Everything posted by giz_60
Therion 166 check battery issue
giz_60 replied to SpecTrum's topic in EScribe, Software and Firmware
A common problem with the Therions is having a bad solder joint connection on the bottom side of the battery sled.... -
There is no way you should be seeing more than 4.2v on the 75 board...are you sure you are not mistaking it for another of your mods...like your Drone BF? Edit: With the cells in a parallel configuration, they will show up as 1 (4.2v) cell....not 8 something (series configuration)
You need to keep in mind that the 75 board & Escribe do NOT monitor each battery, but sees the 2 batteries as one since they are in a parallel configuration.
Lost_Vape_Therion_75.ecig
Running the case analyzer in Escribe should get you the values you need...battery needs to be at 50% or less...
Sounds like the on board fuse may be blown. The 200 board doesn't have reverse polarity protection, so if you inadvertently inserted a cell backwards....If the fuse is blown & you want to replace it yourself, the info on the fuse is in the DNA 200 datasheet...dna200.pdf
Contact Evolv..they will guide you...
The cell 2 voltage indicates an issue with the board...you can open a ticket with Evolv & they can guide you... https://helpdesk.evolvapor.com/index.php?a=add&category=1
Device Monitor while running Battery Analyzer
giz_60 replied to TKnapa's topic in Batteries and Charging
No...can't share the same data path... -
Font on the main screens is not adjustable, just the screens that can be customized...as long as the rounded display opening is the proper size, no info will be cut off...
Just got my paranormal 166 want to get 316l for tc any help
giz_60 replied to Dtgodmage22's topic in DNA 200 and 250
Not sure if this is your problem, but others with the Paranormal have been having an issue with the resistance reading a bit to high, due to the installation of the 510 connector, which will cause the board to not see enough resistance rise while firing, causing it to drop out of TC into Power mode...Can you post a screenshot of 'Device Monitor' while firing with the following boxes ticked..Power, Power Set, Temperature, Temperature Set, Cold Ohms & Live Ohms. Here are a couple of thread pertaining to this issue... https://forum.evolvapor.com/topic/69115-lost-vape-paranormal-wrong-resistance/ https://forum.evolvapor.com/topic/69140-paranormal-75c-resistance-too-high-fix/ -
Try spaced coils... -
Being that it is a used mod, I would be suspicious of the condition of the Lipo battery...
What atty are you using? -
Did you change the battery setting from 3 cell to 2 cell on the 'Mod' tab, battery section, in Escribe...and then upload settings to device?
Try going into the Theme Designer...Screens...select the main screen...click on 'i' icon....'Action>Set>Go To> Child Screen' & then select the screen you want it to go to...(Info Menu ?)
Weak battery on new boxer 20700 mod dna75c
giz_60 replied to Moncrieffey's topic in DNA 75 Color and 100 Color
https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/ Look for the Escribe 2.0 SP8 (newest version) for the 75C...there is a version for Win & Mac available... -
Evolv has been diligently updating the firmware since the 75c's were released... Escribe should let you know if one is available.... -
In Escribe,(Mod > Battery) check the value of the cell soft cutoff...2.75v is good for the 20700 cells...the following .csv file was generated with the 'Battery Analyzer' & will help the battery indicator to be a bit more accurate as well... IJoy_20700_3000mah.csv Edit: Even most of the new mods on the market will need a firmware update...Escribe should let you know if one is available.... -
Weak temp control vape with ISub SS coil
giz_60 replied to Toronto Tonto's topic in DNA 75 Color and 100 Color
I have since gone to build yer own atty's & have never looked back. A lot of people have had success with atty's with OEM coils, so maybe they can chime in with their suggestions & experiences...can say this for sure, stay away from any of the SMOK TFV atty's because they have a floating pin in the base which will cause some really wonky fluctuating resistance issues...even with their build decks as well...just my 2 cents... -
When I first switched over to using DNA mods, which I did to get a good TC experience, I too had alot of issues with the ISub coils in TC mode. Gave my ISubs to a friend who vapes strictly in wattage mode because of all the headaches... -
I tend to agree with @retird, looks like you may be having a wicking issue...It's reaching temp according to Device Monitor... OEM coils can cause these issues -
Can you post a screen shot of 'Device Monitor' in while firing... -
It looks like there is an issue with the device...if still in warranty, I would contact the vendor you purchased it from about the warranty...or you can open a ticket with Evolv...https://helpdesk.evolvapor.com/index.php?a=add&category=1
Can you post a screen shot of 'Device Monitor' as well...
