Was there a special theme on the mod ?
Was this happening from new when you first got the mod? Was there a special theme on the mod?
If it were me or in hindsight, the very first question would have been 'Describe your coil'. All we know now is it's a combination kanthal/SS coil, where it has nothing to do with your theme. I would consider it somewhat unstable, but is working for now. IMHO the title should be changed to be more relevant.
@Lukasz369ns I have removed your DUPLICATE post. You NEVER need/should do that here. That's usually a shitty theme issue. Try just using the Evolv default theme and let me know if the issue persists. https://forum.evolvapor.com/files/file/1438-stock-theme-puff-count-edit/
Now that's a first. I have managed to recreate the '22' on all 3 color boards running that SP55.1 firmware. I have opened a Help Desk ticket describing the issue.
Need to see a picture of that. What theme, firmware, and board type (verifying it's a 250C) on that mod?
are the settings included in the theme?
Wayneo replied to pocixi5431's topic in Themes and Custom Screens
Exactly what settings are you worried about? Do you have a problem? If you have a look under 'Help' you should see backups from the day you bought your mod and first plugged it in to escribe, you could restore from the very 1st one. But that will put back the original theme as well. That 5 year old file you keep mentioning will bring back settings, including firmware and default theme from 5 years ago. -
Just start escribe (with your mod plugged in) and on that startup 'General' page, click on the 'restore defaults' button/option. And voila. Everything default. -
Why do you want to do that? What type of mod do you have? -
@alsk1 I do not believe there is a bug (I could be wrong), and I am going to move these posts about this to their own topic. Since you have cleaned up the issue there is nothing more I can check. Nothing will be removed, just moved. Feel free to create new topics at your leisure in the relevant forum.
I don't see the shortened filename on the right or the left. Or the duplicate file on the right side Everything else is normal. No issue. If you post THAT screenshot (short name), do not write text on it.
Alrighty then, here's the info required to help you. What board type are you using. Color or black and white. What do you mean by this? ⬇ Where do you see it. What do you mean by this? ⬇ It might be easier if you post a couple screenshots for me to see.
My bad, man. I have led you astray. Normally a new feature would have been identified with the corresponding SP release. The unlock sequence is shown here in escribe And you've already seen this information/warning @James Can you please explain how to use the new 'Special Usage' screen 'Power Lock' and the relevant Theme Designer fields
Does it fire? Have you tried different cables? Plug it in, and let it sit for a minute. The board does not start charging immediately after being plugged in. Down in the bottom left hand corner (Device Manager) where you see stealth, locked ....... you'll also see charging (if it is).
monitor data different from the box
Wayneo replied to ZebOctets's topic in DNA 75 Color and 100 Color
I have already written what I thought 2 days ago in my initial post in this topic. 😄 And yes, peak is the highest. -
Go into escribe, start Device Monitor, and do a full Printscreen/screenshot
- 1 reply
- 1
Printscreens that show the full data(I don't mean they have to be enabled) are always much better than just that view you posted. That 190°C you see in Red is probably your 'Temperature Set' value, which is on the left hand side of the screen. On your box/mod, I believe those 2 values on the right hand side (watts and temp) are the averages for that puff. -
🔥🔥🔥 ⚡️PRO VAPERS + Auto Fire / Charts / Action Center / Multi UI
Wayneo commented on aMirS's file in DNA 75 Color, 100 Color, 250 Color
I'll answer, but only this time. You should try to only post theme specific questions here. Yes. Just as the mod starts at 0 watts on its way to its set power level, the coil starts heating towards it's limit. There is only Power and Preheat Power, both should be changeable in every theme. There is no concept of a holding power in TC. If you don't want your set Power to drop, you need to NOT hit the temp you set. -
I looked at that .csv file, and in that 1st second the change was only .001Ω's. After 2 seconds only .005Ω's. And at nearly 11 seconds only .037Ω's, or less than 10% change in resistance. All decreases Even if that were reversed to say those were increases it's just not enough for the board to control it.(from my understanding) Let us know their official answer.
None of the standard materials (wire) we use experience a decrease in electrical resistance when their temperature is risen. None at steam-engine either. Do you have a datasheet for that product showing either its electrical properties or mechanical properties, showing that decreasing TCR? OR Just open a Help Desk ticket and ask. Link in my signature line.
Unclick ALL that you enabled in Device Monitor, only enable/click cell 1 and cell 2. Plug in mod, start device monitor, let sit 30 seconds and post screenshot like your 1st picture Unplug mod, swap battery positions in the mod itself, Plug in mod, start device monitor, let sit 30 seconds and post screenshot like your 1st picture Post 2 screenshots. If you look at your 1st picture, there were many voltage dips with cell 1, I wanna see if cell 2 (after your swap) shows the dip behavior
