black lace Posted January 22, 2016 Report Share Posted January 22, 2016 ''oh'' no worries,, nice to have some leads for materials though; so thanx, love to have something on the bench coming together,,, Link to comment Share on other sites More sharing options...
shortlex Posted January 24, 2016 Report Share Posted January 24, 2016 Here is my 200-2x 18650 made with 3D printer Link to comment Share on other sites More sharing options...
VapingBad Posted January 25, 2016 Report Share Posted January 25, 2016 Really cool use of different colours shortlex Link to comment Share on other sites More sharing options...
jurdanas Posted January 27, 2016 Report Share Posted January 27, 2016 First DNA200 plastic home made (dont like): Remake to Hammond 1550P and LiPo Pack(http://www.hobbyking.com/hobbyking/store/__18205__Turnigy_nano_tech_1000mAh_3S_45_90C_Lipo_Pack.html) (home made, like, but...):Remake to RX200: Time will tell Link to comment Share on other sites More sharing options...
awsum140 Posted January 27, 2016 Report Share Posted January 27, 2016 I finally got around to taking some photos this morning, but first I did some "maintenance" on a couple of my DNA200s. I took my 1590G apart to re-fold the screen ribbon to make sure it stays away from the fire button. Building the ERM+s has convinced me that the ribbon cable is pretty durable and can be bent quite severely without damaging it. While I was at it I took the fire button out and ground/filed a flat on the side that faces the ribbon cable just to make sure. Then I took ERM+ #037 apart and tightened up the 510 connector so it is now flush to the enclosure. My first attempt at a custom spanner didn't let me apply enough torque to tighten it completely, but my new one works like a charm. Here's ERM+ #037 and #038 apart for the photo. In the center is my "high tech" spanner for the 510 connector. Its just a piece of aluminum angle with 6-32 screws threaded through it and ground down to fit in the holes. I'm using lock nuts on the other side to allow setting the depth to prevent the ends from scratching the case under the connector and to spread the force a bit onto the angle stock. Here's my "stable" of DNA, hand built, mods. From left to right - Low tank DNA40 with a Fogger V6, ERM+ #037 with an Aromamizer, ERM+ #038 with a Fogger V4.1 and 1590G with an Aromamizer. ERM+ #038 is for the Mrs. and the Fogger has kanthal coils 'cause she's a tootle puffer. Bet the battery lasts her a week or two at least! Link to comment Share on other sites More sharing options...
black lace Posted January 28, 2016 Report Share Posted January 28, 2016 jurdanas > those are very nice mods, if you don't mind me asking? are you left handed? Link to comment Share on other sites More sharing options...
steamer861 Posted January 28, 2016 Report Share Posted January 28, 2016 This is my collection of DNA200's I assembled them all my self 5 are 3D printed 2 are custom made Thanks to you know who & 2 are VT200 enclosures from Cigreen They are all lipo's 4 1300mAH 3 900mAH 2 Hcigar cells between 900 and 1300mAHI'm going to make it an even 10 with a Mix&match DNA200(3D Printed) with a dual 18650 battery configuration These 2 are the latest additions Again Thanks You know Who Link to comment Share on other sites More sharing options...
Guest Posted January 29, 2016 Report Share Posted January 29, 2016 It's not mine but I sure do love it http://www.themagmod.com/ Link to comment Share on other sites More sharing options...
black lace Posted January 29, 2016 Report Share Posted January 29, 2016 I like the buttons Link to comment Share on other sites More sharing options...
Kagaen Posted February 20, 2016 Report Share Posted February 20, 2016 First and foremost this was my first regulated build and end up messing things up so I know that some will critique my cutting and drilling just know I don't care. I have a box lined up and one being 3D printed for it and I'm use to just doing unregulated boxes Ok so when I got my DNA 200 kit, I did not take in to consideration the actual size of the battery. Drilled the box out completely, Battery finally arrived and ended up not fitting the box no room for the 510 connector. I started scrambling around for what I had laying around in the process I ended up destroying the shelf pins for the switches, and the box was at a total loss. Speed forward to an hour or so after I've torn my hair out and hanging my head as a loss looked up at my dremel kit and saw the accessories box that has little items in it. Ended up cutting 2 walls out of it and part of the spine as you see in the pictures. Drilling went south and had to make shift new pins for it which I used knitting needles and some remains of the plastic I cut out. Every thing else went smooth and I have learned new and valuable lessons in building this. I've since called the the Battle Scar DNA 200 hope you enjoy the pictures as much as I really did building it. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted February 20, 2016 Report Share Posted February 20, 2016 Kagaen said: First and foremost this was my first regulated build and end up messing things up so I know that some will critique my cutting and drilling just know I don't care. I have a box lined up and one being 3D printed for it and I'm use to just doing unregulated boxes Ok so when I got my DNA 200 kit, I did not take in to consideration the actual size of the battery. Drilled the box out completely, Battery finally arrived and ended up not fitting the box no room for the 510 connector. I started scrambling around for what I had laying around in the process I ended up destroying the shelf pins for the switches, and the box was at a total loss. Speed forward to an hour or so after I've torn my hair out and hanging my head as a loss looked up at my dremel kit and saw the accessories box that has little items in it. Ended up cutting 2 walls out of it and part of the spine as you see in the pictures. Drilling went south and had to make shift new pins for it which I used knitting needles and some remains of the plastic I cut out. Every thing else went smooth and I have learned new and valuable lessons in building this. I've since called the the Battle Scar DNA 200 hope you enjoy the pictures as much as I really did building it. Expand awesome! i love it! i don't know how long she'll hold up but if it works and you're happy, i'm happy for you. #BUILTNOTBOUGHT Link to comment Share on other sites More sharing options...
