Well, I should just say that's the same on mine. Really, really, really long story but you did see the atty warning. Welcome DJLSB vapes has some videos out for these DNA mods, escribe, etc. Themes are like the Wild West, from beautiful and functional to NOT. Search works, and we're a helpful bunch.
Yo @Moparman, here's the link expanded https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/ I have 2 and 4 cell 250C. On the 4 cell I can get to 400watts with the international software. Make sure you choose that one. Down at the bottom, SP19
Click the Link in my signature. If you scroll up and down, they're all there. After you download them they (individual firmware files) are in your FW folder Tools/Apply Service Pack at top left of EScribe to flash it. Just pick the one that you want. Edit: Is there any reason you don't want the most current?
Yes, that file looks good. * A proper csv only only makes a battery icon or % more accurate. The board will protect the battery and itself but you cannot create a hard cutoff yourself
@lupinehorror You can check that on board up button by removing 4 bolts. I'd suggest you do that first and check in DM. I'm assuming from your comments you're only sending in the board?
Did you check the above? DW circled the button for you in red?
@zark I have never heard or found any Ni200 mesh anywhere, ever. So why would anyone expect it to work with a Nickel setting. If you look at the OG post, after placing the mesh only portion in another atty it just does NOT work in Replay. Hmmm. As far as Replay goes ................. using SMOKs wattage ratings, does the resistance even rise while firing (from what to what)? Device Monitor printscreen while firing? What do they advertise for mesh material?
Places to buy DNA 250c Enclosures for custom builds
Wayneo replied to shroomalistic's topic in Modders' Forum
I thought you were already a Pizza guy, fancy coil builder, and eBay mod seller? -
With it apart (panel off), did you plug it in and see if device monitor still shows the button being pressed? The actual board buttons are on the fire button side, and wires are usually routed away from them.
There you go. In your last printscreen, right there in the middle, see it says Buttons: Up. Then you said you set it to 15, but it fired at 29. Now at 60. Seems/sounds like you have a sticky button, at a minimum. All 3 actuators/buttons are external to the board. You'd need to remove the panel over the buttons, and clean it ou if there's any leakage or find what's causing the sticking. Good luck
After you held down those 2 buttons for a few seconds, could you change the watts? There are 3 different lock modes on the box. If you start with it not working and then plug in and start escribe - device monitor .......... what does it say down at that very last line on the left hand side? Your pic did not show it. DW's pic shows Mode: Charging, Power Locked.
dna250c Need help dna250c
Wayneo replied to Thom0203's topic in Connectors, Components, and Accessories
Lock only up /select /down buttons
Wayneo replied to babis1098's topic in DNA 75 Color and 100 Color
@babis1098 The official Help Desk link is in my sig. IIRC the last option is 'Suggestions'. That would be your best bet. -
No. -
No, not really. You can lock it, so no button works until you until you unlock. The only button you need to worry about is the select button while using the mod -
@arby What is the SP number you have installed? Also are you plugging in directly to your PC (no hub). Also, have you tried different cables?
@lordmage What can I say. I am no longer curious, and have no idea. (Long cuss filled rant removed before posting) My only suggestion would be for users to open an official Help Desk trouble ticket for problems of this nature (where it's clearly more than a usability problem). P.S Just so you know, Evolv has never asked me to temper my words in this moderator role.
Very pragmatic approach @nibo
@lordmage IMHO I'd wait for an update from @nibs to hear that her mod has been returned and is working fine.
Welcome, Can you go into escribe, then Device Monitor, wait about a minute, then post a full printscreen from there. Did you do anything just before this started happening?
That search bar works really well for users with tone and attitude. Common problem, probably half a dozen different answers, but ofcourse we don't know what you've tried from your descriptive post. Welcome
Minimum Replay requirements DNA75C, 250C, or GO International software installed Theme that supports Replay Success best practices Ni200, Ti, SSxxx, NiFe or any TC capable material (wire) as your core wire In a profile that supports Replay.
Straight up ....... I honestly don't know. And I won't know until I get one to test it out. If that's what it took for you, I'm not gonna argue . Do you mind posting a full printscreen of Device Monitor while firing? Over on the left, tick (enable) Power, cold ohms, live ohms.
Thanks for that. I don't have any mesh attys. In general, your preheat settings look fine. If it's now working fine, then leave it off. BTW, you have 2 material types for SS316, the one you posted was for straight 316, and this profile's using the 'L' variant. All's good, just pointing that out.
