giz_60
Everything posted by giz_60
  1. Double check the tightness of the screws on your build deck. Clean the 510 pin on the atty & connector on the device with iso alcohol...if the resistance is fluctuating for some reason, it will switch to Power mode...
  2. That screenshot was taken from the Evolv default setting...wasn't referring to the Wh's in that post...but rather, how to load a .csv file...
  3. The ohms reset because it switched into Power mode...try removing your atty...let is cool down to room temperature & the attach & try again...If device ask if 'New Coil' after cooling down, select Yes...Can you post another screenshot of the General tab showing that Profile?
  4. It appears that the wattage is hitting the setting you have for pre-heat (35w) and then dropping back to the 30w you have set for Power in the Profile. Try raising these values up some...
  5. First off...THANKS James I know this has been suggested in the past, but one feature that would be nice to have on all devices is the ability to hide, or not load, unused profiles, from the General tab, to the devices. (? Hide Profile On Device) For instance, only 4 profiles being used...and if on Profile #4 & want to switch to #1, round robin instead of having to scroll one way or the other.
  6. Hank III Theme.zip
  7. Can you post a screen shot of the Mod tab in Escribe & one of the Device Monitor...
  8. Not off your rocker at all...i basically did the same thing because I wasn't happy with the Steam Engine TCR value...I have all my devices SS316L TCR set at .00105...and thats for my hand rolled coils....
  9. Can you post a screen shot of Device Monitor
  10. How about a screen shot of the 'Mod' tab in Escribe... Edit: And post it as a photo so as to have a bigger image to see...
  11. Let it sit & charge for a bit...don't vape or anything...it is showing that the device is charging, so may be weak batteries causing a slower charge time...be patient & give it some time...if it still isn't going up, you might want to try a different/newer set of batteries...you can check the true age of your batteries here...https://batterybro.com/pages/18650-date-code-lookup-tool
  12. The Wh's for those cells is closer to 16...a value generated by running the battery analyzer
  13. Your cells appear to be charging.... .534a....give it some time. Your Wh setting for those cells is a bit high...around 16 is where it needs to be...thats not going to affect the charging, but only help make the battery indicator / %, a bit more accurate...
  14. Can you post a screen shot of the 'Mod' tab
  15. But, if it was the 20 hour syndrome, then wouldn't all SS coils be affected? I had a similar issue, at one time, but with a different brand atty. The pre-made coils would work fine, but when using the RBA deck, TC would be all wonky. Put the deck in a different base, & a wonderful vape. Turned out there was some machining issues with the base of that particular atty & the 510 pin in the base wasn't making good contact with the deck but continuity with the OEM coils was good...that one drove me bonkers for a spell...
  16. If you are getting a good vape from SS coils you build, but not from ones that are per-built (manufactured), then it was seem that your issue is with the 'manufactured' coils....not the DNA boards...otherwise, it would be an issue despite what SS coils were being used...QC?...just a thought Edit: In your original post, you did mention that you are using the eleaf & aspire coils..however, you neglected to mention that your home builds were working fine...lack of info lead everyone to believe that it was a universal problem across your devices with SS material...
  17. Samsung_25R5 (2)_18650_2500 mah_16.92Wh.csv
  18. http://batteryuniversity.com/
  19. Not necessarily...just closer to the actual Wh you will get while vaping...
  20. Try lowering your Wh setting to 19.
  21. Can you post a screen shot of the 'Mod' tab in Escribe
  22. Yes, in Device Monitor, bottom right corner..'Reset Statistics'...then 'Upload Settings To Device' in Escribe
