Everything posted by Pphish
Someday Bruh...
Where did you manage to buy one? I thought they only shipped in the UK and EU...
New DNA user - Poor TC performance
Pphish replied to pahpahcee's topic in DNA 75 Color and 100 Color
I think your settings are set quite low for that build. 375 is low for just about any build, I would start with 450 and go up from there, also set your wattage higher, the DNA board will only use what it needs to get to the set temperature. What about other parameters? Pre heat and temp dominant, etc? That being said, I have never been able to get a good vape on SS430,I wish I could though as some people swear by it. My last attempt was on a drop RDA with dual core clapton's from AVS... It was working well, but I think I maybe damaged the wire somehow... If you are successful in getting a good setup, I'm def interested to know how -
I'm honestly surprised you managed to get to the board without destroying the battery sled
multiple ui Gauges - Major update 2.0.0
Pphish commented on SirTimmyTimbit's file in DNA 75 Color, 100 Color, 250 Color
So in your replay enabled profile , it will certainly allow you to use SS316 with Watts chosen as the material type and offer to save the puff... The problem I was referring to adding a redundant feature is when you try to turn replay off via Gauges 2.1; once you turn it off, you can't renable replay with coil material set to Watts. At which point, you must limit yourself to only using replay when the material chosen is temp sensing. But yes thus far Evolv 250c has a way to test whether the coil material is temp sensing, the feature is built into the firmware. As such it won't recognize KA1 as a viable coil to offer to save your puff in regular old replay. I really like the toggle, unless you had a different condition in mind to replace it. But I personally like that, I can tweak some of those features without connecting to a pc thanks to you. Just disable the condition that limits the toggle to temp sensing coils and then it works perfectly. I don't know if you can incorporate PK mode into your theme, but you could possibly manage to allow others to use it by creating an ecig profile to go along with the theme... Still because it's a hidden setting, it may not work in an ecig profile- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
I was wondering about that myself recently, as I'm going to start building some of my own Clapton's once my Daedalus Pro arrives!I can't say with any certainty that replay would identify as a temp sensing coil and offer to save the puff: esp since N80 isn't actually temp sensing wire. But adding the Replay PK profile and enabling the option for unlikely coils is easy enough to do, so regardless you should be able to use it with at least one of the the profiles. I would imagine that with an N80 core and a SS outer wrap fused Clapton (I don't know how well staggered would work under the same conditions so would suggest fused for the crest results), that the mod(also deck dependant) would register the material as SS316 thus allowing for regular old replay... But I could be wrong... Let me know if you have any success!
It's just a redundant condition to add to the theme, as the chipset already does this without limiting the ability to change material type to Watts. KA1 and N80 users already have to enable the hidden PK function and create a Replay PK profile in order to use Replay with non temp sensing coils... Normal replay profile will allow them to fire their atomizer but won't offer to save puff unless it detects you are using TC ready material. The default theme comes with Replay profile coil material set to Watts anyway:so adding another condition on top of that to the theme just takes away some functionality natively allowed in escribe and controlled by the chip already.. Also one of the co-founders of Evolv even discussed how Replay was geared towards people who didn't want to take the time to configureTC, but wanted to avoid dry hits and get the same flavor throughout their vape. The feature was marketed as TC for wattage only users. I know how to disable the condition in your theme so I can run my SS with Replay while using Watts as the material type, but the original functionality and idea for replay stems from the small amount of TC vapors amongst DNA chipset owners. I've already removed the condition from your theme myself but for who don't know how or just don't want to bother to modify the theme to allow for their vaping style, they will simply move to a different theme. Removing the condition still won't allow users to save the puff for non-temp sensing coil material, but it also won't restrict replay functionality to TC variables and vape style either; which replay was not meant to do. Here is the link to a video explaining the purpose of replay as told by one of the main Evolv designers: Still love the theme though!- 150 comments
- 2
- replay
- minimalstic
- (and 10 more)
Taken from what I posted in this thread: Going to the upper toolbar in escribe->bring down the drop down menu labeled help->and click the section that says "About"->and then click the middle of the evolv logo between 10-12 times, until it disappears. Head over to your mod tab in escribe, the first section is safety. Under safety there is a swing to adjust the coils replay can use; normally this would contain 2 settings, allow only on temp sensing coils or allow on dubious coils. After following the above instructions a 3rd option appears, "allow on unlikely coils"change to this 3rd option->create a profile named "Replay PK” and user that to vape your Kanthal or other non temp sensing coils. I imagine this would work in multiple alloy coils as well. But I would stick to using Watts for best operation. I imagine you could follow the same process for multiple using multiple temp sensing coils as well, SS AND TI OR NICKEL. Steam engines tool even allows us to create a TCR and (if memory serves) a tfr curve for multiple temp sensing wire types. You could possibly use these materials in Replay PK and change the chosen material type to your downloaded tfr/TCR and use temp control with multiple alloy builds Also same info with pictures in this thread:- 150 comments
