HERE ARE THE CURRENT VERSIONS:
EVOLV - enhanced theme with elementary mode - Evolv
SQUAPE - enhanced theme with elementary mode - Squape
STATTQUALM - enhanced theme with elementary mode - StattQualm
SILVER - enhanced theme with elementary mode - EVOLV+LVE+Squape in one theme selectable
- silver and  black versions are also available!
The following logo combinations are available:
BLACK: Evolv_or_SQ_switchable
SILVER: Evolv or LVE_switchable
- SCARLET PASSION: Evolv_or_LVE_switchable
Thanks to Tortuga for the fantastic background graphics!
The "K.I.S.S.-Mode ON" mode addresses inexperienced users and is very simple,
the "K.I.S.S.-Mode OFF" mode is aimed at experienced users who want full control over their mod ...
DNA_75c-250c_enhanced_theme_replay_KISS-Mode_Evolv.png DNA_75c-250c_enhanced_theme_replay_KISS-Mode_StattQualm.pngDNA_75c-250c_enhanced_theme_replay_KISS-Mode_Silver.png
(some screens may have changed)
wolke-101 hat hier einen sehr anschaulichen Beitrag zu den Unzulänglichkeiten des TC-Modus geschrieben - spannend.
PLEASE NOTE - REPLAY IS FOR COIL MATERIAL "Watts" PROVIDED, NOT FOR SPECIFIC WIRES!
What's New in Version 28   See changelog
emir71
Report ·
Hallo erste mal,
Probier bitte nie neue Version aus - lohnt sich und scheint stabil
Share this review
