See also my other Themes:
What's New in Version INT_2.0_SP20_2-1 See changelog
INT_2.0_SP20 _2-1:
BLACK:
BLACK / SILVER:
INT_2.0_SP20 _2:
INT_2.0_SP20 _1:
- new coil setup screen
V45: Final Version with Escribe INT 2.0 SP19
- changed, clean arrangement of the coil setup screen
- K.I.S.S.-OFF-Mode: New Atomizer Screen links to the coil setup screen instead of just confirming a new coil
With version INT_2.0_SP20_2-1:
- Download
- 04/13/2022 06:58 AM
04/13/2022 06:53 AM
11/05/2021 12:31 PM
11/05/2021 12:27 PM
10/31/2021 05:35 PM
10/24/2021 12:48 AM
10/23/2021 10:28 AM
10/22/2021 08:34 PM
10/12/2021 08:21 PM
10/06/2021 03:03 AM
10/01/2021 01:13 PM
09/29/2021 11:02 PM
09/29/2021 08:58 PM
09/23/2021 07:16 PM
09/23/2021 07:02 PM
09/15/2021 11:46 PM
09/14/2021 09:28 PM
09/12/2021 10:38 PM
09/12/2021 02:38 AM
09/11/2021 11:23 AM
V6.1
V6.1
V6.1
V5.4.7
V5.4.5
V5.4.5
V5.4.2
V5.4
V5.3
V5.2
V5.1.1
V5.1.1
V5.1
5
5
4.3.6
4.3.5
4.3.2
4.1
4.1
4.0.6
4.0.5
4.0.5
4.0.5
4.0.4
4.0.3
4.0.3
2.9
INT_2.0_SP20_2-8
INT_2.0_SP20_2-8
INT_2.0_SP20_2-8
INT_2.0_SP20_2-8
INT_2.0_SP20_2-7
INT_2.0_SP20_2-5
INT_2.0_SP20_2-5
INT_2.0_SP20_2-5
INT_2.0_SP20_2-5
INT_2.0_SP20_2-2
INT_2.0_SP20_2-1
INT_2.0_SP20_2-1
INT_2.0_SP20_2-1
INT_2.0_SP20_2
INT_2.0_SP20_2
INT_2.0_SP20_1
INT_2.0_SP20_1
INT_2.0_SP20_1
INT_2.0_SP20_1
INT_2.0_SP20_BLACK_1
INT_2.0_SP20)_BLACK_1
FINAL Version INT 2.0 SP19
45
44
44
44
44
44
43
43
42
42
42
41
41
40
39
39
39
39
39
39
39
AUGUST 2019
39
39
38
38
38
38
38
38
38
37
36-5
36-5
36-5
36
36
36
36
36
36
36
36
35
35
34
34
33
33
33
33
33
32.2 (SILVER)
32.2 (SILVER)
32.2 (SILVER)
32.1 (SILVER)
32.1 (SILVER)
32
32
32
32
31
31
30
29
28
28
28
28
28
27
26
26
26
26
26
26
23
23
23
22
22
22
21
21
20
19
18
17
15
15
15
15
15
15
15
14
14
14
14
14
13
13
13
13
13
13
13
13
13
12
12
12
12
12
11
11
11
11
11
10.7
10.7
10.7
10.7
10.7
10.7
10.6
10.5
final
final
8.1
8.0.0
5.5.2
5.5.1
5.5.1
5.5.1
5.5.1
5.5
5.5
5.5
5.5
5.4.1
5.4.1
5.4.1
5.4.1
5.4
5.3 INT
5.2.3 INT
5.2.2 INT
5.2.1 INT
5.2 INT
5.1 INT
5.1 INT
5.0.21 INT
5.0.1 INT
5.0 INT
4.9
4.8
4.7.9-BETA
4.7.9-BETA
4.7.8-BETA
4.7.7-BETA
4.7.6-BETA
4.7
4.7
4.7
4.7
4.7
4.7
4.6
4.6
4.6
4.5
4.2.1
4.2.0
4.1.0
4.0.0