- replay
- minimalstic
- (and 10 more)
I know that kanthal does work in replay with (the hidden setting) PK Mode enabled and the proper profile setup. Going to the upper toolbar in escribe->bring down the drop down menu labeled help->and click the section that says "About"->and then click the middle of the evolv logo between 10-12 times, until it disappears. Head over to your mod tab in escribe, the first section is safety. Under safety there is a swing to adjust the coils replay can use; normally this would contain 2 settings, allow only on temp sensing coils or allow on dubious coils. After following the above instructions a 3rd option appears, "allow on unlikely coils"change to this 3rd option->create a profile named "Replay PK” and user that to vape your Kanthal or other non temp sensing coils. I imagine this would work in multiple alloy coils as well. But I would stick to using Watts for best operation. I imagine you could follow the same process for multiple using multiple temp sensing coils as well, SS AND TI OR NICKEL. Steam engines tool even allows us to create a TCR and (if memory serves) a tfr curve for multiple temp sensing wire types. You could possibly use these materials in Replay PK and change the chosen material type to your downloaded tfr/TCR and use temp control with multiple alloy builds
Hmm... So I originally downloaded the first 2.1 version you posted on Friday evening, and installed that; I then saw that 2.1 had been re-released on Sunday morning with enable/disable replay functionality(I live in the US, mountain time zone or UTC/GMT -6 , so the time frames I'm referencing might not match with when you actually uploaded the files). Rather than installing the new version, I figured I could just enable the feature myself by tweaking the first version of 2.1 that was released, but I figured I would compare the first and second versions to see if I noticed any differences in the implementation of the enable/disable replay toggle (I hope this making sense). When I couldn't see a difference in their deployment, I just decided to tweak the first release on my own. I changed the default condition for the toggle to not be greyed out from "atomizer is temp-sensing material=true"to "atomizer can replay=true". That didn't work, so I then deleted the condition all together and just left a toggle for "atomizer can replay" which worked. I only use SS316L Clapton wires from Advanced Vape Supply, however the toggle's functionality in the first version of 2.1, wouldn't allow me to reactivate replay in my profile if the material chosen was set to Watts, it did function if I set the material to SS316... But depending on what juice I'm vaping, atomizer I'm using, or if I'm in the mood for temp limiting will make a difference in whether I use my SS316 build with my 250c's coil material set as Watts or SS316... And I will often do all of this from the profile I have labeled as "replay" So you see even though I use temp sensing 316, when I use 316 on purely wattage mode and try to use the toggle to enable or disable the ability to use replay...I lose the ability to re-enable the functionality unless I change my coil material to 316 or hook it up to escribe. Now keep in mind I haven't used the last revision of 2.1 you most recently uploaded, so maybe you changed something I was missing that would allow me to toggle replay while vaping with material set to watts... And if you did, where could I find it? Or did you intend for the toggle to only be functional if the coil material was set to something other than Watts? I really hope this all made sense! Sorry for the long winded post! And thanks again!- 150 comments
- replay
- minimalstic
- (and 10 more)
Love the new UI and the ability to switch to the classic UI... Love the new features! I was adding the pre-heat settings on my own b4 2.0, but I just added a new screen for it; your addition is both more practical, functional, and asthetically pleasing. One gripe... The replay feature only being available enable/disable with temp sensing material means that if I disable it while in wattage I lose the ability to use replay on that profile without connecting to escribe and re-enabling the feature... So it's technically only able to be toggled on/off when used in TC mode. As a feature, replay's main purpose was to allow those using wattage mode to experience something similar to temp control; your implementation restricts replay to temp sensing coils, unless previously enabled on the profile in escribe.... Which I don't think is what you were trying to do. I edited 2.1 to make the enable/disable feature functional for wattage profiles by deleting the temp sensing material condition of the toggle and then replacing the picture for the default condition (just to keep the asthetics)... Now it can be used for wattage or TC mode. Not sure if you meant to send it up the way you did or not... Perhaps the temp sensing detect condition would have been appropriate... Though I don't know that my alteration would allow replay on non temp sensing coils anyway (kanthal,N80,etc...) which I believe still cannot be used in replay without enabling the hidden PK function in escribe and creating the necessary profile (though I may be won't about that).- 150 comments
- replay
- minimalstic
- (and 10 more)
I do wish we could adjust pre-heat time like on the 200 & 250 boards; but currently we cannot. As for this timer, how would you see it? And why would you need it when you can just adjust the max puff time? I don't know theme designer well enough but, I feel it is feature that could easily be designed and added to the device. Perhaps not currently, as I said I don't know the capabilities of theme designer well enough to say either way. Though I don't know that pre-heat for 4 seconds would be great for your coil. What kind of material would you be building with? As of now you can almost do what you are asking, just without the stopwatch.
Put escribe into manufacturer mode, and change the max puff time under the safety settings... There is one other place you have to change it too, then install a theme, like gauges, that allows you to control how long your mod fires before shutting off power.
