like 6
Thank you for this award 😊
  • Like 2
  • Thanks 3
Thunder Dick
emir71
Hallo erste mal,
Khaled Shehab
good job 👍
RogerMechMan
Hi!
Happy vaping!
mykl10
aMir S
Sami_mp
