dwcraig1
Everything posted by dwcraig1
  1. I'm going to take a guess, judging by the single dot at the bottom of the screen maybe is means "Locked". Escribe/Theme designer might offer some insight to it. Vou adivinhar, a julgar pelo único ponto na parte inferior da tela, talvez signifique "Bloqueado". O designer Escriba / Tema pode oferecer algumas dicas.
  2. Make sure that the box is checked in the profile that you are using. If you are still not getting it to Replay check to see if you are using the International firmware and if not try that.
  3. So how much lower does the resistance change after it's been sitting? A little, a lot?
  4. I was just editing my post to mention the cable.
  5. The voltage of your power source (computer USB) looks kind of low. You might try another computer, cable or power supply
  6. I see nothing on their site with a DNA60. https://rusmods.com/index.php?route=product/category&path=57
  7. A DNA60 with USB charge/data port connects to EScribe. The version of EScribe for your DNA75C is certainly capable of connecting to all of the EScribe capable boards. I'm not a Mac user so I don't know the specifics but when I first connect a DNA device Windows detects it and automatically installs the drivers for it. There are quite a few DNA60 mods coming out that have no USB port but to have a USB that is charge only well I can't image that. Does the manufacturer claim it is upgrade-able? Perhaps one of our Mac users can offer more insight.
  8. Well one way would be to number the cells 1 ,2,& 3 with a marker and change their position in the sled and then look at Device Monitor and see where they moved to. Note the voltages of the cells first so you can discern which is which. Other wise you would have to check how the sled is wired to the balance tap on the bottom of the board....too hard.
  9. After looking at your Device Monitor snippet I see now what I missed earlier. Your cell #1 is 4..2 volts, that is full charge. Therefore the charger is balancing the cells and that's a bit of a slow process. After you bring all 3 up to 4.2 volts I suspect your problem will be gone. Let us know how it goes.
  10. Device monitor shows that it is charging at a rate of 0.28 amps so it is charging but slowly. Try a different cable and\or power source. Check to see if USB port on the mod has dirt/lint in it. Your cells are slightly unbalanced but I don't think it's affecting charging but perhaps it is. Do you have access to a stand alone charger? If so charge them that way and get them balanced and see if that helps. Charging with data connection max is 1 amp and without data connection max is 2 amp.
  11. Could you post a snippet of Device Monitor showing the cell voltages? Like this one>
  12. That is correct. I have a DNA75C Spade and it has the highest mod resistance by far, works well though. It's somethog like 0.02 ohm where all my others are around 0.004.
  13. Do your board and room temps look reasonable?
  14. I doubt very much that the board is the problem though anything is possible I guess.
  15. As far as I know VA only handles warranty on products purchased directly from them, otherwise where it was purchased from handles it .
  16. My thoughts is that the wiring is the problem, the 510's positive or it's chassis ground. Regardless it should be returned to place of purchase. Well it doesn't have a regular 510 so the output or ground for the atty.
  17. They (Evolv) are in Ohio also. https://helpdesk.evolvapor.com/index.php?a=add&category=1
  18. Look at the data sheet or elsewhere as to how to fold the screens ribbon.
  19. My guess would be that the ribbon on the screen is being pinched under neath the fire button. I don't know what to think about the firmware issue, did you downgrade it back to 1.2 SP 5.1?
  20. Well those are about if not the exact same settings that come default from Evolv on DNA75, 200 and 250, perhaps more.
  21. DNA60's don't use one as the charger is not on the board, about the best explanation that I can provide. So while the settings are there and can be changed there is no way to measure it. I hope that answers your question some what.
  22. So I didn't really know the answer for sure so I installed the US firmware on my DNA75C and tried to enable the profile that I was using to be able to Replay. No you need the International version. Just go ahead and install it as the boards are the same boards, it's a legal thing for Evolv. Here is what I got when I tried to enable Relay with the US version (SP 33.2 US) Edit: So after posting the above I noted that it only mentioned Boost so I went back and did it over. Replay did not work with the US version.
  23. I'm going to respond to this but it probably isn't going to do you folks any good as they need to be returned. But I will tell you how to figure out what's most likely at fault. Connect you mod to EScribe and make sure it's set for 2 cell operation. Go to Device Monitor and check the voltage of cells 1 & 2, if one of them is higher than 4.2 volts and the other is real low then the battery management chip has gone south. Then if no cells are above 4.2 volts, The voltages are read from the balance tap at the bottom of the board. Most likely the connections to them is poor for what ever reason. So the problem could be with the battery sled wiring, see image, Since these are new they need to be returned where purchased. If that proves too difficult open a ticket with Evolv, perhaps they can help with it. Check under the battery door, look at that small connection between the cells that makes when the battery door closes, that is the connection to tap #1....might be a problem there.
  24. Connect to Escribe /Device Monitor, down on the bottom towards the right side is "Buttons". With no buttons pressed it should say "none". Will it fire using "Puff"?
  25. Don't look at the screen as it looks authentic, look at the component layout on the board.
