- SCARLET PASSION:
Thanks to Tortuga for the fantastic background graphics!
PLEASE NOTE:
- all protections against erroneous settings (eg Temp-Protect in power mode), as usual from my enhanced themes
-the functions for REPLAY are only enabled in power mode (material => Watt / as provided by Evolv) and only after activation if the coil is REPLAY-capable.
TO THE EXPERIENCED USERS:
See also my other Themes:
Disclaimer:
Haftungsausschluss:
Edited by gwyar
What's New in Version V5.3   See changelog
SUMMERTIME!
DISPLAY OF THE BOARD TEMPERATURE ON THE MAINSCREEN IN "ENHANCED MODE"
- Colored warning in case of excessive heating of the board on the main screen in "enhanced mode"
- direct locking of the device from the main screen in "basic mode"
- Fixed display error board temperature on battery screen for unit of measurement "Fahrenheit"
  • Like 2
emir71
Hallo erste mal,
Probier bitte nie neue Version aus - lohnt sich und scheint stabil
Thank you for this award 😊
  • Thanks 2