Kagaen Posted February 20, 2016 Report Share Posted February 20, 2016 [/QUOTE]awesome! i love it! i don't know how long she'll hold up but if it works and you're happy, i'm happy for you. #BUILTNOTBOUGHT[/QUOTE]Thank you, and I don't plan on having her in the case for more than 2 weeks payday is right around the corner and will be getting a few more viable cases Link to comment Share on other sites More sharing options...
edwa Posted March 3, 2016 Report Share Posted March 3, 2016 So this happened . Projector Box by Koncio Mods from Poland. Outstanding work . Link to comment Share on other sites More sharing options...
yff1999 Posted March 4, 2016 Report Share Posted March 4, 2016 ???? ?? Link to comment Share on other sites More sharing options...
The DigitalAlchemist Posted March 8, 2016 Report Share Posted March 8, 2016 I call it my DNA200-RX. RX200 converted with the DNA200 chip, and dressed up with a J-wrap and mounting a Alliance Big Boy V2.The wire is something of my own design (never looked up a build for it, just kinda discovered you can do it). It's a pair of 24g wire twisted together, then a 32 (I think) threaded into the gaps, twice. Amazing flavor, resistance isnt bonkers either. 0.17 for what you see there.Really, I cant say enough about the flavor. It's kick ass! I'd say it's better than a clapton, and easier to make too! With much much less wire to boot. Link to comment Share on other sites More sharing options...
Pathian Posted March 10, 2016 Report Share Posted March 10, 2016 I might have a problem.L to R: LittUp 44 #20, Mahogany DNA200 with Mamu Faceplate and Avidvaper buttons, Reuleaux, Bare metal Silo and red ano Silo Link to comment Share on other sites More sharing options...
Gs901 Posted March 16, 2016 Report Share Posted March 16, 2016 lolerwaffles said: I moved on from my beta, looks alot better now. Still on those 18650s. Expand love this box would love to own one Link to comment Share on other sites More sharing options...
and_des Posted March 19, 2016 Report Share Posted March 19, 2016 Just got this in a exchange. Didin't really like the finish so i redid it today. Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 23, 2016 Report Share Posted March 23, 2016 I received my Protovapor Silo today, a great job they did. It came properly set up and included a nice cable, instructions and warranty card. So a big shout out to Evolv, Protovapor and Modcrate. Link to comment Share on other sites More sharing options...
black lace Posted March 24, 2016 Report Share Posted March 24, 2016 Blue screen? Or is it just fading out? Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 24, 2016 Report Share Posted March 24, 2016 Fading I guess, it looks just like the rest of them that I have. Link to comment Share on other sites More sharing options...
vegabob Posted March 24, 2016 Report Share Posted March 24, 2016 This is a Mod MAMU has made for me it's 41/41/93mm it's got a 1,5000 mah battery in it a Fatdaddy V4 510. She only made 2 of these and I was lucky to get one. I'm so glad MAMU is back in the Modding game a little bit. I have wanted one of her EVOLV product mod for 3.5 years. For people that don't know who MAMU is she is one of the OG Modders from years ago. Her mods are very hard to get your hands on, like I said I was very lucky to get this sweet little mod. I own a lot of high end mods but to me because of what MAMU has done for the Modding world from way back I hold this mod closer to my heart than any thing else I own. I have thanked her over and over for letting me be the one to care for your work of art. Link to comment Share on other sites More sharing options...
vegabob Posted March 24, 2016 Report Share Posted March 24, 2016 and_des said: Just got this in a exchange. Didin't really like the finish so i redid it today. Expand Link to comment Share on other sites More sharing options...
vegabob Posted March 24, 2016 Report Share Posted March 24, 2016 I was very lucky to pick up one of these Music City mods my self. The quality workmanship in these mods is awesome. You can tell a craftsmen built these mods Link to comment Share on other sites More sharing options...
black lace Posted March 24, 2016 Report Share Posted March 24, 2016 Yes very nice, you dont see many wooden ones, i love wood metal combination, specialy tree wood, real wood. What size battery in there? Link to comment Share on other sites More sharing options...
