   (7 reviews)
3_P_EVOLV_V7-Descrition.png+
See also my other Themes:
What's New in Version 32.1 (SILVER)   See changelog
- Darstellungsfehler "New-Atomizer"-Screen im neuen SILVER-Theme behoben
- Display error "New Atomizer" screen in the new SILVER theme fixed
  • Like 6
Thank you for this award 😊
  • Like 2
  • Thanks 3
Thunder Dick
emir71
Hallo erste mal,
Hi!
Happy vaping!
mykl10
aMir S
