Everything posted by giz_60
Most of the Evolv defaults should work fine... you might want to load a .csv file for those batteries to improve the accuracy of the battery level indicator on the device... LG_HG2 (2)_18650_3000 mah.csv
There is no option for the number of cells on the 75...
Had that issue once...opening 'Device Monitor' reset the date & time...
I would try disconnecting the external button completely. Problem persists, then a possible board problem...if not, either your wiring or a bad button...
What mod is that?
If no atty is working, then it sounds like a connection issue with the 510 pin...which has nothing to do with Evolv, but rather Lost Vape...have had similar issues before & was able to fix by using a small screwdriver/knife to raise the 510 pin to establish a solid connection...
Most any wire you apply an electrical current to is going to warm up, therefore most DO have a TCR value applied to them. However, doesn't mean that they will work in TC mode. Because the TCR value of Kanthal & Ni80 is so low, they will not work in TC mode.
Would be best to contact the manufacture of the wire you are looking to buy, for the correct TCR.
Kanthal & Ni80 wire is NOT a TC compatible wire...therefore, they cannot be used in TC mode...
.006 is the default value that Escribe applies as a TCR value....as long as you uploaded the setting to the device as .00094, you will be good to go...
Being that no 2 mods are EXACTLY the same, why not just run the case analyzer & obtain the proper thermal values for YOUR mod....
In Theme Designer...'Options > Set Orientation'
Had this same error before...hooked mod to Escribe & opened Device Monitor...time & date were reset...
Return it
- 1 reply
- 2
DNA250's reading different ohms
giz_60 replied to Fabian9988's topic in EScribe, Software and Firmware
A very slight variance is normal. .003 sounds a lot better than .019 -
check atomizer message after SP23
giz_60 replied to jhdelamain's topic in DNA 75 Color and 100 Color
In Escribe...'Tools > Apply Service Pack'... -
Most likely is a 510 issue. However, being that the Smok TFV atty's are notorious for weird resistance fluctuations due to the floating pin in their bases, the issues is most likely on the atty (510) side rather than the mod side...
Charging Light / Battery Curve Question
giz_60 replied to kinger's topic in DNA 75 Color and 100 Color
Board..the curve will affect.the cell percentage (%) you see -
giz_60 replied to David Campbell's topic in EScribe, Software and Firmware
Found em....Thanks!! -
Have noticed that in DM, the 'Graph Options' has disappeared in the SP4 update. Have the abilities to set the graph timescale under the 'Appearance' tab & take a .csv snapshot (which disappeared in SP3) been moved somewhere else?
