  1. What @BillW50 showed, does not survive a battery swap.
  2. Unfortunately there's no easy answer, because more info is needed. What is the coil material (wire)? Are you vaping this in straight watts, or Temp Control, or Replay? Instead of a mod screen photo, can you post a screenshot/printscreen of Device Monitor (of each mod) while firing with ONLY the same boxes as you see below. (Your numbers seem backwards) "Is this due to a different firmware? or due to hardware differences?" No, not usually. Both DNA mods should give almost the same experience, most of the time, in your case.
  3. I'm still waiting for an answer to @BillW50 question if escribe detects it? and hopefully a Device Monitor screenshot. By always USB charging, you're effectively blind to any small leaks down into the battery contacts. A small torx bit and a $10 digital meter would also be beneficial to diagnose your issues. 🤷‍♀️
  4. Welcome to the forum @HankStarr 👋 I don't know where you heard this, because many cells have a 'Fully discharged' value of 2.5v, a few 2.3v, and IIRC one is 2.0v. The 250C, regardless has a 3.0v minimum standing/unloaded voltage for each cell.
  5. Input -> Straight battery side specs per cell. Not charging. Output -> After going through the regulator board (250C in your case) Battery tab -> Values per cell Electrical tab -> Combined and limited OR Totals for the output The datasheet for the 250C shows more information but not what you seek. There is no current more detailed explanation. There was an escribe manual somewhere in one of your folders, but last I looked was from 2016 and was only about Python scripting, but I also remember another manual, but still not what you seek.
  6. What's there to fix? Start escribe. Go under 'Help' -> 'Backups' Restore from a date when it was the original board. Then see if there are any firmware updates
  7. Instead of a 2 part process, this fix has now been rolled into the latest 'early' escribe suite SP30.1 found below. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=937825
  8. The theme on your mod must not have that feature. Click on downloads - color themes, that takes you to the theme park. in the bigger grouping of pics look for the word reset. You'll need to use escribe to install a new theme. Escribe will also let you know if there's an update, but if it doesn't click this link which is the latest https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?tab=comments#comment-937825
  9. That looks like ejuice down at the bottom of the board in/on the JST connections or where they connect to the board. I think if you open up your mod you'll find ejuice that needs to be cleaned off.
  10. You cannot set or create the TCR of any material 'on the mod' The material (wire) has a TFR or TCR, NOT a specific coil. You can use steam-engine 'wire wizard' to simulate a build of your materials and coil once, and that will show the TCR value in the 'TCR in vaping range' field. IF you're gonna use these coils strictly with color DNA mods Replay offers dry hit protection and more. That TCR value benefits non color DNAs or any other mod. Replay DOES NOT require ANY material profile.
  11. You should try to sign in with your original ID, and use the 'forgot your password' option. No need to create a second ID. DO THAT, and I'll change this post to your original ID.
  12. Thank you for your understanding @Darth vapes. Tomorrow I'll delete this post, and the 2 above. 2 things I'll comment here. YOU ONLY NEED A MATERIAL PROFILE FOR TC YOU DO NOT NEED A MATERIAL PROFILE FOR REPLAY PS You never did answer James' question
  13. @Darth vapes Seeing as how you have the same issue on the 250C , I'd like to MOVE all your posts after your 'Thursday at 01:43 PM post' as the weak puffs issue has been resolved with the 45.1 update. (Just trying to keep this weak puff issue isolated for everyone). Waiting for your acknowledgement. Of course I'll also move @BillW50 posts
  14. Hopefully it is still under warranty from where you purchased it. I think you should either contact them or the builder himself. Failing that, you could open it up and look around the screen connector itself. If neither of those 2 options seem reasonable, you could open an RMA with Evolv. I imagine the screen is very close to the board, and you might want to purchase a data/charging board for future use, such as setting the board up to your liking. Checking the firmware level, etc. Those board pins are at the bottom of the board near the screen ZIF connector. I made this cable that is removable just for the above changes. After all that I posted a cheat sheet for these non color boards. https://forum.evolvapor.com/topic/71559-cheat-sheet-key-combos-for-non-color-mods/
  15. If you are not in USA 🇺🇸, they can be found at Stealthvape or Modmaker, both in the UK.
  16. Wow! There are many themes under the Downloads tab. Just look around.
  17. So if you turn up the watts, won't you get the same taste/flavor? Edit: Or you could use the 'watt boost' profile, say start at 5, to give those 23 watts some extra watts for more power
  18. In escribe under the 'screen' tab, there are at least 6 parameters for the screen behavior. At a minimum you should check the brightness is at 100% (or more than it is now). Always 'upload settings to mod' after any changes
  19. I think we're gonna more words. What material is your coil used in the DB V3, and what Ω's? How many watts do you run it at? When you put it on the Hyperion, what Ω's does it show, what is the profile called, what coil material shows? How many watts do you run it at?
  20. Does that mod have a USB port/escribe access? Are you saying it was brighter, and then slowly over time it's been getting darker and darker? <- I've never heard of that before.
  21. Why would you want to install a firmware without knowing what it's supposed to fix? Sounds backwards to me. Hopefully Jacob will send you for small screen, but more importantly tell you what it changed. 👍
  22. That version has never appeared here from Evolv. It could either be a typo appearing, or an oversight. The Help Desk can clarify. Link in the 4th post.
  23. That is the correct location, and version currently on your device. I don't know any more about the different firmware updates. You'll need to make that request for more details and a curated list at the Help Desk, link below. https://helpdesk.evolvapor.com/index.php?a=add&category=1
  24. Updates where the GO is mentioned starts with this post. You can read down to the bottom of the thread for more details https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=928400
