Everything posted by Pphish
Places to buy DNA 250c Enclosures for custom builds
Pphish replied to shroomalistic's topic in Modders' Forum
Pm me the price? -
Just the enclosure or the board, wiring,etc? -
Out of 3 DNA mods, countless atomizers, countless builds...I have never once been able to turn the atomizer analyzer even less than a quarter without the reading changing.
Floating 510 pin... Not great for replay or temp control.
Oh I see lol... Sounds like your may want to read up on changing your mods internal resistance... Also, have you tried any other SS316l mesh besides the nex mesh?
Re-read what you wrote and am deleting my response based on my new understanding...lol
How has nobody asked what atomizer op is using? Of course replay isn't working on stock pre made coils! There are very few instances where it would... Even if the coils say SS there are so many issues with the connection of floating pin atomizers with temp control and replay! If op gets an rda or rta and throws some guaranteed SS316l wire in there,I assure you that replay will work! The fact that op was getting a tolerable experience with same coils in TC only means that OP got lucky. But my guess is that OP is using a smok tank or crown 3; in the case of smok, the coil is not SS only the outer casing of the coil is made of SS and in the case of crown the coil material is an unknown variant of SS. The smok has been known to work in TC and give a reasonable vape... But it will never work reliably and will absolutely not work in replay for many reasons!
Bruh...SS316 and other TC wires have a higher resistance when heated; this how we get temp control! So of course the resistance changes when you hit it a few times and remeasure the ohms!🤯 wait were you joking?! Please tell me you were joking
evolv 250c What i would like to see in the next update
Pphish replied to Vapors Tongue's topic in General Discussion
Not going to happen, and here is why: Evolv designed each profile to have readings independent of one another, this way each profile could theoretically represent a different atomizer. With all the variables that one can change in a profile, it's actually quite nice to be able to pre-set a profile so one can quickly put on a new atomizer and with a couple clicks be ready to have an entirely different vaping experience. You are aware that you could just lock in the cold resistance into all of your profiles and that can literally be done without even having to use a computer! It would undermine the entire reason the profiles are there in the first place. -
Was wondering what the Nuclear model would look like... I've got my eye on the universal 2x21700 squonker they have up. That will likely be the enclosure I use to build my first device. Not trying to knock on you or anything but I can run my paranormal 250c for slightly over a day at 100-105 watts with my Sony VTC5a and VTC5d(vapecell re-wraps)... But more power to ya! Building a mod had got to be much more satisfying than buying one anyway. What how long is the battery life on your device?
Yeah but that also removes all the profiles and material that I've added to the device. Are you certain that the device stores old themes that you are no longer using? If so that seems like a bit of an oversight on the part of Evolv... Sounds like something should be remedied in the next firmware update ( @James)
Replay function send based around core wire... So use SS for at least some of the core wire... Don't think it needs to be all though. Interestingly enough though you can use a different material for core wire(N80,N90,etc)and SS other wrap, and while replay doesn't work... Temp control will! I've been using N80 cores with SS wrap and then running in temp control with material set to SS316, and TC works flawlessly! Alternatively, SS cores and N80 wrap works with both replay and TC-SS. Running framed staple aliens in my Themis now with all N80 core with 34g SS wrap and use both TC and wattage with great success... No replay;though, I haven't tried it on my Replay PK profile to see if it works with that.
How did you do it?I didn't realize that themes accumulated on the device after a new one was loaded on...
Pre-built coils and wire from Advanced Vape Supply are A-OK
Pphish replied to ajoe's topic in Replay and Atomizers
Love my Boaz! Great connectivity... Amazing for temp control! And love AVS, but I Clapton my own wire now and they are too expensive and don't sell spools longer than 100 ft. But seriously amazing company; I'm in Colorado and hoping to work for them actually -
I really liked the way that RTA looked... But seemed to have one fatal flaw; the positioning of the grub screws on the deck,I use a lot of flat wire types that would be misshapen by that deck. Plus I already have a Themis which I love and the Juggerknot sense too similar to drop $60 on. What are your thoughts?
And I'm using the Gauges theme
I kind of thought it might be and I thought about adding a disclaimer since you said you were using quad cores which def don't need as many watts or as high of a temp. I would do the set temp between 495-505 with the pre heat temp set to 460_465 I would still give it 80-85 Watts for the set wattage and 95 for pre heat wattage. As a rule of thumb , set the pre heat temp about 20-30 degrees lower than your set temp and set pre heat wattage about 10-20 watts higher than your set wattage... That way there is no sudden dip in vapor production. And yes my coils are beefy...I should have used some N80 or kanthal in my build to bring the ohms up; but I used all SS316 and it does read .042 lol.i do not suggest building this low you can get better performance and flavor with higher ohm builds.
Dude this is nothing to do with your device. . Look at your settings! You must understand the parameters you're working with in temp control... You are using 125 WATTS(which is way too much to begin with) to pre heat to 525 F->as soon as your coil hits 525->it drops down to only using 40 WATTS(which is way too low for .12 ohms) at temp setting of 475 ( 50 degrees lower than your pre heat... That doesn't work) Try this: Get this: This is with some wire I wrapped myself: SS316L 24g /32g x 3 with 32g-> that's three 24g staggered Clapton cores wrapped by 32g then fused together with another 32g overwrap->for a fused staggered Clapton
multiple ui Gauges - Major update 2.0.0
Pphish commented on SirTimmyTimbit's file in DNA 75 Color, 100 Color, 250 Color
- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
Are ohms stable? Can you tell us a bit more about the build and the temp settings you are running it at? Also what happens if you put it in Watts?
I brought up the same point to the designer, and you can see his response a few posts up. He made using a temp sensing coil a condition of the ability to save the puff, effectively limiting the functionality of replay. I don't think he meant to exactly, he didn't realize that this was already an inherent function of replay that didn't need to be added. I modded the theme shortly after the 2.1 release to regain the ability to use replay with coil material set to Watts. I can share that file with you if you would like.- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
If you look through the modding forums, they have a thread that had all the links you need
I agree with retird, but I'm also wondering what mod you have? My paranormal was set to .004, but I brought it down to .0038; my friends paranormal was also set to .004 but I took her down to .0017 to get a correct ohm reading. Before tinkering with mod resistance perhaps see how ohm reading vary between your 250c and some other mods. If they are reading about the same resistance, then try running case thermals(be prepared to wait) in escribe. Also where did you source your SS316? Are you running in wattage mode on replay? What kind of build do you have in there (like Clapton or gauge)?
Check your mod resistance, calibrate if need be. The Drop RDA works perfectly with SS316 for me, I'm running a .064 build in it at the moment
Sounds to me like a mod resistance problem, or likely an unstable connection in the atomizer itself... Especially if replay mode causes dry hits
