  1. Stainless Steel 3xx, 4xx. Ti01, Ni200, NiFe 48/52 AS THE CORE (DOMINANT) material/wire Not Nichrome.
  2. Follow what I suggested in my first reply
  3. Sorry? Who's wrong, what's wrong? First you said Are you now saying your coils are Or do you not believe what I said were best practices?
  4. Are the core wires SS or Nich? Best practices are Core wires are Temp controllable wires Using a Replay enabled theme, and in a replay enabled profile
  5. Moved and merged your duplicate threads. If you look around in here, there are multiple battery/charging posts similar to yours.
  6. @Capobuf So if I understand you correctly, with the working screen, can't you check all the mods? If the liquid is inside the screen wouldn't you just order new screens and maybe a spare or two. Shipping is very reasonable and only one way to you. If the VS cable is non standard length, in the long past others had created an extension cable, or you should contact them. Either way, good luck and let us know how it works out.
  7. That's how I feel about my Triade's. But gotta say my beater VT133 has been a true workhorse. Tried and true. Naked now (paint started flaking at 3 weeks) and a couple mm's narrow, but every atty goes on there first after a rebuild.
  8. @StockQuahog Personally I'd have no battery concerns. Your build and settings are working fine for you. Nothing wrong at all, if you like that vape and flavor. BUT if your build goes wonky you'll be vaping at 155 watts. If you were to put Preheat to 155w, Punch to 11, and set regular power to 50 ....... you'd achieve the same thing, while having some safety if it drops out of TC. By blasting your way to any temp you could be missing out on nuances in your ejuice, which could be a good or bad thing. Higher resistance SS builds are easier for chips to control in general. Your .124 raises up to ~.15 ......... a .4 would raise to ~.48 Only old-timers will appreciate that Karloz bump, where your mod has overshot the temp set before settling.
  9. For anyone else looking here's a Copper one https://www.signaturetips.com/collections/signature-acc/products/calibration-tool-for-dna200-devices
  10. Sorry, don't have one. You might try the Help desk. Link in my signature line.
  11. His name was Ed, and I had contacted him in the past at SmokeFreeMods@gmail.com Others have used 510 tightening tools, but not out of copper.
  12. Go watch a review or two and see how others build and wick it. You use SS of your choice with their build specs.
  13. @Carl sayers SS3xx, SS4xx, NiFe, Ti01, Ni200 are all TC capable. You should probably start with the Stainless Steel
  14. What's there to say. Build your RTA coil out of a TC capable material/wire. Go to a replay enabled profile Find the wattage you like. When you have a really great puff, hit replay.
  15. @ozzyagYeah to 91%, like @dwcraig1 said, NO to acetone
  16. Good stuff, and welcome Sheesh, you should see the emoji right beside that wave
  17. Now that the board's out, I'd give it a thorough cleaning with IPO. Wipe down all the components. The buttons, are 4 part, you can remove top clip, rubber, then flat piece to get to what soldered. Wipe them all, re-assemble, and test. Good luck.
  18. @zlollar06 What firmware version is on your mod?
  19. @Augmentin @Ghoulsfrank What firmware version?
  20. @zark Just to clear up a bit of confusion, whenever I've typed "mods" I'm referring to the volunteers in this forum, and nothing else as we really only discuss DNAs here.
  21. Buddy, that was enthusiasm. My question remains, which other mods? There are 5 mods here (volunteers), 3 main developer/owners at Evolv. If you're talking abut Zark, he's not a part of either category. PS I think you might be the first person to ever call me out for 'bad info'. But that's OK, I'm chillin. 😎
  22. Great, then go lock. You finally got the answer you want. What other mods recommend that you lock? And where?
  23. The research tab might help you. Or your stats are downloaded to ecigstats.org or available via ecigstats. Because you own a 'C", there is much more information available to you. They are also on your device. Hobbyquaker's work IIRC was done by the serial commands available. More info in the Research area. If you only use DNAs, ecigstats can colate all the info in one place for a complete picture.
  24. Do you already own a DNA mod? How many mods do you own?
