3_P_EVOLV_V7-Descrition.png+
See also my other Themes:
What's New in Version 43   See changelog
V43:
- There are no longer two dark versions,
the new one is now called "BLACK":
By default, the Evolv logo is active.
Via a switch in the screen menu, the SQUAPE logo can be switched on; however, this only affects profiles 1 to 4
- SILVER theme: modifications on the main screen
in TC mode at "K.I.S.S.OFF" / "K.I.S.S. ON"
- The "StattQualm" -THEME IS DEVELOPED ONLY ON EXPRESS REQUEST (FEEDBACK)
V42:
- There are no longer two SILVER versions:
- again small graphical adjustments
V41:
- BUGFIX IN THE CONFIGURATION OF LOCKSCREEN AND MAINSCREEN
- BUGFIX BATTERY WARNING LESS THAN 10%
(in this context, I would like to remind you how important feedback is ...)
- small menu and screen adjustments
  • Like 4
 Share
Thank you for this award 😊
  • Thanks 2
Thunder Dick
emir71
Hallo erste mal,
aMir S
