measuring ohms Measuring ohms more than once?
Wayneo replied to Rubberducky784's topic in DNA 250 Color
IF You do not need to But if you do then because -
Your answers. 1. Yes. Default on the mod is fine. Or you can get TFRs from steam-engine or create custom TCRs in escribe. 2. Yes. Find the watts you like in regular vaping with the coil, and set that +20% as your Power value. Starting around 200C, increase temp till you reach the temperature of the vape till you like it. If you look in Device Monitor, once your coil reaches your set temp, the watts will drop lower
Can ya do a full printscreen of your Profile 7
Alrighty, can you do one last printscreen while taking a puff. Using the mod in that last Printscreen (ByrdBuild#2). Same atty and coil used there. Using your Profile 7 like in the PS, but ONLY with these checkboxes ticked.
Can ya describe your coil.
Then no. If your mod is always reading the live ohms/resistance of your coil, why would you think you would need to re-measure? But there's no harm whatsoever if you do, as it won't matter -
Can you post a full Printscreen of 'Device Monitor'
External USB Data Connection Trouble - DNA60
Wayneo replied to greenj22's topic in Batteries and Charging
@greenj22 Are you going to leave that permanently soldered? I notice a BB on your bench, and my connections are always removable cuz I just couldn't figure how to mount the board -
Aahhh, yup, that's correct. What you're looking for is Boost Punch while in Watts mode. It's a slider from 1-11, proportional up to 100 watts for 1 second.
@AMDtrucking The board is limited by software, not hardware. Just download and install the latest International version
@StephenGong2000 I never said the word resistance even once. Go run it the watts you think then. Mine were only suggestions.
DNA 166 show always "Check Battery", dont charge and dont work
Wayneo replied to Nembo's topic in DNA 200 and 250
@Nembo Open a trouble ticket with Evolv. They will guide you. From your description, the battery management chip is gone/blown. -
Running your own battery analyzer Full batteries to start You need some sort of RDA/atty on top. Coil built as a few (4) tennis ball sized loops of straight wire. And a fan to keep it all cool, blowing on the loops. Run the battery analyzer at 40w When complete, save and upload to your device.
If it works in temp mode, it'll work with replay
What's the coil material type? If it's SS you have better chances it will
Great it's all figured out. Enjoy your mod. Wish you had told me all that beforehand.
If it's the same material in your simple 75 (and it works for you), you could just save that file and use it in your 75C mod. Crazy wire datashet had some stupid number 'TCR - 3100', which they probably meant 0.0031 That's the value you should have used to create your custom material. CW says right there, they refer to their wire by Ni content, not the (FeCrAl) Iron content so it would match with S-E NiFe52 which is effectively 0.004036. Your 75C showed a TCR value of ~0.00266. You did not show the ending ohms of your simple 75, and it never dropped power, or reached temp. If it's the same material in your simple 75 (and it works for you), just save that file and use it in your 75C mod.
So where did you get the TFR/TCR from, and what is it? If you simulated the build in steam-engine, wire wizard .... is the resistance pretty close to yours?
What type of material is the coil?
Yeah, I'm noticing that also
@mjordan79Site now alive again.
No longer there. Just run Battery Analyzer.
'Time', not available in current version. Just set the power or temp when using TC material for preheat
@DJT Read my comments in this post for running battery Analyzer, or quick fix. No tools required. https://forum.evolvapor.com/topic/70206-dna-250c-battery-percentage-vrk-18650s/?do=findComment&comment=927810
