giz_60
Everything posted by giz_60
  1. Yep...there is a known bug concerning the date(s) that is supposed to be fixed in the next update...
  2. There are no adjustable settings to change that...
  3. The Smok atty's are notorious for causing weird problems due to the floating pin in the base.
  4. I have 4 75c devices...1 purchased & 3 I built...1 has over 30,000 puffs & 1 over 40,000...haven't had any major issues...really enjoy this board!!!
  5. In Theme Designer, under the 'Language' tab, you can set it as needed...
  6. I believe most of that info can be found in the 250 data sheet...https://downloads.evolvapor.com/dna250.pdf
  7. I would contact who you purchased the coils from. A lot of fakes out there!
  8. The Paranormal's have been having issues due to LV using a loctite compound on the threads of the 510 connector. This could very well be causing the problems you are describing. You can read about it & a fix here....https://forum.evolvapor.com/topic/69140-paranormal-75c-resistance-too-high-fix/ Or you can open a ticket with Evolv & let them guide you...https://helpdesk.evolvapor.com/index.php?a=add&category=1
  9. The fact that the single coil is working & the dual is not, is an indication that the issue is not with your mod. Smok attys are know for causing issues due to the floating pin in the base...
  10. Contact Evolv & let them guide you... https://helpdesk.evolvapor.com/index.php?a=add&category=1
  11. Run the 'Battery Analyzer' in Escribe with your RDA set up like this...with the fan blowing on it to keep it cool... Edit: As @Wayneo stated, the .csv is only going to affect the battery % reading...
  12. A screenshot of Device Monitor in Escribe would be helpful
  13. Sony_VTC5a (2)_18650.csv
  14. Or..you can set up a toggle control in your theme to flip the screen either way...
  15. LV Paranormals have issues...https://forum.evolvapor.com/topic/69140-paranormal-75c-resistance-too-high-fix/ This thread is about the 75c's, but the problem seems to persist across all Paranormals
  16. Judging by your manual, it looks like they are recommending to NOT use that atty in Temp mode, rather wattage/power mode...the stock profiles on the VT75c for wattage/power are profiles #2 & #5...try one of those & adjust the wattage as necessary...
  17. You can always try reloading the factory .ecig file...it's possible it got corrupt somehow... Lost_Vape_Therion_133.ecig
  18. Also...will drop back a year every time you cycle through the date settings on the device...at least on mine it does
  19. Board issue...contact Evolv & let them guide you...https://helpdesk.evolvapor.com/?a=add Inboard cell is #1 & out, #2
  20. This was posted by @retird awhile back... This was posted earlier by Evolv: ( my memory is not as sharp as it was when I was 65) " DNA 60 can't really use Thermal meaningfully, because the charging is off-board and it doesn't know much about it. The defaults should work well enough." Don't have the .csv for your cell, but do have one for the Efen 20700, which is a 4300mah cell...or the IJoy 20700, 3000mah....should get ya closer than the HG2's Efan_20700_4300mah_11.57 Wh.csv IJoy_20700_3000mah_8.045 Wh.csv
  21. https://forum.evolvapor.com/topic/65710-topic
  22. In Escribe, on the General tab, if you click on 'Get Information', it will bring up the serial number & the manufacture date, or you can search it from the Evolv website...https://www.evolvapor.com/sncheck
  23. Lock device (click fire 5 times or what you have it set to) and then hold the up & down button for a few seconds...
  24. In Escribe, open Theme Designer & go to the 'Look & Feel' tab
  25. Being that is is a BF device, there is a really good chance that the previous owner had gotten some juice leaked into the device. You might consider cleaning the internals, or you can contact Evolv & let them guide you...https://helpdesk.evolvapor.com/?a=add
