Theme Designer -> Screens
Avatar GO now listed at ejuices.com $45. Pack of 3 1.1ml replacement pods $10.50 or $12 IMHO you ought to wait for trusted reviews
@hill115sideAFTER your external balance charge do another printscreen like your last one.
No use running the analyzer now. Over time, leaving your mod charging, it should rebalance, unless you can bring up cell 3 on your own.
In between Options and Manufacturer mode, it said click user interface (last option). If that's not there, what version of escribe do you have? (link in my sig for latest escribe)
So you're all fine now?
Did you click the 'mod' button ? and what did it say?
LG HG2, Sony VTC5A, VRK 3000 mAh Paranormal DNA250c
Wayneo replied to Vapor2600's topic in Batteries and Charging
@Vapor2600 If you will be using 3 different battery models, why not just leave it at the default? You can only ever have 1 profile on the mod at a time -
Boost, even at a lower value like 3 will give you a warmer vape, but Replay really is the coil saver. No more dry hits, even if your pod is full.
@Backdoor That vtbox dna 250 uses a LiPo battery, doesn't it? If the cell voltages are out of balance, a recovery charge might work. If you look in Device Monitor it will show the individual cell voltages. A 'weak battery' says one or more cells is triggering that warning. If you find any below 2V, you should recycle that LiPo
Welcome. IMHO, from my take, burping (opening fill cap occasionally), turning down 'warmth', and using Replay will extend your pod life. Others have resorted to combing out some of the cotton to help them wick better. The better news is LV has announced new pods where the coil itself is replaceable and one is a mesh coil. IQS has also come out with a 3rd party pod. So all is not lost on your purchase. Hope this helps
N80 is NOT a TC capable material/wire. Just use straight watts. There is also NO preheating/boosting of watts on the 75 at this time. Welcome
Can not get good flavor with DNA 166c and Mutant RDA
Wayneo replied to Alvee's topic in DNA 200 and 250
Your mod only supplies watts to the coils in various manners. I'd suggest you go watch video reviews on you RDA, or ask on other forums that cater to RDAs. You'll get better responses there. -
Triade: How to turn on/off stealth mode and power lock
Wayneo replied to mexus's topic in DNA 250 Color
@mexus Try a few different themes, and you'll find one that mostly fits with what you like. Use Theme Designer with that theme and others to see 'how' they did it. The 'Main Screen' is really the heart or 'meat and potatoes' of any theme. Many will take the theme they like and customize it further to match their needs, and give credit to the original designer if they decide to publish it here. For now, just enjoy your mod -
dna250c Need help dna250c
Wayneo replied to Thom0203's topic in Connectors, Components, and Accessories
Good to hear all is well, and you are back to a working state. -
@mexus Correct. There are NO native key sequence shortcuts. It's all up to the theme how quick and easy it is to get to. -
@Habubi Look at cell 2 in your video, that battery is showing like 2.8v (can't tell from fuzzy video, PRINTSCREEN would have been better. Did this just start? Did you have any leaking?
Search box works here. It was a somewhat common problem, solved by bending the cable out of the way, like an accordian. In this search link, I think @Spector NS5 RD had the most detailed response. https://forum.evolvapor.com/search/?q=bend ribbon fire&search_and_or=and Welcome
I'd suggest you do a backup of your current config if you decide to install that firmware, and need to go back. Until it's published here, officially by Evolv, you're on the bleeding edge, or to be more PC (an early adopter)
Great information Thom. Stealthvape in the UK is responsible for LV repairs. I do believe if you contact them, they should be able to send you a replacement. But first, you should remove the other 2, lift that assembly gently and see if the broken remaining portion falls out. IIRC it's a T5 torx. If you're lucky, you can remove one of the others, and check for it if you have a specialty fastener shop close by. Good luck -
Welcome @Nicomanteno Have you reached out Ginger about your Boxer issues? Evolv is truly only responsible for the board, and if you look at the photos the Boxer has some custom parts. Personally, I'd try there first, Evolv second. Evolv IS the repair center for your Triad and now Drone so they're stocked with necessary bits.
Welcome Markus This should help you. https://forum.evolvapor.com/topic/70557-nife48/?do=findComment&comment=930009
So hey @lordmage, did my help completely squash all the errors? I haven't heard from you or @nibo. @FAQZY You might want to read the post directly above yours.
Well, I should just say that's the same on mine. Really, really, really long story but you did see the atty warning. Welcome DJLSB vapes has some videos out for these DNA mods, escribe, etc. Themes are like the Wild West, from beautiful and functional to NOT. Search works, and we're a helpful bunch.
