Everything posted by giz_60
On the 75 watt boards...yes
@James,...is this why when resetting the date (yr.) on the device & not hooked to Escribe, when finished it drops it back 1 yr...ie, in order to get it to set the yr. to 2017, am having to set it to 2018 & when finished, it drops back to 2017. Also, each subsequent scroll through the date field will drop it back another yr...2016, 1015, etc....
Your not getting enough power to the board...usually a sign of a weak/bad cell or a connection issue...if that mod has a screw on battery cover, then I would recommend cleaning all the threads etc. really good with so iso alcohol...I have had similar issues before with that type of setup and cleaning made a big difference...
Look at your battery voltage...2.75v
You are having a severe battery sag...either a weak/bad cell or bad/dirty connection...
Ok...now how about one while firing the device... Edit: And what kind of wire & atomizer & mod are you using?
Can you post a screenshot/print screen of Device Monitor in Escribe with the following fields checked...Pack, Power, Power Set, Temperature, Temperature Set, Cold Ohms & Live Ohms
Since neither of the 2xx boards have an on board led, there is not going to be any adjustment available through the Escribe software. You will need to contact Vapor Shark about that issue...Vapor Shark is known for different features on their mods utilizing the DNA boards..they even have there own buttons, not Evolv's, installed on the boards they use for their mods..
kanthal A1/none temperature control preheat/power over time curve
giz_60 replied to jeblesh's topic in DNA 200 and 250
Available for both Windows & Mac... https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/ -
If you are worried about the ohms being to low, you should be good...run .07 coils on my Therion 166...
Paranormal Battery csv file needed
giz_60 replied to Smokin Dave's topic in Manuals, Instructions, and Tutorials
After running the analyzer, click 'Accept'...then 'Upload Settings To Device '...but sounds like you either have a bad cell or a bad battery connection... -
Look up a few posts...
