  1. @Simon23484 Are you running the latest software/firmware? Link in my sig just in case.
  2. The default values of both those pods are the equivalent of the ranges on store bought coils. Yes you can raise them much higher, but they'll burn out quicker. The DNA GO can output 30 watts, the pods cannot handle that.
  3. @cool2019 That's the best you're gonna get from those unsupported pods.
  4. @cool2019 Your file contained 'no puff data'. What is the current resistance of the coil?
  5. The colour boards operate differently compared to the non colour boards. After working out hotspots, etc. as I already said, re-read the atty while on the mod (Kanthal/NiCr). How much of a lower resistance and what kind of atty with that NiCr coil? I'm hoping you're checking stability using 'Atomizer Analyzer'? What do you mean it lags? What version of firmware is on your mod? PS It's hard to separate the wheat from the chaff in your posts. And that was four (4) questions I asked.
  6. Try this link for 2.0 SP19, and then choose the type you want. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=929633
  7. A quick Google search showed me "About 1,520,000,000 results (0.66 seconds)" I think that's 1.5 billion. Only 2 were relevant. 🤔 🤨
  8. For the MOD tab to appear - Options (menu bar) -> User Interface -> Manufacture
  9. Will anything happen if you click the 'restore defaults' in escribe under the 'My dna' section ? If No, you should just open a Help Desk ticket. Link below.
  10. Haven't seen that before. Is the mod recognized by escribe at all? If yes, you might do a hard reboot If no, I'd do a complete restart of PC, remove and reinsert batteries in mod and try escribe again
  11. What were you doing just before that happened?
  12. En Escribe 'Device Monitor' en la esquina inferior derecha, se muestra el firmware del dispositivo. O En alguna pantalla de tu mod dependiendo del tema. In Escribe 'Device Monitor' in the lower right hand corner the firmware on the device is listed. OR On some screen on your mod depending on the theme. Qu versin de firmware est ejecutando? Nmeros, por favor. O Puede abrir un ticket de la Mesa de Ayuda (enlace a continuacin) What version of firmware are you running? Numbers, please. OR You can just open a Help Desk ticket (Link below)
  13. Yes, you are right.
  14. Datasheet/specifics for each board available here https://www.evolvapor.com/ The 60 does not have integrated charging, but you can get/use an Evolv 1A data/charging board.
  15. Specific discharge curves are NOT MANDATORY. You can use the default if you want, just fine. ALL batteries are NOT created equal. BUT if you want the most accurate battery icon and %, be able to fine tune parameters for your vaping style, you have the ability to do that. Depending on the board, Wh settings are not required.
  16. 1 amp maximum, diminishing as it gets closer to being full. The 75 uses a different/lesser Battery chip (BMC) and only the options shown in 'Screen' Charging are available
  17. No. N80 does not change enough for it be used in TC. SS3xx increases around 20% (in our vaping temp range) and that's about the lowest TCR material. Hohm mods in the past claimed they could do it (even kanthal), but they're longer in the mod business Not that I'm aware of. And it just won't work. You could if you want, find the specs for N80, and IIRC if there's a Mechanical section they might post the rise in ohms at diff temps, and from that craft a TFR file if you understand what you're doing, but it would still not work IMHO. Even the DNA250C board (flagship) will struggle with it, (dubious coil) in Replay and not supported.
  18. No csv file required. N80 is not a TC material (wire). Just use watts.
  19. As long as you credit the original designer, most won't have an issue. Welcome to the forum
  20. No, not really. The easiest way would be to find a theme you like (icons), and then build your own logic behind them. Many creators have spent countless hours creating their own and downsizing/upsizing afterwards, they won't look as crisp. BUT if you really want to, I'd suggest as part of their filename if you harvest icons from other themes, to include their dimensions (I use it as a prefix) like 4x80_battery full. User @zark has posted a zip file of icons from other themes a couple times.
  21. As a moderator, I cannot delete your account. Either just never sign on again (we do not spam you), or open a Help Desk ticket and ask if they will remove it.
  22. So, just checking. You're saying your cold/ambient coil which reads 0.077 ohms, fluctuates +/- 0.03, which would put it at .107 ohms high in AA, just sitting there? On the other hand, that second puff in the second pic actually hit temp, but it was a brief puff. Did it seem too hot? Now that you're back to dual coils with more mass, you do need more watts, but something just feels off to me. How many watts can you use without TC with that coil (safely that you like) <- You can just leave the temp as is and turn down preheat to say your 80, and slowly just increase the Power (watts) while staying in this profile.
  23. @Drughugs Can you describe the coil that's in there now, and If you use Atomizer Analyzer (bottom of the profile page), is the resistance value relatively stable. One last thing, you might want to move the Punch value up to 11 and retry if it all looks good. Like @dwcraig1 mentioned, your coil resistance should almost be double the cold ohm value. No, I don't think the build is too low.
  24. @Drughugs Without the details of the whole Printscreen, I can't tell whats up.
