   (7 reviews)
3_P_EVOLV_V7-Descrition.png+
See also my other Themes:
What's New in Version 13   See changelog
With  a toggle on the main screen you can switch between two levels - the well-known, extended level and the greatly reduced K.I.S.S. level, in which only the basic settings are available.
  • Like 6
Thank you for this award 😊
  • Like 2
  • Thanks 3
Thunder Dick
emir71
Hallo erste mal,
Hi!
Happy vaping!
mykl10
aMir S
