Hadron Pro - 1.1 SP33 US/INT to SP45 INT...irreversible changes?/
Wayneo replied to franticseven's topic in DNA 250 Color
Device Monitor uses that battery curve voltage value for the Level % after the 4 cell voltages BUT If you're gonna follow the screenshot @dwcraig1 showed, see that label in his pic that says 'Maximize puffs', that MUST be changed to 'Maximize recharges' for charging to stop at 4.10Volts -
Two things @illogik Do you remember what volts (or %) your batteries showed when you finally put it down? Do you remember what volts (or %) your batteries showed when you first picked it up? Looking at the datasheet, there's a Quiescent Current (while you were sleeping) of 10 mA -
Boost - A 1 second proportional increase from the set watts for any coil when not used in TC. Punch - How many extra watts will be used during that 1 second Kanthal and N80 are watts mode only materials. The word temperature is not used with non TC materials. Words like hotter or cooler are used to keep a clear distinction between TC and non-TC materials For TC material (NiFe, SSxxx, Titanium, Nickel200) using TC. Preheat - Maximum watts allowed at the start of a puff Punch - How close to the 'set temp' before quitting the Preheat watts Alternatively if you hover many fields in escribe you'll get official definitions
Here's a great video tutorial on the board and Theme Designer. The main reason anyone would compare this to minikin is due to the same shape and size. The video lingo, or escribe will get you familiar with DNA words You cannot create your own vape curve. (wattage) DJLSB vapes - Evolv DNA 75 C Full Review with eScribe and Theme Editor Tutorial - https://youtu.be/1dvBpTm-FQM
for your battery. Even now, it does not affect your mod in operation. You can use it down to the 'weak battery' warning, knowing the 'check battery' will soon be there. Your battery standing/unloaded voltage will not be below 3 Volts for any cell. Notice I still talk volts, you still talk % 😉 -
At least all 4 cells look equal. 👍 Many mfgr's do not run the 'battery analyzer' for their batteries. I don't know if they did, but it will make that % value or an icon more accurate. Sorta like idiot lights in a car. Anyway if you want to, YOU have access to their tools Using escribe on your PC, For the MOD tab to appear - Options (menu bar) -> User Interface -> Manufacturer Then choose 'Battery' This requires maybe an hour, an RDA, a fan. Let me know for more details if any/all of you 3 want to. -
Yes. This will be a bit longwinded. For all those reasons I wrote before That very low power draw is done to make it more responsive to button presses. Also, If it actually powers off, it has to do the New Coil check based purely on resistance. But NO battery knows anything about a % (percent).They only talk in volts. 16.8V for you guys If your battery charges each cell to 4.20 volts it is full based on the default curve. If your mod shows 95% in the morning, using the default curve, each cell should be at 4.15 volts, or maybe just 1 of those 4 cells has dropped to 4.15 volts. That would be a drop of 0.05 volts per cell. Many themes will show individual cell voltages, but even better, escribe Device Monitor (click cell 1, 2, 3, 4) will show how each cell is operating while in use (taking a puff) Why don'cha post a device monitor screenshot -
My suggestion is to find a generalized vaping forum or search youtube for reviews or commentary. If you're interested in the Reflex, peruse this area but remember many posts are users with problems. If you're interested in the Reflex, ensure you can find replacement pods. This forum is dedicated to DNA mods and their users, so you'll get a much broader view of what's out in the market elsewhere such as at e-cigarette-forum.com or vapingunderground.com
IIRC your mod should detect a failed update. I'm a Mac guy so no longer Windows savvy. You could/should a Help desk ticket with Evolv. Link in my signature. Good luck and let us know how you make out.
Try using a different USB cable and see if that helps, ideally plugged in direct (no hub)
landscape Evolv default Landscape PIMPED OUT - SESSION MODE
Wayneo commented on CMK's file in DNA 75 Color, 100 Color, 250 Color
IMHO this theme still reigns supreme, right down to the hidden lock feature from the regular/main screen. Or how about the watts shown when in Replay mode (nope not what you're thinking). Nothing but Gold. Those special touches aren't talked about at all really, but once you see/use them you'll come to understand. It's just a pity that I couldn't add this as another 5 star review after 7 months and numerous updates.- 2 comments
- 2
- dovpo
- steamcrave
(and 3 more)
Tagged with:
They both have the same identical chip and screen. .9” 80 x 160 pixel Full Color TFT
color Color Changer - Switch 11 colors DIRECTLY on your mod
Wayneo commented on BigLarry's file in DNA 75 Color, 100 Color, 250 Color
- 2 comments
- full feature
- black panther
- (and 30 more)
@BillW50 Loctite on the threads <- Don't do that. It can throw off your ohm readings. I personally encountered that AND here's a post from an Evolv employee saying the same ThatGuySwain - https://forum.evolvapor.com/topic/69140-paranormal-75c-resistance-too-high-fix/
Demon Slayer Centaurus 250C
Wayneo commented on Tandi Kukuh's file in DNA 75 Color, 100 Color, 250 Color
landscape New Evolv Landscape DNA75C-100C-250C
Wayneo commented on Khaled Shehab's file in DNA 75 Color, 100 Color, 250 Color
Suite SP31 is the latest for all mods. Click the link in my signature. Guaranteed there were 250C firmware updates in 2021. I think SP45 firmware for the 250C which will be in there.
Unable to connect to brand new Evolv 100DNA Color
Wayneo replied to CASCO's topic in EScribe, Software and Firmware
Well if you wanna measure say from the middle of your bottom button to the middle of the USB port it should be 8.9mm (or that's what I figure from the engineering description at the bottom of this page) https://www.stealthvape.co.uk/product/evolv-dna100c/ -
Nah, many vendors were out there with single battery 21700's with 100 watts. You can 'punch' the watts to 100 on your 75C with the right battery and build. Of course your battery life will suffer more than it currently does. If the USB ports line up side by side, it's NOT just a board retrofit. Here's a photo of 2 identical mods and you'll notice the USB port on the right (100C) is lower. -
Different people want different things shown on their screens. There are about 6 different ways YOU can sort the order of themes shown to you. My opinion would very easily be different than yours. Many just look pretty. Follows evolv's guidance - cmk aka gwyar, Mr. bottomfeeder, zark(russian). Among others Kitchen sink almost everything - Frank65 Clean - niandra3, tortuga, copyman. Those are author names that I can personally recommend. No offence to others.
Is that Odin 100 even a DNA mod? -
So I think you have 1 dead board and 2 dead screens. Your board has an official 1 year warranty, but you can open an RMA at https://www.stealthvape.co.uk/ and they will guide you.
Did you hear a click at the screen ZIF latch/connector? If it has a USB port, is it recognized by escribe?