Pphish reviewed SirTimmyTimbit's file in DNA 75 Color, 100 Color, 250 Color
Best theme I've found... asthetically pleasing with a great advanced feature set! Still any chance we could get a page added to tweak the pre-heat parameters, similar to your materialish themes... Basically with additions for pre-heat wattage and target pre-heat temp; while still allowing for punch adjustment. That is the only thing I would change. Otherwise amazing!- 150 comments
- 1
- replay
- minimalstic
- (and 10 more)
I'm not at all convinced that the theme had anything to do with your issues... As far as the issues with the mad modder 250c, there was another person around here who had to send his mod back because of some coating on the 510 connector... I've used and currently use Gauges theme, since before 1.5, and I have literally never seen that message nor have I experienced any issue similar to what your describing. The only time I've experienced the issues you describe were with my DNA 200&250 Triade's, and those issues were always either build or mod related. Something tells me though you have switched themes, this is hardly the end of your issues
This may be due to the most recent firmware update.
And from Mooch's battery test result post for the enook just some great battery advice: Always Remember- There is no 18650 that can have a factory/manufacturer rating over 30A.- There is no 3000mAh 18650 that can have a rating over 20A.- There is no 3100mAh-3500mAh 18650 that can have a rating over 10A.- There is no 18650 with a capacity rating over 3600mAh.
Where did you source your HG2's? You would be surprised how many local shops (at least in my area) sell re-wraps of those brown LG's... Every battery I currently own I bought from RTD vapor; they are a very reputable online battery reseller based out of Pennsylvania, great selection and better prices than your local vape shop, and most importantly guaranteed authentic batteries. I own both a Triade DNA 200 & 250, and didn't feel like buying more batteries when I bought my Paranormal 250c, but already had all these married sets of three batteries. I chose break up some triplet HG2s and VTC5s; I run both over spec, with a 30amp pulse 25amp continuous (I'm in no way advocating this behavior) but get over a days worth of use out of both, but only after changing my theme and the settings I mentioned earlier. Out of the box settings though, I also noticed that my battery life was not going to last for a full day. I can attest to the quality of the Sony VTC5A... Best battery on the market, and you won't damage the cells running them with a 30a pulse and 25a continuous discharge...2600mah should last you over a day with a bit of tweaking. I'm currently using the latest firmware with, hg2s or VTC5s (not to be confused with 5A) at the specs I mentioned above, using the Gauges theme, on my Paranormal mounted with a Digi Flavor Themis running a dual SS316L stapled Clapton build coming in at .074 and powered by 91watts... Still getting over a full day out of a single set. So it is possible...
You didn't change any other parameters in escribe? Are you using the stock theme that came on the Paranormal? The stock battery values it came with have a 35amp peak and a 30amp continuous discharge rate if I remember correctly... Which is way too high for any 18650 battery that I know of. Since your battery is 3200mah and not a well known brand, I would guess they have a max continuous discharge rate of 10-15amps. You will want to change the parameters to run close to spec for your batteries. Also turn on stealth mode. I have my Paranormal's screen turn off while I'm firing and changed the amount of idle time till the device locks from 60min to 10min.
Question to all the guys with Paranormal DNA250c
Pphish replied to Abadaman's topic in DNA 250 Color
I did the same after spilling a bit of juice. Impressed with build quality for being the lowest price option for a DNA 250c... And the best looking option IMHO. I haven't seen a single Paranormal unit where the 510 sits flush with the mod... It not a protruding 510 pin so much as a raised lip on the 510 connecter. I've had the device about a week and half and have already gotten over it. The Paranormal 250c is easily the best device I've owned or tried. I do want to try and make my own lipo 250c... But thus far I'm not seeing any chassis that I like. I'll give it time. I can live with the 510 connecter the way it is, the device is still handsome and functional as any unit I've owned- 18 replies
- 1
- resistance
- temperature
(and 1 more)
Tagged with:
That's what I guessed. With that many inner wraps it would yield anywhere from 1.1-1.13 ohms depending on the mod Check out Vape Tool app for either Android or iOS. The free version will work for your current needs. The pro version is great. It's basically a simplified version of steam engine with some more in depth explanations of the parameters you are inputting for the calculator. I use it everytime I build, though steam engine is just as capable- 18 replies
- 1
- resistance
- temperature
(and 1 more)
Tagged with:
Try more than one build b4 jumping to conclusions. Just looking at your photos, I'm counting 9 inner wraps and 2 half wraps which would bring your total to 10... Correct me if I'm wrong. Also what was the inner diameter of your coil? It's almost always the atty or the build having issues b4 the actual device itself.- 18 replies
- 1
- resistance
- temperature
(and 1 more)
Tagged with:
What's the internal resistance if your mod set to? I feel that is the most likely culprit, or is it reading ohm correctly?
Thanks much! I noticed that your theme has revision 34 for the firmware...my Paranormal came with revision 33 and escribe hasn't prompted me to update the firmware. Is there an early release I'm missing?
Was your mod resistance reading something other than. 004?
- 22 replies
- paranormal
- dna250c
(and 1 more)
Tagged with:
