You need a minimum of Escribe SP18 for Mojave. Escribe Link found in my sig.
Vandy Vape SS316L Fused Clapton Wire (24ga*2+32ga)
Wayneo replied to Lanzarotechris's topic in Replay and Atomizers
Your post was edited, but you might want to describe how they had you build your new coils so others can benefit. -
Paranormal 75C resistance too high FIX
Wayneo replied to ThatGuySwain's topic in DNA 75 Color and 100 Color
@asmcriminalConsidering this ^^^ from over a year ago, what can I say. You can open a ticket with Evolv. Link in my sig- 45 replies
- 1
- ohms reading high
- paranormal 75c
(and 2 more)
Tagged with:
@steamer861 SP18 now available, and works. Link in my sig.
In your other post, you were already told 30 watts, boosting to 40. The answer will not change. Boost and warmth - 11. Tiny 900mAh battery (large for pods) Many are vaping in the 11 - 13 watt range on these non rebuildable pods. This is not an Aromamizer Titan atty holding 30ml of juice sitting on a 400 watt 4S Lipo.
N80/Ni80 is a good old regular power/watts material (wire). No profile required. Having said that you can download curves from steam-engine or create your own within escribe 'Materials' tab. Welcome
All I can think is that perhaps the coil was not at ambient temp when you went into temp control. Maybe take the atty off your mod, hit the fire button so the mod shows check atomizer, let the atty sit for a bit (say half hour), reinstall atty answer 'yes' for a new coil if prompted. Ideally it'll show a resistance lower than before. If that doesn't work, What kind of atty, and can you describe the coil
Is your mod is actually a 3 button color screen Paranormal 250c? Last I checked the online manual was not for these newest boards. I'd suggest you start with a YT video or two. This one's pretty long but DJLSB Vapes is quite thorough. The 75C and 250C both have the same interface/themes.
What type of material are you using AND post the link for the material file
replay Gothic DNA250C / DNA75C Replay & Power bank
Wayneo commented on copyman's file in DNA 75 Color, 100 Color, 250 Color
- 11 comments
@iltrainu Sp 18 is the latest and works. Link in my sig.
Sp 18 is the latest. Link in my sig.
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Lost Vape Paranormal 250C
Wayneo replied to BrodatyVape's topic in Connectors, Components, and Accessories
My Rhombus panels are attached. No suction cup or alternates in the package. -
That mod's not Color (unless there's an update from March 2017), VT75D looks decent but not their latest.
There's also a new Vapcige, Thinkvape Finder (2&3 battery), MadModder I believe, JacVapor Scotland. Around my area I'm now seeing mainly unregulated squonk mods, or high nic pods out the ying yang. I'm using my BB as a mtl box at 3x my regular nic when running around.
I wouldn't do that. Lotsa good info here. And welcome.
Yes Choose from the last 3 of your Printscreen. Details for each are on that same link for them.
I'm using my own theme. There are many, some better documented than others. Here's one that I tested, for starters and replay enabled.
SP17 had an issue. I'd use 15 or 18. 18 Intl found here (last post). IIRC, if you look at Profile 2 (Device Monitor), it's called Replay
Can you swap the battery position of those same batteries within that mod, and see if that sag follows the battery. Printscreen afterwards appreciated.
My opinions only Seems like replay is very much based on vw mode? <- Seems so, to me. And this is how I've used it. Do you think it’s even worth getting a replay enabled on tc? <- I do not
Minimum replay requirements: DNA250C or DNA75C (Mods with a color screen) International firmware installed Theme that's replay enabled At least 1 of your Profiles with 'use replay on this profile' ticked, and set for use. BUT Material Type set as 'watts' Coil made from a TC wire (material), like Ni200, SSxxx, Titanium. Easy way: Adjust watts on your mod till you're getting a 'great' puff. After your 2nd puff your screen should be showing something different than the first puff, like (ready, or save puff). Select that option. Ideally your screen should now change to 'replaying' or whatever's in your theme. Your mod will now attempt to duplicate that puff for you, until you quit replay. Similar to TC, you'll get dry burn protection. DJLSB Vapes has a couple good YT videos on these C boards and replay. 'Search' works here for some of the finer points like warmth or boost punch once you get the basics down. Good luck.
Eleaf MELLO 4 tank with standard coil 0.3 ohms
Wayneo replied to osf's topic in Replay and Atomizers
In TC you need to talk temperature primarily. Watts (40 in your case) are only required to get your coil up to the temperature you want to vape at, or limit the watts supplied to the coil. Using a SS profile, and set for TC at 40 watts, you can monitor the temp attained and watts used for it. Cool or hot depends on you and your lungs. Maybe start at ~400F, and adjust temp either up or down. -
Which coil material should I use: SS 316, SS 430 or Kanthal All will work on your mod in power/watts mode. SS316, SS430 for Replay Why can I set the temperature with a Stainless steel coil Because the wire (material) changes its resistance when power is applied. Same as Ni, Ti, and others. These are your main TC or 'Replay' materials (wire)
