It can really be as simple as that Yes, 'warmth' and 'boost punch' can help you fine tune your vaping experience. BUT it can be great without them. For now, just puff away in a replay profile in a straight watt material/mode and hit the replay button when you're ready. Watch a video on how it all works and what the terms mean. Maybe put both at 5 for now, move 1 value to 8 tomorrow, if you don't like that change move it back. Some themes work better than others for users, just depending on how/what the creator thinks and if it jives with you. Enjoy your mod
What doubt(s) do you have? If you follow Bill's advice completely, you should be fine. He's a well respected DNA user. And I do mine in a similar manner. ⬆ This, right here.
DNA200 suddenly reading batteries incorrectly.
Wayneo replied to jsforder's topic in Batteries and Charging
That sounds like the connection to one of the batteries could be dirty or needs adjusting. I'd clean them up (battery and mod coonections) with some Isopropynol alcohol (I have used Windex in a pinch) and check them again. While you're doing that see if all 4 mod connections appear to be making good contact. Usually one end is fixed and the other springs/moves in and out. Try that and report back -
Can't change profile after reset to defaults in Escribe.
Wayneo replied to speshals's topic in DNA 200 and 250
There is no reset. There's a reboot or a restore defaults. What you describe is being in a wattage profile where boost is enabled, and your mod is locked. Unlock the mod, and try again Or, under the top options (File, Edit, Internet, etc.) there should be a 'Help' and under there you'll find 'Backups'. You should be able to choose from there, to get you back to where your mod was working fine. -
No.
You could search for it or even better, run your own battery analyzer. Guaranteed accurate for your mod and batteries.
therion 166 batt problem
Wayneo replied to dub benz's topic in Connectors, Components, and Accessories
Sounds like a blown BMIC and you'll need to open a Help Desk ticket. Link below. https://helpdesk.evolvapor.com/index.php?a=add&category=1 -
I've seen very low builds with these boards with Nickel and Titanium in Temp mode. Rarely do any of these mods come fully calibrated that I'd trust the resistance that low, up to my face. My best suggestion would be for you to ask elsewhere where others vape that low and might have more input, or open a Help Desk ticket for their answer.
We're not Evolv employees so I'd suggest you just open a ticket. Don't worry about scratches.
No, I meant preheat as written. My bad about Replay Then yes, do either of those. Probably the second if you want to see the temp. The 600F max appears to be an industry safety norm. Make sure your Preheat Power is greater than your 'settings' 'power', then 'Punch' is 1-11, or by temp as to where those settings drop/stop using the 'preheat' values. I think that gives you what you want with no workaround.
Need how-to for screen replacement on drone 250c
Wayneo replied to Bombastinator's topic in DNA 250 Color
I have never heard of a charge from Evolv's repairs. Considering they have been contracted by LV for warranty work, just send it in. They're prompt and thorough -
3 Torx screws and you get easy access to the entire 510 assembly. I think if you look/measure the length of threading on your atty's you might find one is longer than the others that could have started this issue.
In escribe, go to Mod -> Atomizers and change the 'Max resistance' value to 0.4 for the old .25(DL) settings
- 1 reply
- 1
Have you tried any other atty's on your mod, and do they work?
NO, I do not believe there is a way to list all profiles or their names on 1 screen at this time. Only the current profile selected.
In escribe, Go to 'File' -> 'Save', and post file here.
older DNA200 consistently killing cell1 on my lipos
Wayneo replied to pwet's topic in DNA 200 and 250
IMHO none of us here are battery experts, but this post by a very senior moderator had the similar thought process as mine. A quick 'search' found it. https://forum.evolvapor.com/topic/69584-vapecige-vtbox250/?do=findComment&comment=924036 P.S I couldn't tell English was not your native language. (tresse a dessouder in french) <- desoldering braid. -
After these problems started did you ever check if cell 1 was draining and charging in a balanced manner? Or after a day if cell 1 had drained some? Which efusion? If the JST connector (white connector the battery plugs into) is soldered to the board, I'd replace it after cleaning up around the solder points. On my efusion Duo, it's easy to get at the LiPo which is behind a removable side panel. I'd probably replace from the to the board itself up to and including the JST connector. Not easy to get at the board itself. -
Battery door paranormal 250c
Wayneo replied to starview's topic in Connectors, Components, and Accessories
Try Stealthvape in the UK -
Ok. So have you verified it's an authentic board? Once escribe has started, click the 'get information' button, it will open a web page. If you've gotten that far, back in escribe, click the 'Theme' button/tab. Are those in Chinese? If yes, save the 2 logo's if you want. Now you have a choice. You can either load the entire evolv defaults which is pretty quick (just click "default theme') OR, in Theme Designer, up at 'Options' 'Language' choose English, then 'upload setting to mod'. Let me know how that works out.
That's a really old mod, so if you can't find one using the search feature you could be waiting quite a while. On non color mods the theme is really just a logo or 2, which is really nothing special.
Serial number blanking on and off
Wayneo replied to Moe KarimKarim's topic in EScribe, Software and Firmware
Can you restate what the problem is, and try to be a little more wordy. I, unfortunately can't understand what you're trying to say. Welcome -
SirTimmyTimbit's Gauges by Jkronicle
Wayneo commented on J_kronicle's file in DNA 75 Color, 100 Color, 250 Color
DJLSB vapes has some good videos on the mods and Theme Designer. If you were to decide to publish it for others, just give credit to the original theme author. Or just keep it to yourself and tweak whatever you want. Welcome
