60 vape doing weird count down to 1 watt when coil attached
Wayneo replied to John Spano's topic in DNA 60
Does it have a USB port? -
I'm in Canada so no idea. I think they kept pushing the release date out. Between the door closure issues, ultem to not ultem, blah blah blah 😎
Wow! I haven't started squonking yet. My 'Information' shows this, but no clue what batch it would be.
@etab75 LV has a repair centre right there in the UK if you don't wanna take it apart yourself.
My drone is less than 2 days old and I'm still setting it up. I haven't actually squonked on it yet, but I know what I might find. I'll let you know if I got a leaker
All of my LV C chips have come with around 6 puffs and 1 reset.
I'm not a Windows guy, but usual things to try are a reboot and plugged in directly. Try running as administrator, different USB ports as well as different cables
Minimum Replay requirements DNA75C, 250C, or GO International software installed Theme that supports Replay Success best practices Ni200, Ti, SSxxx, NiFe or any TC capable material (wire) as your core wire In a profile that supports Replay. There is nowhere in the Materials setting for straight wattage Replay, only whether or not you want to consider it a 'temp sensing' material. Hope that helps
Yes to both. You can watch in Device Monitor how it reacts with your coil. Tick/check the Power and Power Set boxes Nope. Yep, 1 second Nah, Replay is the big thing with these newer boards.
Are you sure it was Check Battery? Can you post a full printscreen of Device Monitor with an atty attached.
Those are the correct settings. You might want to change that 2.75v to 2.9v The mod uses the actual volts to determine when they're empty, what is that? All that 80% number does is control your icon. Run your own Battery Analyzer for your batteries, or search and find someone elses and use that.
Minimum Replay requirements DNA75C, 250C, or GO International software installed Theme that supports Replay Success best practices Ni200, Ti, SSxxx, NiFe or any TC capable material (wire) as your core wire In a profile that supports Replay Suggest you upgrade the software and firmware for your mod. Link in my sig.
Hey @onikami It's not there FOR YOUR MOD, or any C mod. Your hunt can end.
You're very welcome. And welcome. Now that it's working, longer answer. The coil resistance is stored 'per profile', so if you want to use the current coil in a different profile, when you get to the new profile you need to read the ohms. ONCE, per profile being used. Remember to hit select/accept/confirm.
YES Easy answer ........ say 'Yes', read resistance of coil, confirm, select to get back to normal. Then try. You should be fine at this point.
Yessir. The files are compatible/interchangeable across DNA 60, 75, 75C, 200, 250, 250C ...... and I hate to publicly say this, but even Arctic Fox
Material files are independant of coil ID, wraps, number of wires, etc. So, only the material itself. For straight watts, no material file is needed at all, for any material type. What you remember was for an old cheat. There are already some material files on your mod, but you can also get/create some on steam-engine. IMHO you should really try out Replay with a TC build. Still, no material file needed, with the benefit of dry hit protection.
In your Applications folder, you should be seeing escribe suite. When you start that, you should see this then you should choose/select/start EScribe Which would look like this You need to Connect and Download
For the Mac issue, I'd suggest you check you're running the latest versions of software and firmware. Link in my sig. You might wanna try a few different cables if it's not connecting. Some cables are charging only. Search works, and if you hit that magnifying glass, more options appear. djlsb has many YT videos, but they're like an hour long. The GO chip has much fewer customizations than the full blown chip. Many fields have little 'tooltips' written. Welcome
No idea at all. Maybe try Google in countries you get good shipping rates.
@colin_ab OK, in the past I have seen @James (evolv developer) pipe in and ask questions when this appears, but because there's no reply I have no idea what more to look for. But the help desk, as I initially suggested, should. Good luck. Here's an example.
We can't speak for the Help Desk, but with it being new, have you reached out to the Manufacturer? Surely they should have some sort of warranty for a custom device. Have you tried different cables? AND I see what you're saying.
Can you possibly post a printscreen while this is occurring, with the fields in the top left hand window box ticked. That printscreen will also show what version of the firmware you're running. OR, just open a ticket with the Help Desk. Link in my sig.
You can only pre heat in a TC profile - material is identified as a TC material in a profile You can only boost punch when your material is not identified as a TC material in a profile Punch (1-11) is proportional value In a TC profile - The higher the value, the closer it gets to the 'set temp' before ending pre heat In watts - a 1 second 'proportional' increase of watts to get your coil to watts quicker (sorta like soft, normal, hard, or watt curves on other mods) In your case, you could find the wattage you like (say 30 in this case), then set preheat your watts to 10 higher, leave punch at 5 for now. Using Device Monitor you should see if it reaches your set temp
The 'firmware' on the OG is exactly the same as can be found here. I don't know if they even use the latest, but I could imagine that because they're an American manufacturer, to stay on the good side of the FDA, they'd not load the Intl. version. If you're talking customizations, it was all set for defaults, and the 8 profile settings were minimal. You're not really missing anything except a logo or 2. I do have a copy, but am not comfortable sharing,
