See also my other Themes:
	Edited  by CMK aka gwyar
What's New in Version INT_2.0_SP20_2-2 See changelog
							INT_2.0_SP20 _2-2:
INT_2.0_SP20 _2-1:
							BLACK:
							BLACK / SILVER:
In the following standard topics, I have added a screen on which these dependencies can be observed well PreHeat-Boost-Test.ecigtheme
Im folgenden Standardtheme habe ich einen Bildschirm hinzugefügt, auf welchem siche diese Abhängikeiten gut beobachten lassen PreHeat-Boost-Test.ecigtheme
INT_2.0_SP20 _2:
							INT_2.0_SP20 _1:
							- new coil setup screen
							V45: Final Version with Escribe INT 2.0 SP19
							- changed, clean arrangement of the coil setup screen
							- K.I.S.S.-OFF-Mode: New Atomizer Screen links to the coil setup screen instead of just confirming a new coil
 With version INT_2.0_SP20_2-2: With version INT_2.0_SP20_2-2:
- Download
- 10/14/2022 07:43 AM
												10/14/2022 07:43  AM
												10/09/2022 02:52  PM
												04/13/2022 06:53  AM
												11/05/2021 12:31  PM
												11/05/2021 12:27  PM
												10/31/2021 05:35  PM
												10/24/2021 12:48  AM
												10/23/2021 10:28  AM
												10/22/2021 08:34  PM
												10/12/2021 08:21  PM
												10/06/2021 03:03  AM
												10/01/2021 01:13  PM
												09/29/2021 11:02  PM
												09/29/2021 08:58  PM
												09/23/2021 07:16  PM
												09/23/2021 07:02  PM
												09/15/2021 11:46  PM
												09/14/2021 09:28  PM
												09/12/2021 10:38  PM
												09/12/2021 02:38  AM
												09/11/2021 11:23  AM
												V6.1
												V6.1
												V6.1
												V5.4.7
												V5.4.5
												V5.4.5
												V5.4.2
												V5.4
												V5.3
												V5.2
												V5.1.1
												V5.1.1
												V5.1
												5
												5
												4.3.6
												4.3.5
												4.3.2
												4.1
												4.1
												4.0.6
												4.0.5
												4.0.5
												4.0.5
												4.0.4
												4.0.3
												4.0.3
												2.9
												INT_2.0_SP20_2-8
												INT_2.0_SP20_2-8
												INT_2.0_SP20_2-8
												INT_2.0_SP20_2-8
												INT_2.0_SP20_2-7
												INT_2.0_SP20_2-5
												INT_2.0_SP20_2-5
												INT_2.0_SP20_2-5
												INT_2.0_SP20_2-5
												INT_2.0_SP20_2-2
												INT_2.0_SP20_2-1
												INT_2.0_SP20_2-1
												INT_2.0_SP20_2-1
												INT_2.0_SP20_2
												INT_2.0_SP20_2
												INT_2.0_SP20_1
												INT_2.0_SP20_1
												INT_2.0_SP20_1
												INT_2.0_SP20_1
												INT_2.0_SP20_BLACK_1
												INT_2.0_SP20)_BLACK_1
												FINAL Version INT 2.0 SP19
												45
												44
												44
												44
												44
												44
												43
												43
												42
												42
												42
												41
												41
												40
												39
												39
												39
												39
												39
												39
												39
												AUGUST 2019
												39
												39
												38
												38
												38
												38
												38
												38
												38
												37
												36-5
												36-5
												36-5
												36
												36
												36
												36
												36
												36
												36
												36
												35
												35
												34
												34
												33
												33
												33
												33
												33
												32.2 (SILVER)
												32.2 (SILVER)
												32.2 (SILVER)
												32.1 (SILVER)
												32.1 (SILVER)
												32
												32
												32
												32
												31
												31
												30
												29
												28
												28
												28
												28
												28
												27
												26
												26
												26
												26
												26
												26
												23
												23
												23
												22
												22
												22
												21
												21
												20
												19
												18
												17
												15
												15
												15
												15
												15
												15
												15
												14
												14
												14
												14
												14
												13
												13
												13
												13
												13
												13
												13
												13
												13
												12
												12
												12
												12
												12
												11
												11
												11
												11
												11
												10.7
												10.7
												10.7
												10.7
												10.7
												10.7
												10.6
												10.5
												final
												final
												8.1
												8.0.0
												5.5.2
												5.5.1
												5.5.1
												5.5.1
												5.5.1
												5.5
												5.5
												5.5
												5.5
												5.4.1
												5.4.1
												5.4.1
												5.4.1
												5.4
												5.3 INT
												5.2.3 INT
												5.2.2 INT
												5.2.1 INT
												5.2 INT
												5.1 INT
												5.1 INT
												5.0.21 INT
												5.0.1 INT
												5.0 INT
												4.9
												4.8
												4.7.9-BETA
												4.7.9-BETA
												4.7.8-BETA
												4.7.7-BETA
												4.7.6-BETA
												4.7
												4.7
												4.7
												4.7
												4.7
												4.7
												4.6
												4.6
												4.6
												4.5
												4.2.1
												4.2.0
												4.1.0
												4.0.0
