So when you said ”If I wanted a TCR of 300, what would I put in that box? Just confused on the conversion” DW said 0.003, and that’s the same as 0.00300. Following that, a lower value of 98 would be 0.00098 The TCR of a material has nothing to do with hotter or colder. It merely states how much a material heats up. The 98 would heat up slower. (All things being equal) See that 500F you wrote, that’s the hotter or colder part.
Battery Icons For Black Wallpaper Screen
Wayneo replied to soldier05354's topic in Themes and Custom Screens
Gimp, MS Paint, Photoshop ................ the list is almost endless. Or even just go repurpose icons from within font files Welcome -
Escribe is a suite of tools containing software for all mods, and firmware for some or all mods also. The notes are there in that thread identifying changes for each going back years. Latest at the very end. Under the options tab in escribe you can choose if you want to be notified of updates. So the entire suite has a Service Pack number. Escribe software has a version number. Firmware has a different number.
LOL. Very first line, of the very first reply from dwcraig. LOL
Numerous formats including a .stl file found here in the zip file
@wogfun Have you reached out to Lost Vape for a replacement? They are the manufacturer. Good luck.
Hey Chris, couple things. I see I had posted that link twice before, first time 9 months ago ............ but not this time. I posted the pics and James posted the link It really does sound like a cryptic link, but hey, we can't force them to change their ways. AND I FULLY AGREE WITH YOU. No need to be sorry pal, have a good one!
If you've searched this forum and can't find one, probably no big loss. You're out a logo, but you can download other screens/logo's/themes. Many if not most mfgr's leave the mods in a default state, but you can run the same tools as them.
⬆ This, right here. What battery and mod are you currently using? Fake or inferior batteries, or massive sag can make you believe you have short runtimes.
That material will be fine. Turn your watts up/down, hit 'replay'. Sit back and don't worry about dry hits from mesh (while in replay).
Make sure you're using material (wire) that is normally used for TC (SS, Ti, Ni200 as examples) for your simple coil, or as the core of a more complex coil.
It can really be as simple as that Yes, 'warmth' and 'boost punch' can help you fine tune your vaping experience. BUT it can be great without them. For now, just puff away in a replay profile in a straight watt material/mode and hit the replay button when you're ready. Watch a video on how it all works and what the terms mean. Maybe put both at 5 for now, move 1 value to 8 tomorrow, if you don't like that change move it back. Some themes work better than others for users, just depending on how/what the creator thinks and if it jives with you. Enjoy your mod
What doubt(s) do you have? If you follow Bill's advice completely, you should be fine. He's a well respected DNA user. And I do mine in a similar manner. ⬆ This, right here.
DNA200 suddenly reading batteries incorrectly.
Wayneo replied to jsforder's topic in Batteries and Charging
That sounds like the connection to one of the batteries could be dirty or needs adjusting. I'd clean them up (battery and mod coonections) with some Isopropynol alcohol (I have used Windex in a pinch) and check them again. While you're doing that see if all 4 mod connections appear to be making good contact. Usually one end is fixed and the other springs/moves in and out. Try that and report back -
Can't change profile after reset to defaults in Escribe.
Wayneo replied to speshals's topic in DNA 200 and 250
There is no reset. There's a reboot or a restore defaults. What you describe is being in a wattage profile where boost is enabled, and your mod is locked. Unlock the mod, and try again Or, under the top options (File, Edit, Internet, etc.) there should be a 'Help' and under there you'll find 'Backups'. You should be able to choose from there, to get you back to where your mod was working fine. -
No.
You could search for it or even better, run your own battery analyzer. Guaranteed accurate for your mod and batteries.
therion 166 batt problem
Wayneo replied to dub benz's topic in Connectors, Components, and Accessories
Sounds like a blown BMIC and you'll need to open a Help Desk ticket. Link below. https://helpdesk.evolvapor.com/index.php?a=add&category=1 -
I've seen very low builds with these boards with Nickel and Titanium in Temp mode. Rarely do any of these mods come fully calibrated that I'd trust the resistance that low, up to my face. My best suggestion would be for you to ask elsewhere where others vape that low and might have more input, or open a Help Desk ticket for their answer.
We're not Evolv employees so I'd suggest you just open a ticket. Don't worry about scratches.
No, I meant preheat as written. My bad about Replay Then yes, do either of those. Probably the second if you want to see the temp. The 600F max appears to be an industry safety norm. Make sure your Preheat Power is greater than your 'settings' 'power', then 'Punch' is 1-11, or by temp as to where those settings drop/stop using the 'preheat' values. I think that gives you what you want with no workaround.
Need how-to for screen replacement on drone 250c
Wayneo replied to Bombastinator's topic in DNA 250 Color
I have never heard of a charge from Evolv's repairs. Considering they have been contracted by LV for warranty work, just send it in. They're prompt and thorough -
3 Torx screws and you get easy access to the entire 510 assembly. I think if you look/measure the length of threading on your atty's you might find one is longer than the others that could have started this issue.
