Are you sure you are using the correct profile for TC? According to your original post that bottom value on your display should show 304 (profile 1), and the temp you set as the largest numbers(temp coil running), yet your Device Monitor shows you're using Profile 7
At a minimum, I hope you clicked on the notice showing the 2016-06-05 firmware upgrade. Welcome.
Fellow Mac non-color users. Does this happen if YOU set a 'Custom Screen' on individual Profiles? This still occurs using the latest beta Escribe 2 beta versions, both US and Intl. Keep an eye on the word Watts. All I'm doing is continually 'Upload to Device' and the image gets corrupted, but NOT on the device itself. This occurs on all profiles.
You might wanna to post this in the 'Theme Park' or ask to have it moved there. https://forum.evolvapor.com/files/category/6-dna-75-color-250-color/
So long as the core wire(s) are a TC material, and N80 or Kanthal is used as a wrap, it's always worked for me in TC. When people talk 'plain' or 'simple', everyone's definition is/can be different, it's just too vague. I'd imagine, if anyone were to see ~20% rise in resistance in straight watts your chances are good. Where I imagine an issue is when they then use multi metal coils, like a clapton with a parallel wire or two ... all heating and cooling at different rates so the change is not consistent. I own NO color mods, so can't offer anything better.
making theme Making advanced theme from ground up
Wayneo replied to Dragonraihan's topic in DNA 250 Color
DJLSB Vapes did a very good youtube tutorial on Theme Designer when the 75C first came out. -
OK, So WHEN is this NEW software for the 75C coming out?
Wayneo replied to Joe M.'s topic in DNA 75 Color and 100 Color
@Andy-d EASY my friend. Just hand that crying baby a spinner to calm that anxiety. Funny with all the feigned outrage and insistence no one has offered to sacrifice a virgin or stomp their feet! Here's some Popcorn while you wait .... big bags for some. 🍿🍿🍿🍿🍿🍿🍿🍿🍿🍿🍿🍿 -
Download the latest version of escribe from the 250C board page. Gotta use www not forum
- 9 replies
- 1
- usbproblem
- charging
(and 1 more)
Tagged with:
Hmmmm, I've never seen live ohms lower than cold ohms under normal conditions. All I can think is to re read the resistance of the cold coil in the proper mode. Using Ni or Ti with SS can be scorchingly hot
Are you locking the resistance of that coil? If so, unlock it. I can see it rising on the live ohms.
- 9 comments
@ModBox Did you have those numbers backwards? You never did say what atty you're using, but anyway, you might just try checking the 510 pin is tight as well.
Well this looks backwards ????? @retird, is this possible under normal conditions on these C boards?
Atty swirls just destroy me, so I debated between the Source and the modmaker. I'm using 3 of the modmaker and happy they're proud of the body. Solid 510. My poor Modcrate 510 sits .... and my Varitubes are just atty holders.
Which one's?
@AMDtrucking He's got about 4 of 'em.
Save Theme E-Scribe Mac Ver 2.0 SP13
Wayneo replied to steamer861's topic in EScribe, Software and Firmware
Works fine for me Steamer (loading and saving). Running MacOS 10.13.4 . Tested with and a 250C theme. -
Case Thermal characteristics does not require any atty at all attached to the mod. Just a known constant temp, and batteries like you mentioned. Mod resistance. Yes, TC wire, uncoiled. On your 22, any material you want to remove must first be removed from any profile using it.
- 48 replies
- jac vapour
- dna75
(and 1 more)
Tagged with:
New Paranormal DNA 166 - Screen not working at ALL
Wayneo replied to evlesoa's topic in Report a Bug
Cough, cell voltages, cough. -
@T.A.Nettles,V Always good to post it for others
Wayneo replied to David Campbell's topic in EScribe, Software and Firmware
@YetanotherSteve Hotay, there are 3 major classification types for escribe in the locked post here, called 'Early Firmware and EScribe Suite'. This contains software, and sometimes firmware for SOME board types. RECOMMENDED SERVICE PACK <- Pushed out by escribe to all users (auto updater) EARLY SERVICE PACK <- For early adopters. Like post Beta testing, but not fully vetted by the masses. OTHER SERVICE PACKS <- Older versions of the above, moved here for posterity Within each of those groupings, there are 2 more groupings. US version <- FDA compliant International <- Non FDA compliant, Where NEW features can be introduced AND Finally OS type. Windoze, MacOS, and Linux. Now, just for shits and giggles, I'll bring it all home. Your version of escribe is found under 'About escribe' Your firmware (mod) version can be seen down in the bottom right hand corner of 'Device Monitor'. Those folders you mention only contain prior FIRMWARE versions. -
You sound like you've read up on this, or done it (Thermals), but just to be sure ... start with your batteries 25-50% full, and an area with a somewhat stable known temperature. Are you sure it's being recognised as a TC wire? You could adjust your Preheat watts setting to 30 watts or higher, lower your power (watts) value to the max you'd vape it normally without nastiness (on this mod). Even if you set it to 75 preheat watts, preheat punch 11, and preheat time limit to 10 seconds (all ridiculously high), the mod will revert (drop) to the regular 'Settings', power value if it does not see a quick enough rise in resistance.
- 48 replies
- jac vapour
- dna75
(and 1 more)
Tagged with:
How to DISABLE charge when connected to laptop
Wayneo replied to mactavish's topic in Batteries and Charging
@VB In Escribe 2.0 SP12 on MAC - FYI, it's in the same place as you said. Device Monitor - Diagnostics - Disable USB Charging -
The 1st portion of my last post (apparently poorly described) was an alternate method to check/set the mod internal resistance. Usually done with a TC wire, and I never tried that with Kanthal. The portion following the OR was meant to look for rounding errors with the mod and atty combinations in their then current state with a non TC capable wire. A .01 or .02 reading in reality is close enough for Rock and Roll. You could raise the Therion internal resistance up by .001 to see if that helps. I am of the belief that running your own Thermals and setting your own internal resistance is the best thing you could have done, on all your DNA's. So to be consise. Put the JAC back to its setting. Put the Therion back to its setting raising it by .001 at a time to see if that helps to get them in sync. PS. Didn't your Jac read the .15 Nickel as .15(and in what state)? What did the Therion read? Off topic - Are the thermals done for the Therion, or only the case resistance?
- 48 replies
- jac vapour
- dna75
(and 1 more)
Tagged with:
