Glad to hear you're enjoying your mod. 👋 No, there is no custom wattage or temperature curve based on seconds. But you can open a Help Desk ticket and give them your suggestion. Link in my signature line. I have never seen this or heard of this before. What settings change?
This can be one of the most difficult issues to find due to so many different reasons. Was this a new coil or new wire or a new atty? Was the coil checked for any hotspots before using, and screws were still a tight connection? Was the coil installed at room temperature? Describe the coil and Ω's. Using Atomizer Analyzer tell me how much the coil fluctuates over a minute. While taking a puff using Device Monitor (and the same 3 fields as below(1)), pause the screen (2), hover your mouse over near the end of the puff (3) and click for that vertical line, and post the full screenshot like I did.
evolvdna New Evolv Default Enhanced DNA75C-100C-250C
Wayneo commented on Khaled Shehab's file in DNA 75 Color, 100 Color, 250 Color
If you continually make improvements; why don't you identify what was improved using the 'changelog' like others? why do you continue to post old versions along with the new and improved? Maybe keep 1 version back. By the way, what were the 'Many additions, modifications and improvements' for this edit/update? All I see is 1 (one) icon change. -
Watch that video on DNAs, as some terminology will be new to you. Are you in a non TC profile such as 'watts' ? If you are, do what you'd normally do -> turn the watts down. The answer to that is No.⬇
80 watts all day on a single battery is a tall order. 🤔 The best way to estimate would be to use this. Put in your battery specs. https://www.steam-engine.org/batt
Hyperion 100c new user - is this normal?
Wayneo replied to Brainfog's topic in DNA 75 Color and 100 Color
No idea about the puff count issue as it's useless to me, but not all Fire button presses are puffs, and those get cleaned up when plugged into your PC that also has escribe. (But I have heard this before) Here's a thought, what theme are you running? How can you tell when this happens and when does it happen? TC requires your coil and atty to be room temp when you start. By removing the battery 2 things happen. It allows the coil to cool more and it also forces your mod to reread the Ω's. But YOU should also re-measure the Ω's so it's written into the mod. -
Is there a way I can copy the settings of a different mod.
Wayneo replied to jsd540's topic in DNA 75 Color and 100 Color
There is no wattage curve. But, in a Profile where a NON TC material has been selected you can do a BOOST PUNCH. It's a set 1 second slider. Effectively a hard normal soft like other mods, to give a coil that extra to start vaping quicker. You might want to turn your watts down a bit, with Punch at 5, and work the punch up or down. That might delay burning your coil. EDIT: What kind of mod? You've posted this in the 'Reflex' area -
preheat kanthal dna75 (2022) Just use Boost Punch
Wayneo replied to abraxas's topic in EScribe, Software and Firmware
This is a 5 year old post. On all boards except the OG DNA200, no trickery is needed. Just use the Boost Punch feature for a 1 second proportional watts increase -
Thanks for that @BlackFireDragon 👍 Up near the top left you'll see the voltages for each cell. Cell 1 and cell 2 are both discharged to such a low state that the board will not recover them (charge). IMHO you need a new battery. Cell 3 and 4 look like the standard shipping voltages before ever being fully charged and that low puff count and mWh usage (bottom right) and seconds would say it was like this when you got it. I'll just briefly address your last post as you directed it to @retird. The maximum charge rate on ALL 250C boards is 2A, no matter what you read. Batteries don't know %'s. Most Lipo's consider each cell at 3V as their fully discharged value and part of the built in board protections just will not charge a battery as shown.
I get the jist of what you are saying. Can you start escribe, then Device Monitor and a full screenprint with your mod plugged in. It should look like this.
If it's only the colors Start escribe with mod plugged in. Go to mod -> Mechanical -> screen type and try the other 2 options. Always Click Upload settings to mod after any changes. OR Start escribe with mod plugged in. Go to Help, Backups, and restore from a time before you did restore defaults. Always Click Upload settings to mod after any changes.
Version 1.0.0
652 downloads
You can download them individually or as a .zip.csv file containing all 6, but you'll need to remove .csv file extension Steam-Engine files NiFe (Reactor_Wire) - TCR in vaping range 4000 ×10-6 NiFe30 (StealthVape) - TCR in vaping range 5000 ×10-6 NiFe30 Resisttherm TCR file - TCR in vaping range 3200 ×10-6 NiFe30 Resisttherm TFR file - TCR in vaping range 3355 ×10-6 Nifethal_52 (Alloy52) - TCR in vaping range 4036 ×10-6 Nifethal_70 (Alloy120) - TCR in vaping range 5250 ×10-6 These Steam-Engine files and TCR values were sourced from here http://www.steam-engine.org/wirewiz# Here's how to understand or create just a custom TCR file from the 'TCR in vaping range' values or given to you by a vendor. Nifethal_52 (Alloy52) value 4036 ×10-6 you would create 0.004036 as the TCR value Vendor says 404 you would create 0.00404 as the TCR value Some vendor datasheets list the NiFeXX to denote the Nickel content like here. You need to take care. While others list NiFeXX to denote the Iron content like here -
If that's all you changed or tightened ...... yes. The DNAs require very solid and clean connections.
@raberone Well that's much better. Those all look as if they worked fine in TC. @BillW50 That last puff peaked at 92°C Bottom left hand corner which is quite low for temp, and constrained by the 16 watts
I will assume you did not do TempCal Init on your Dani, and it was set for normal watts. Your DNAs should still work fine for TC vaping even though they both read the coils slightly higher than your other mods, as they were both calibrated. You will notice on escribe in all of the profiles the coil resistance is always stored as an Ω and temperature pair which is used to derive the base 20°C (which will be lower) That's the best I got.
Wow! Even the Ω's are drastically different. We know your Rubrik works fine in the 75C. I think it has to be down to the connections on the Abyss. That small 0,001Ω fluctuation with Atomizer Analyzer is normal. Do you have another RBA that works in TC on the abyss? @BillW50 dont't you have an Abyss, and does yours work in TC?
For both tests was it the same Rubik rba with the same coil? AND did the Abyss switch to OFF?
I would not give up so easily raberbone. TC works easier with a spaced coil or you really gotta make sure there are no hotspots with a contact coil. At the bottom of the Profile page is Atomizer Analyzer, and with your mod plugged in it should show very small fluctuations, or a small rise then dropping (rinse and repeat). Then using Device Monitor (while taking a puff) with Power, Power set, cold ohms, live ohms checked/enabled we/you can monitor exactly what's going on. Screenshots appreciated.
Thank you. So taken from zivipf; Alloy components: Ni 52%, Fe rest Temperature coefficient: 400 Well you do have the correct material file. so that's good. My 'ugly head' comment refers to Ziv using the '48' to identify the Iron content whereas steam-engine uses '52' to identify the Nickel content. Using escribe with your mod plugged in can you go to your SS316L and NiFe profile and make sure or change so that the temperature box under settings is chosen. (same thing as making sure the 'Off' is NOT highlighted) and let me which material had the 'Off' highlighted. Make sure to Upload settings to mod whenever you make ANY changes in escribe. Another way your mod could have got to 'Off' is on page 4 of the datasheet. Here's a snippet. 'The maximum temperature is adjustable between 200° Fahrenheit and 600° Fahrenheit. To disable the temperature protection entirely, adjust the limit up to 600 degrees, then press the UP button one additional time. The temperature limit will read OFF.' Here's where you can download the complete datasheet 'https://downloads.evolvapor.com/dna60.pdf' Edit: While you're in there (Material for NiFe52 you might want to change the 'On-Screen Name' from 'Ni' to 'NiFe or NiFe48' <- something no other mods can do
NiFe rears its ugly head again. Can you post a link where you bought this wire AND a screenshot of the NiFe Material Profile, like below.
@rcamarda After a good sleep, here's an idea. Remove atty from mod for 10 minutes (to cool), go to a completely different profile where it shows zero for the ohms (don't worry about material type). Re-install atty and hit the fire button which will generate the new coil message. What are the Ω's Rambling on. I'm wondering if you're hitting the fire button even briefly (before you remeasure) which could cause the ohms to rise that 0.06Ω from your Dani. Considering both of your calibrated DNAs read the coil exactly the same, it would be hard for me to fault the mod Do you see this difference between mods with different atty's like @BillW50 showed?
Thanks for that. Both values look very respectable. Since you measured the internal resistances yourself I'm out of ideas.
Outdated material presets and box TCR input still missing
Wayneo replied to rcamarda's topic in DNA 250 Color
You don’t need to reset to defaults. just start escribe with no mod attached, choose new 250c, when it opens go to material, select nife30 in the right hand window and move out to the left hand window. Now it’s available for all your moods just move it to their right hand window -
@BillW50 is absolutely correct AND one of the 5 default evolv material entries IS Nife30. If it's not there that was done by Vapecige. However NiFexx is an oddity whereby different vendors use that suffix value to denote the Nickel content while others use it for the Iron content. Then on other mods you end up with 'M1 or T1 3200' and 'M2 or T2 4036' on other mods that do not allow you enter a material name. Oh yeah, which one's which? You can put that suggestion in at the Help Desk. Both forum activity and SP updates are driven by user engagement. You personally have dealt with Evolv's Director of support, yet questioned the truthfulness of the answer. What other competitor has a dedicated user site or allows access to their non marketing employees?
