  1. hold down the 2 small buttons at the same time for a few seconds.
  2. Yeah, figured that out about an hour after writing that. And welcome
  3. You mean cut one lead at a time from the xt60 and solder into the xt30 connector, right? The xt60 can hold a much thicker gauge wire, so check if it'll fit in the xt30.
  4. Glad it's better for ya. Welcome.
  5. Did you read my edit above? It's your wire not jiving with steam-engine. That's why the resistance never matched up.
  6. Edit: Here's the easy answer. Follow this link by @Moutainvaper , go download v3.25 & v3.5 . Those are the fabled Jaquith wire profiles. You'll find 3.5 will display a lower number (temp) on your screen, more to your liking. https://forum.evolvapor.com/topic/65874-ss316l-help/?page=7&tab=comments#comment-923794 Your TC is working fine. SS is an alloy, meaning the wire composition falls within ranges. Nothing wrong with your mod, it's your wire. Report back if you want to on how it's working. No need to answer any of the below original Name and brand of wire? So you're saying 570 on this mod is the same as what on your other mod? And can you just validate to me that wire profile is the standard steam-engine profile? (looks like it to me)
  7. Device Monitor scrolls while firing. Hit the pause icon when you've had a vape. Scroll backwards till it's pretty. Printscreen instructions in my footer.
  8. Name and brand of wire also.
  9. Saw that. What's the current state? Can you post a Printscreen (full, complete from end to end) of Device Monitor while firing with temp, temp set, live ohms, current and volts. And one of the Profile you're using.
  10. Just let your mod sit unpluuged for half an hour. Turn your temp down to your normal values before firing. More answers and explanations over there.
  11. Good morning, @Jentz9517 and @Moutainvaper nope he's long gone, sadly enough. I learned a lot from him. I see the original filenames were changed, which actually followed this format "DJaquith UD-SS 316L V3.25.csv" There is/was even a V5 &7. So in all 5 versions. So ask yourselves 2 questions Why do they say UD in the filename. Think maybe that was the specific brand he tested at the time? Why at least 5 versions, and wouldn't V7 (the last be the best/most accurate) Think about that for a minute and before you go spreading the love. Maybe even ask Steam-engine to change their curve for the good of the world.
  12. Hah! I don't work here/there. But, that is the current behavior of that field. You're good. If you keep an eye on it, that value will move lower, probably drop ~.03 ohms over the next little bit. You're still good, and that's supposed to happen. 'Refinement', BTW.
  13. In reality it's changing because you might be using SS wire, and you showed Profile 2, your mod is not in Profile 2 and just using watts. Notice the 'temperature set' field is blank. Welcome
  14. What version of Escribe? In 2.x it's under 'look and feel'
  15. You are welcome. And you could use those with the Nickel setting on your 40 in TC. Steam engine to the rescue again. Just below the top right. Click on equivalents. http://www.steam-engine.org/wirewiz.html#
  16. All things being equal (except wraps or gauge of wire) ....... the .2Ω Steam-engine is your friend.
  17. NO, YOU CANNOT!! For at least more times than fingers on one hand , kanthal is NOT a TC wire. There is NO evolv board available that will temperature protect/control your kanthal wire.
  18. What seems dangerous? Boost for wattage (similar to Power curves or normal medium high) for other vendors. OR are you talking dangerous for Temperature Protected vaping? IMHO, both are advantageous in the right circumstance. Take out Kanthal it's not a TC wire. Diameter, resistance etc. does not matter. If you like a Temperature, that's it, that's all. I vape in about a 60F range usually, cooler in the mornings. I can use any TC wire at any resistance, and get a somwhat equivalent vape. Using Kantha', n80 you can sorta do this using the 'heat flux' of your build
  19. You could run your own Battery Analyzer, which will take about an hour, tops.
  20. Boost is the proper terminology when talking non TC vaping with any material/wire. Preheat for TC material and vaping only. No official detailed documentation, but it is identified and explained in the datasheet for your board. - if on, I can regulate wattage. <- Max amount of watts to use while coil is getting up to temp - if on, I can regulate temperature. <- Max temp, or temp you want vape at - if on, I can regulate the punch. <- How close to 'temp you want vape at' before ENDING preheat values
  21. Just double the Wh's from the single, use a double, or run your own. Your own will be most accurate. 1 hour of your time and a fan needed.
  22. @Jkill9109 Or just enable/push the 'Temperature Dominant' option in any of your 8 profiles where you want that. Welcome
  23. Yeah I watched it all. My TC with my wires works mint, so no need for me, but I will get 2 boards, just cuz. I wish he wasn't interrupted as much, and did ya catch when djlsb said 'lock the resistance'. He's always said that. Ugh.
  24. @67exec So there would go the balanced battery managament chip, the serial configuration, the 2amp charging, and a drop in efficiency. <- That's the 75C. I can't see it.
  25. Since you're still new, here's a pretty good cheatsheet for ON MOD keysequences.
