I've used the new update for 24 hours now with no problems. I love it if can now jump between different tc coils without having multiple profiles step up for the same tank. I liked my dna200 before, but now it's a home run. Thank you
VapingBad said:
[QUOTE=jarred.sayles]I have the new update. How do you change materials on the same profile on the mod though?
lock then hold down all 3 buttons for a few seconds[/QUOTE]
Thanks for that info!
You know if there is a place that lists the updated changes, button presses, etc...?
In the change log in the first post perhaps ?
This version features:
(1) a new Materials tab where you can store and transfer material settings onto and from the DNA,
[We've included our Ni200, and Steam Engine's SS316 and Ti1. These will be upgraded in the future, if better data becomes available, and others added if others become common.]
(2) the ability to change a profile's material without EScribe, by holding down all three buttons while locked,
(3) Profile Name and Material Name can be displayed on-screen as custom fields,
(4) profiles now have a "Temperature Dominant" option, making temperature the main adjustment for a profile if you want to do so,
(5) for small batteries, in the Mod tab, you can reduce max continuous and pulse battery input currents,
(6) in Help->Language, you can override the language detection,
(7) Device Monitor has "Simulate Button Presses" for remote testing,
(8) Device Monitor can run Python scripts for scientific study and automation,
(9) the ability to adjust the temperature increment, and
(10) various OS compatibility and miscellaneous improvements.
RoofMonkey911 said:
[QUOTE=VapingBad][QUOTE=jarred.sayles]I have the new update. How do you change materials on the same profile on the mod though?
You know if there is a place that lists the updated changes, button presses, etc...?[/QUOTE]
You're welcome
1st post of this thread
so far big plus on the temp dominate choice, material storage , the added battery specs makes it all the more better in my book. took a bit but so far i like it.
there was one error i came across while uploading materials. it might have to deal with csv file names with numbers. like 1.csv for example
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index and length must refer to a location within the string.
Parameter name: length
at System.String.Substring(Int32 startIndex, Int32 length)
at A.Fe.hh(String )
at A.Fe.M(String , String& )
at x.DT.yq()
at x.DT.yb(Object )
at x.qF.ak.w(Object , EventArgs )
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34209 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
DEScribe
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/EScribe.exe
DimensionEngineering.Common.Windows
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/DimensionEngineering.Common.Windows.DLL
Win32 Version: 4.0.30319.34250 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.34262 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Win32 Version: 4.0.30319.34239 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/DimensionEngineering.Common.DLL
DEScribe.Core
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/DEScribe.Core.DLL
DEScribe.Branding
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/DEScribe.Branding.DLL
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/DimensionEngineering.DLL
System.Xml.Linq
Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.0.30319.34230 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
IllusoryStudios.OpenSsl
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/IllusoryStudios.OpenSsl.DLL
DEScribe.PluginApi
Assembly Version: 1.4.0.0
Win32 Version: 1.4.0.0
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/DEScribe.PluginApi.DLL
DimensionEngineering.PluginApi
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/DimensionEngineering.PluginApi.DLL
System.Security
Win32 Version: 4.0.30319.34248 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
SecondLanguage
Assembly Version: 1.0.3.0
Win32 Version: 1.0.3.0
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/SecondLanguage.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
NBit
Assembly Version: 1.2.1.0
Win32 Version: 1.2.1.0
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/NBit.DLL
ICSharpCode.SharpZipLib
Assembly Version: 0.86.0.518
Win32 Version: 0.86.0.518
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/ICSharpCode.SharpZipLib.DLL
IllusoryStudios.Math
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/IllusoryStudios.Math.DLL
EquationParser
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/EquationParser.DLL
HidSharp
Assembly Version: 1.9.0.0
Win32 Version: 1.9.0.0
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/HidSharp.DLL
SaberUpload
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/SaberUpload.DLL
Mono.Addins
CodeBase: file:///C:/Users/lordmage/AppData/Roaming/Evolv/EScribe/Mono.Addins.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
black lace said:
[QUOTE=mknight]My computer keeps telling me that the signature is corrupt or invalid
yeh, mine did that so i just right clicked on the warning and selected install anyway..[/QUOTE]
Mine did that as well. Norton was telling me it was alright but Windows 10 was giving the warning. Installed without a hitch as soon as I clicked on install anyway.
Cheers,
Steve
Bobdudeman1988 said:
how do you change profiles on the mod with the new update..i cant seam to figure out how to do it. you used to lock then + or - to switch..?
Hold the + and - down to lock the power/temperature. Then press + or - twice quickly as Margucci said. It's the same as it was before the update(s).
Cheers,
Steve
not sure why i couldn't figure it out..but i got it. thanks for your help guys.. sorry for noobness
You welcome, glad you got it sorted. Nothing to be sorry about. This is a forum where we are supposed to help each other out. You were having a problem, asked a question, a couple of us answered and problem solved. That's the way it's supposed to work.
Cheers,
Steve
Just a question, at what point do these software and firmware updates get pushed to all the users via the autoupdate built in to escribe?
I plugged in my brand new Lavabox last night and installed the software from the download link on the DNA200 info page (i.e. the main link that is presented to the public). The software did not prompt me to download a new version nor new firmware. Today, I came across this thread and went to check the firmware I was running. Turns out, I was on 8-21-15 (I assume the same for the software, I didn't check). I saw here the recommended release was 10-21-15 so I went ahead and installed that software and firmware bundle. My question is this, if that version is the recommended, why not push it via escribe to everybody? It's clearly not the bleeding edge/testing version as the 2-12-16 build is listed as that. I get that the DNA200 is inherently a device for tinkerers but I would not have found the "latest" software/firmware had I not stumbled across it. So, are ALL the builds listed here not "production"? If not, why is escribe updating itself and devices to a build from 6 months ago?
Hi guys,
have updated the firmware on three of my devices for awhile. Found that material tab on one of my device (a diy box) would not arrange materials on device alphabetically (not even in order of adding, rather a fixed specific order with v3 and v3.5 ss on top) as compared to my other 2 VT200.
edit: fixed by swapping mod parameters with working saved files. (sorry that I saved over the faulty file but its all fixed now :) )
retird said:
Go to post #1 and take your pick of updates. I've used them all including the latest one.  :)
So does that mean that the auto update doesn't work? What version would you recommend to be updated the least?
Thanks for the response! :D
