giz_60
Everything posted by giz_60
  1. Lost_Vape_Therion_133.ecig
  2. @ScaryMonkeyMan Any idea on how to set up the tab order on the screens...
  3. Now instead of 'Edit', it shows 'Options' and the only option available is 'Hide'...also, selecting 'General Discussion' under the DNA 200 & 250 section is showing a blank page....at least for me it is....
  4. Thanks...I knew what it was doing but couldn't seem to find it...
  5. @James Maybe we need to start a thread for forum issues...I tried to edit a post, got a message the page wasn't found & now the 'Edit' link is gone from all of my posts Edit: Now it's back...but still missing on previous posts
  6. And also how to set the tab order on the screens?
  7. @VapingBad On several of the screens in your theme, you have conditions set if false, the pictures are hidden, like in the following screenshot...question is, where are you getting the hidden from?
  8. Well..after having the issue, I had removed some things to help resolve the issue & now I can't seem to replicate it. If I run into this again, I will send you the file... (Off topic, I had 1 message in my inbox & tried to compose a new message but got a message stating Inbox was full & couldn't compose a new message. Deleted the message, sent myself another & got the same results again. Not sure if this is normal or not.)
  9. @James Thanks...another quick & possibly silly question. Recently received the Out Of Memory message. Went to check Space Used & got the message again. Deleted a couple of fields from a screen & was able to bring up the Spaced Used info....Now the silly question....what is the difference between the 2 memory slots listed? I know it should be obvious, but....And is there any way to utilize more of the On-Board Memory?
  10. @James When setting up a field to display the USB charging current (Miscellaneous → USB → Current), regardless of the battery's charge level, it is always showing 0.75A on the device screen. Inline meter is reading 0.11A on a fairly full charged cell, but the device is always showing 0.75A ? Only when the cell is fully charged does it change...to 0.00
  11. Just a suggestion if someone is attempting to make changes that Escribe 2.0 isn't allowing them to...
  12. Until all the bugs & kinks get worked out of the new version of Escribe, one could install the old version of Escribe as well, so as to make proper adjustments to the non-C board...just a thought...
  13. Yup...same thing happening here as well...I caught that earlier on, but just kinda got used to it... Keeps locking no matter what you have it set for..either on the 'General' tab OR on the 'Lock' screen in the theme...
  14. On the 166, from the factory, profile #5 (Pwr ctrl) is what would be used for Kanthal...
  15. It does with the 75C, but not the regular boards...always reverts back to the default...at least for me it did...
  16. Could be...good to hear ya got it...
  17. Have you tried loading it into Escribe? It is a .ecigtheme file not a .zip file...at least that's what downloaded for me...
  18. If I am seeing it right, @VB has it set up correctly...with a TC coil you should see the indicator... and with a non-TC coil, you should see a indicator for the coil...and the 'PH' will change colors accordingly...if you click on the conditions at the top, you will see the differences...
  19. James, Unless I am missing something, it seems that whenever a screen is set to 'round robin', when it goes from the top field to the bottom field on the screen & visa versa...the 'status' is not updating to what is entered for that field, but rather retaining the 'status' of the field it was last on...hope that made sense...
  20. A lot of people are having issues with SS316L & having to turn up the temperature. Think it has something to do with wire quality...I am running SS316L at 410F (210c) & it is working good...try loading this SS316L .csv & see if it helps... SS316L.csv
  21. Much better...the 'temperature protected' is just a message letting you know that you have achieved your set temperature & the device is protecting the temperature from going any higher...
  22. If you look at the 'Live Ohms' graph, you will see it fluctuating up & down...you still have something amiss...if you are using contact coils, try spaced coils...
  23. If you open Escribe to the DNA 250 version with no device attached...this is the screen you will get...which is what was used in the screen shot you were originally referring to...was only using this as an example to show how to load a .csv file into his device...
